Download ASL 2.0.0-beta.5 here
Report Bugs/Issues here
- Change default hangtimes to favor simplex nodes in rpt.conf
- Add bashrc alias for
first-timescript to work without sudo - Fix Register string behavior weirdness in asl-menu
- Add tomorse script to convert text to morse code wav files. Morse code generation in ASL isn’t always consistent, so allowing static generation fixes this. use
tomorse -hfor help. - Don’t bother with root password in
first-time- just setrepeater's password. - Bring over sounds dir from ASL 1.01 Fix #10
- Tweak menus and add
/etc/motd - Add credits for contributors
- Fix paths in asl-menu and first-time. Fix #12 and #13
- Cleanup. Fix paths. Add CPANM and locate. Fix paths for astdb.txt.
- Remove asl images on
make clean - Fix greps for asterisk ports, ssh, and mylanip for supermon
- Reformat code for supermon. Fix several paths to work on Debian 10. Add www user to sudo. Add extra supermon scripts. Add config file for apache2 cgi-bin. Fix #9.
