Being that information I have found here in the forum (not much) and on the wiki (not at all) does not address my issues/questions, I decided to go ahead and post a topic here which may just be an easy answer and a problem of proper wording in the search feature on my part.
BUT!!
After being a long time user of the AllStarLink/HamVoip (whichever) system, I have decided to enable my nodes APRS feature using the ASL distro on a Raspberry Pi. I have setup the gps.conf file as much as i can understand each lines definitions, enabled the module, restarted Asterisk and WALA, I am on the map.
But, I noticed my antenna height, radio wattage, gain, direction and calculated range (based on all of the previous) were way wrong.
So I decided to change those parameters, shown below, to see how the information showed up on the APRS maps to try to get a general idea of how this all worked:
elev = 1 ; Elevation of Antenna in Meters (NOT HAAT)
power = 100 ; Power level
height = 1 ; Antenna Height in HAAT
gain = 5 ; Antenna Gain
dir = 0 ; Antenna Direction
1st, of course (see docs allstarlink org/drupal/node/14, had to remove https://) doesn’t exist anymore and takes you to AllStarLink Wiki
2nd and on, my antenna height shows as 320’, gain shows as 0, direction shows as SW, power is 16W, and calculated range is 23.39 Miles. These are the same information that was displayed with my proper settings in the file and shows on both https://aprs-map.info and https://aprs.fi.
BTW, frequency and tone do not show up in the APRS information at all so I put it in the comment txt which, along with the coordinates and callsign show as expected.
Is there some other setup procedures to get this right?
Are there other current sources of setup information for this and ASL in general for its many features?
Thanks all and everyone
Harold
K7ILO
Las Vegas, NV. 27863
