ASL 3 issue with uri and yaesu transceiver
I just installed ASL 3 on an old node that used Debian 8 but when I install my old URI on the Yaesu equipment I can’t get the RF part to work, can someone help me with the configuration, I’ve tried with simple and usbradio
Can you give more details than “can’t get the RF part to work”?
The equipment does not transmit when there is activity, I am using as a sound card an old uri that I had in another node running with debian 8 now I am with an rpi with asl 3, in the configuration I tried with simple and also with usbradio and options 0 and also 1, I am using it as a link with a yaesu equipment, the connections to the equipment are correct because they worked perfectly before with the node with debian 8
Sorry, this still isn’t really giving anything to go on here. Are there errors on the Asterisk console, in /var/log/asterisk/messages.log, or elsewhere?
[2025-01-24 21:10:18.715] Asterisk 20.11.0+asl3-3.2.0-2.deb12 built by builder @ allstarlink.org on a aarch64 running Linux on 2024-12-20 20:30:41 UTC
[2025-01-24 21:10:18.816] NOTICE[799] loader.c: 70 modules will be loaded.
[2025-01-24 21:10:19.257] NOTICE[799] cdr.c: CDR simple logging enabled.
[2025-01-24 21:10:19.265] NOTICE[799] dnsmgr.c: Managed DNS entries will be refreshed every 300 seconds.
[2025-01-24 21:10:19.328] NOTICE[799] indications.c: Default country for indication tones: us
[2025-01-24 21:10:19.328] NOTICE[799] indications.c: Setting default indication country to ‘us’
[2025-01-24 21:10:19.556] NOTICE[799] res_smdi.c: No SMDI interfaces are available to listen on, not starting SMDI listener.
[2025-01-24 21:10:19.587] WARNING[799] chan_dahdi.c: Only FXO signalled channels may belong to a call group
[2025-01-24 21:10:19.587] WARNING[799] chan_dahdi.c: Only FXO signalled channels may belong to a pickup group
[2025-01-24 21:10:19.587] NOTICE[799] chan_dahdi.c: Ignoring any changes to ‘userbase’ (on reload) at line 23.
[2025-01-24 21:10:19.587] NOTICE[799] chan_dahdi.c: Ignoring any changes to ‘vmsecret’ (on reload) at line 31.
[2025-01-24 21:10:19.587] NOTICE[799] chan_dahdi.c: Ignoring any changes to ‘hassip’ (on reload) at line 35.
[2025-01-24 21:10:19.587] NOTICE[799] chan_dahdi.c: Ignoring any changes to ‘hasiax’ (on reload) at line 39.
[2025-01-24 21:10:19.587] NOTICE[799] chan_dahdi.c: Ignoring any changes to ‘hasmanager’ (on reload) at line 47.
[2025-01-24 21:10:20.117] WARNING[799] loader.c: Module ‘res_adsi’ has been loaded but may be removed in a future release.
[2025-01-24 21:10:20.429] NOTICE[933] app_rpt.c: Normal Repeater Init 27684
[2025-01-24 21:10:20.437] NOTICE[937] chan_simpleusb.c: Channel 27684: Set option TONE VERIFY, mode: OFF(0).
[2025-01-25 08:50:34.451] WARNING[933] app_rpt.c: rpt_thread restarted on node 27684
[2025-01-25 08:50:34.451] WARNING[18002] channel.c: Channel allocation failed: Refusing due to active shutdown
[2025-01-25 08:50:34.451] ERROR[18002] chan_simpleusb.c: Channel 27684: Unable to create new usb channel
[2025-01-25 08:50:34.451] ERROR[18002] app_rpt/rpt_bridging.c: Failed to request SimpleUSB/27684
[2025-01-25 08:50:34.451] WARNING[18002] app_rpt.c: Disabled broken repeater 27684
[2025-01-25 08:50:37.722] Asterisk 20.11.0+asl3-3.2.0-2.deb12 built by builder @ allstarlink.org on a aarch64 running Linux on 2024-12-20 20:30:41 UTC
[2025-01-25 08:50:37.799] NOTICE[18003] loader.c: 70 modules will be loaded.
[2025-01-25 08:50:37.911] NOTICE[18003] cdr.c: CDR simple logging enabled.
[2025-01-25 08:50:37.918] NOTICE[18003] dnsmgr.c: Managed DNS entries will be refreshed every 300 seconds.
[2025-01-25 08:50:37.968] NOTICE[18003] indications.c: Default country for indication tones: us
[2025-01-25 08:50:37.968] NOTICE[18003] indications.c: Setting default indication country to ‘us’
[2025-01-25 08:50:38.188] NOTICE[18003] res_smdi.c: No SMDI interfaces are available to listen on, not starting SMDI listener.
[2025-01-25 08:50:38.205] WARNING[18003] chan_dahdi.c: Only FXO signalled channels may belong to a call group
[2025-01-25 08:50:38.205] WARNING[18003] chan_dahdi.c: Only FXO signalled channels may belong to a pickup group
[2025-01-25 08:50:38.205] NOTICE[18003] chan_dahdi.c: Ignoring any changes to ‘userbase’ (on reload) at line 23.
[2025-01-25 08:50:38.205] NOTICE[18003] chan_dahdi.c: Ignoring any changes to ‘vmsecret’ (on reload) at line 31.
[2025-01-25 08:50:38.205] NOTICE[18003] chan_dahdi.c: Ignoring any changes to ‘hassip’ (on reload) at line 35.
[2025-01-25 08:50:38.205] NOTICE[18003] chan_dahdi.c: Ignoring any changes to ‘hasiax’ (on reload) at line 39.
[2025-01-25 08:50:38.205] NOTICE[18003] chan_dahdi.c: Ignoring any changes to ‘hasmanager’ (on reload) at line 47.
[2025-01-25 08:50:38.549] NOTICE[18003] ./xpmr/xpmr.c: xpmr rxlpf: 0
[2025-01-25 08:50:38.549] NOTICE[18003] ./xpmr/xpmr.c: xpmr rxhpf: 0
[2025-01-25 08:50:38.549] NOTICE[18003] ./xpmr/xpmr.c: xpmr txlpf: 0
[2025-01-25 08:50:38.549] NOTICE[18003] ./xpmr/xpmr.c: xpmr txhpf: 0
[2025-01-25 08:50:38.689] WARNING[18003] loader.c: Module ‘res_adsi’ has been loaded but may be removed in a future release.
[2025-01-25 08:50:39.034] NOTICE[18046] app_rpt.c: Normal Repeater Init 27684
[2025-01-25 08:50:39.036] NOTICE[18052] chan_usbradio.c: Channel 27684: Automatically assigned USB device 1-1.5:1.0 to USBRadio channel
[2025-01-25 08:50:39.040] NOTICE[18051] chan_usbradio.c: Channel 27684: Set option TONE VERIFY, mode: OFF(0).
[2025-01-25 08:50:39.055] WARNING[18051] chan_usbradio.c: Possibly stuck USB read channel. [27684]
[2025-01-25 08:50:39.080] WARNING[18051] chan_usbradio.c: USB read channel [27684] was not stuck.
[2025-01-25 08:53:15.539] WARNING[18046] app_rpt.c: rpt_thread restarted on node 27684
[2025-01-25 08:53:15.539] WARNING[18250] channel.c: Channel allocation failed: Refusing due to active shutdown
[2025-01-25 08:53:15.539] ERROR[18250] chan_usbradio.c: Channel 27684: Unable to create new usb channel
[2025-01-25 08:53:15.539] ERROR[18250] app_rpt/rpt_bridging.c: Failed to request Radio/27684
[2025-01-25 08:53:15.539] WARNING[18250] app_rpt.c: Disabled broken repeater 27684
[2025-01-25 08:53:18.556] Asterisk 20.11.0+asl3-3.2.0-2.deb12 built by builder @ allstarlink.org on a aarch64 running Linux on 2024-12-20 20:30:41 UTC
[2025-01-25 08:53:18.683] NOTICE[18251] loader.c: 70 modules will be loaded.
[2025-01-25 08:53:18.790] NOTICE[18251] cdr.c: CDR simple logging enabled.
[2025-01-25 08:53:18.796] NOTICE[18251] dnsmgr.c: Managed DNS entries will be refreshed every 300 seconds.
[2025-01-25 08:53:18.847] NOTICE[18251] indications.c: Default country for indication tones: us
[2025-01-25 08:53:18.847] NOTICE[18251] indications.c: Setting default indication country to ‘us’
[2025-01-25 08:53:19.067] NOTICE[18251] res_smdi.c: No SMDI interfaces are available to listen on, not starting SMDI listener.
[2025-01-25 08:53:19.084] WARNING[18251] chan_dahdi.c: Only FXO signalled channels may belong to a call group
[2025-01-25 08:53:19.084] WARNING[18251] chan_dahdi.c: Only FXO signalled channels may belong to a pickup group
[2025-01-25 08:53:19.085] NOTICE[18251] chan_dahdi.c: Ignoring any changes to ‘userbase’ (on reload) at line 23.
[2025-01-25 08:53:19.085] NOTICE[18251] chan_dahdi.c: Ignoring any changes to ‘vmsecret’ (on reload) at line 31.
[2025-01-25 08:53:19.085] NOTICE[18251] chan_dahdi.c: Ignoring any changes to ‘hassip’ (on reload) at line 35.
[2025-01-25 08:53:19.085] NOTICE[18251] chan_dahdi.c: Ignoring any changes to ‘hasiax’ (on reload) at line 39.
[2025-01-25 08:53:19.085] NOTICE[18251] chan_dahdi.c: Ignoring any changes to ‘hasmanager’ (on reload) at line 47.
[2025-01-25 08:53:19.085] WARNING[18251] chan_dahdi.c: Only FXO signalled channels may belong to a call group
[2025-01-25 08:53:19.085] WARNING[18251] chan_dahdi.c: Only FXO signalled channels may belong to a pickup group
[2025-01-25 08:53:19.582] WARNING[18251] loader.c: Module ‘res_adsi’ has been loaded but may be removed in a future release.
[2025-01-25 08:53:19.915] NOTICE[18294] app_rpt.c: Normal Repeater Init 27684
[2025-01-25 08:53:19.921] NOTICE[18299] chan_simpleusb.c: Channel 27684: Set option TONE VERIFY, mode: OFF(0).
I have changed in the simpleusb menu to usb instead of usbinvert now when I connect to a parrot node I receive audio although it is choppy on the other hand I notice that when I transmit with my handy no audio enters the node and therefore I cannot configure the audio input
When you say you’re using a URI is that the DMK-URI and on which Yaesu repeater Dr1, Dr1x, Dr2x? I’m also using an old DMK-URI and it worked on Hamvoip, for a while, and now with ASL3 it works. Audio was good on ASL3 until something happened then the audio went LOW and no adjustment would bring it up to acceptable. Still playing but can’t get to it for a few days. Are you going into the 15pin rear port or the round din plug? Can you tell me which pin on your radio connector goes to what pin on the DB25?
I too am using SimpleUSB > Repeater mode > USB (not USBInvert).
I don’t see anything wrong in your logs. Make sure you have things setup properly in simpleusb-tune-menu.
This using a Yaesu ft-8900 equipment
Could you give me some recommendations to configure it correctly?
