aprs password for app_gps
I would like to set up my allstarlink system to report position information to the aprs system.
Can someone tell me how to set up this password? Also, are the default server and port listed in the example below what should be used?
I have searched the aprs site and couldn’t find who to request this information from.
Chuck Henderson, WB9UUS
; Configuration for app_gps
[general]
call = wb9uus-2 ; callsign (including SSID) for APRS purposes
**password = 12345 ; Password for APRS-IS server for above callsign**
comment = AllStar Node 27468 ; Text to be displayed associated with this station
**server = [second.aprs.net](http://second.aprs.net)  ; APRS-IS server to report information to**
**port = 10151 ; port on server to send data**
icon = r ; A CAR (default) Icon do be displayed for station on APRS display (see below)
comport = /dev/ttyS0 ; Serial port for GPS receiver (specify this only if using GPS receiver)
baudrate = 4800 ; Baud rate for GPS receiver (specify this only if using GPS receiver)
;debug = y ; set this for debug output
freq=442.700 ; Display Frequency of station
tone=107.2 ; CTCSS tone of station (0.0 for none)
lat=40.508 ; Fixed (default) latitude in decimal degrees
lon=-88.988 ; Fixed (default) longitude in decimal degrees
elev=123.4 ; Elevation of Antenna in Meters (*NOT* HAAT)
power=9 ; Power level (see below)
height=5 ; Antenna Height in HAAT (see below)
gain=8 ; Antenna Gain (see below)
dir=0 ; Antenna Direction (see below)
On Sat, Jan 22, 2011 at 10:30 PM, Jim Duuuude [email protected] wrote:
There have (obviously) been some changes/improvements made to the
Echolink and APRS/GPS subsystems within app_rpt.
Included in these is the ability for a node to report its “fixed” GPS coordinates
to the APRS network, even if it does not have a GPS receiver connected.
Please see the following:
Setting up Echolink Connectivity
http://209.159.155.200/drupal/node/56
Setting Up APRS and GPS Configuration
http://209.159.155.200/drupal/node/179
Of course, the latest copies of app_gps and chan_echolink need to be
downloaded from the SVN.
JIM WB6NIL
Well – Google found this
http://zielkeassociates.com/~jack/aprs-xo/aprspass/
I took the first link provided and looked at the first few entries and there are emails for sysops who will give you a “passcode”
Apparently the passcode is generated from an algorithm using your call+SSID as input.
I have not tried it (yet)
Ken
From: [email protected] [mailto:[email protected]] On Behalf Of Chuck Henderson
Sent: Sunday, January 23, 2011 5:53 AM
To: app_rpt mailing list
Subject: [App_rpt-users] aprs password for app_gps
[general]
JIM WB6NIL
The APRS-IS password could be generated using the callpass utility that
comes with xastir.
Bogdan - YO3IIU
information
to the aprs system.
I have searched the aprs site and couldn't find who to request this
information from.
[general]
call = wb9uus-2 ; callsign (including SSID) for APRS purposes*password
station*server = second.aprs.net ; APRS-IS server to report information
to**port = 10151 ; port on server to send data*
display (see below)
using GPS receiver)
Included in these is the ability for a node to report its "fixed" GPS
coordinates
JIM WB6NIL
[email protected]
ohnosec.org
The heck with all this confusion regarding APRS passwords!!
I just reverse engineered the password algorithm and will make
a password generator (and will also automatically generate a password
for Portal-generate configurations).
JIM
Date: Sun, 23 Jan 2011 15:49:55 +0200
To: [email protected]
CC: [email protected]
Subject: Re: [App_rpt-users] aprs password for app_gps
comes with xastir.
Bogdan - YO3IIU
information
to the aprs system.
information from.
[general]
call = wb9uus-2 ; callsign (including SSID) for APRS purposespassword
stationserver = second.aprs.net ; APRS-IS server to report information
display (see below)
using GPS receiver)
elev=123.4 ; Elevation of Antenna in Meters (NOT HAAT)
coordinates
JIM WB6NIL
[email protected]
ohnosec.org
[email protected]
ohnosec.org
Okay, the web site now has automatic APRS password generation for Web-based
configurations, and a page to do it manually (under “server”).
JIM WB6NIL
To: [email protected]; [email protected]
Date: Sun, 23 Jan 2011 08:13:51 -0800
JIM
comes with xastir.
Bogdan - YO3IIU
information
to the aprs system.
information from.
[general]
display (see below)
using GPS receiver)
coordinates
JIM WB6NIL
[email protected]
ohnosec.org
[email protected]
ohnosec.org
[email protected]
The protocol is quite simple and the source for callpass is included in
the xastir source. Though, reverse engineering it seems a lot more fun :slight_smile:
Regards,
Bogdan - YO3IIU
JIM
comes with xastir.
Bogdan - YO3IIU
> information
> to the aprs system.
default
> information from.
>> [general]
purposes*password
this
information
APRS
>> display (see below)
only
>> using GPS receiver)
>> On Sat, Jan 22, 2011 at 10:30 PM, Jim Duuuude >> >> <[email protected]>wrote:
GPS
>>> coordinates
connected.
>>> JIM WB6NIL
> App_rpt-users mailing list
> [email protected]
> ohnosec.org
[email protected]
ohnosec.org
it was!! :slight_smile:
Date: Mon, 24 Jan 2011 00:27:16 +0200
Subject: RE: [App_rpt-users] aprs password for app_gps
CC: [email protected]; [email protected]; [email protected]
Regards,
Bogdan - YO3IIU
JIM
comes with xastir.
Bogdan - YO3IIU
information
to the aprs system.
default
information from.
[general]
purposespassword
this
information
APRS
display (see below)
only
using GPS receiver)
On Sat, Jan 22, 2011 at 10:30 PM, Jim Duuuude > >> >> [email protected]wrote:
GPS
coordinates
connected.
JIM WB6NIL
[email protected]
ohnosec.org
[email protected]
ohnosec.org
Since adding the gps.conf, which is working and puts me on the aprs maps, I started getting the following messages on the console….
[Jan 24 08:59:57] WARNING[2659]: chan_usbradio.c:2152 sound_thread: select failed: Interrupted system call
[Jan 24 09:00:07] WARNING[2659]: chan_usbradio.c:2152 sound_thread: select failed: Interrupted system call
[Jan 24 09:00:17] WARNING[2659]: chan_usbradio.c:2152 sound_thread: select failed: Interrupted system call
[Jan 24 09:00:27] WARNING[2659]: chan_usbradio.c:2152 sound_thread: select failed: Interrupted system call
[Jan 24 09:00:37] WARNING[2659]: chan_usbradio.c:2152 sound_thread: select failed: Interrupted system call
[Jan 24 09:00:47] WARNING[2659]: chan_usbradio.c:2152 sound_thread: select failed: Interrupted system call
I then enabled debugging in the gps.conf file and this is what I got…
[Jan 24 09:14:22] NOTICE[2658]: app_gps.c:456 gpsthread: got lat: 4030.48N, long: 08859.28W, elev: 123.4M
[Jan 24 09:14:22] WARNING[2659]: chan_usbradio.c:2152 sound_thread: select failed: Interrupted system call
[Jan 24 09:14:22] NOTICE[2658]: app_gps.c:518 gpsthread: sent packet: user wb9uus-r pass 18598 vers “Asterisk app_gps”
[Jan 24 09:14:22] NOTICE[2658]: app_gps.c:527 gpsthread: sent packet: wb9uus-r>APRS,qAR,wb9uus-VS:=4030.48N/08859.28WrPHG9580/AllStar Node 27468
[Jan 24 09:14:32] NOTICE[2658]: app_gps.c:456 gpsthread: got lat: 4030.48N, long: 08859.28W, elev: 123.4M
[Jan 24 09:14:32] WARNING[2659]: chan_usbradio.c:2152 sound_thread: select failed: Interrupted system call
[Jan 24 09:14:42] NOTICE[2658]: app_gps.c:456 gpsthread: got lat: 4030.48N, long: 08859.28W, elev: 123.4M
[Jan 24 09:14:42] WARNING[2659]: chan_usbradio.c:2152 sound_thread: select failed: Interrupted system call
[Jan 24 09:14:52] NOTICE[2658]: app_gps.c:456 gpsthread: got lat: 4030.48N, long: 08859.28W, elev: 123.4M
[Jan 24 09:14:52] WARNING[2659]: chan_usbradio.c:2152 sound_thread: select failed: Interrupted system call
[Jan 24 09:14:52] NOTICE[2658]: app_gps.c:518 gpsthread: sent packet: user wb9uus-r pass 18598 vers “Asterisk app_gps”
[Jan 24 09:14:52] NOTICE[2658]: app_gps.c:527 gpsthread: sent packet: wb9uus-r>APRS,qAR,wb9uus-VS:=4030.48N/08859.28WrPHG9580/AllStar Node 27468
[Jan 24 09:15:02] NOTICE[2658]: app_gps.c:456 gpsthread: got lat: 4030.48N, long: 08859.28W, elev: 123.4M
[Jan 24 09:15:02] WARNING[2659]: chan_usbradio.c:2152 sound_thread: select failed: Interrupted system call
**I suspect that it is expecting a radio to be connected for it to send packets out over the air. **
How do I configure this so it can work or, if that isn’t what it is about, then how do I get rid of the warning?
Regards,
Bogdan - YO3IIU
JIM
comes with xastir.
Bogdan - YO3IIU
information
to the aprs system.
default
information from.
[general]
purposespassword
this
information
APRS
display (see below)
only
using GPS receiver)
On Sat, Jan 22, 2011 at 10:30 PM, Jim Duuuude > > >> >> [email protected]wrote:
GPS
coordinates
connected.
JIM WB6NIL
[email protected]
[email protected]
seeing the same thing…
Also...is there any variable possible to set to cut down the
reporting interval? For a stationary system…like a
repeater…every 30 seconds seems a bit much (maybe if it was
located on the San Andreas fault, it would be moving, though…;))
-- 73 all...and thanks, Jim, for the great functionality.
Bryan
Echolink WB0YLE-R
Allstar 27294
APRS WB0YLE-8
LS/MFT
YMMV
ROTFLMAO
etc...
could you send me a tarball of your entire /etc/asterisk directory, so that I may duplicate
the problem here?
JIM
Date: Mon, 24 Jan 2011 09:32:41 -0600
Regards,
Bogdan - YO3IIU
JIM
comes with xastir.
Bogdan - YO3IIU
information
to the aprs system.
default
information from.
[general]
purposespassword
this
information
APRS
display (see below)
only
using GPS receiver)
GPS
coordinates
connected.
JIM WB6NIL
[email protected]
[email protected]
also, did you update everything to the latest SVN, or just app_gps and chan_echolink??
My copy of chan_usbradio.c does not have that line in the same location, which leads me to
believe that you didnt update from the whole SVN.
Heck, just send me a copy of your chan_usbradio.c file, too while youre at it.
JIM
Regards,
Bogdan - YO3IIU
JIM
comes with xastir.
Bogdan - YO3IIU
information
to the aprs system.
default
information from.
[general]
purposespassword
this
information
APRS
display (see below)
only
using GPS receiver)
GPS
coordinates
connected.
JIM WB6NIL
[email protected]
[email protected]
Agreed, it would be good if there was a way to set this interval.
Tim
:wq
On Jan 24, 2011, at 8:00 AM, Bryan D. Boyle wrote:
Also...is there any variable possible to set to cut down the reporting interval? For a stationary system...like a repeater...every 30 seconds seems a bit much
Ladies & Gentlemen...
The simplest solution to get individual APR passcodes is to use the APRSPASS program that's installed with APRSD. There's nothing mysterious or secret about acquiring APRS passcodes. Here's a cut and paste about APRSPASS:
APRS passcode calculator (new in 2.1.1)
The aprspass program is located in the /home/aprsd2 directory. You may move it to another more convienient location if you wish. To determine the aprs passcode required for a callsign "N0CALL":
Change to the /home/aprsd2 directory.
./aprspass N0CALL
APRS passcode for N0CALL = 12345
I've used APRSPASS to generate passwords for several programs, including UIVIEW32, javAPRS, APRSD, Xastir, etc.
I hope this is what you were looking for, and has helped to solve your problems.
Best regards,
Gary E. Kohtala - K7EK / AFF0WA / AFA0IU / AFE0DM
Personal Web Page: www dot k7ek dot net
the problem here?
JIM
Since adding the gps.conf, which is working and puts me on the aprs maps, I started getting the following messages on the console...
I then enabled debugging in the gps.conf file and this is what I got...
[Jan 24 09:14:22] NOTICE[2658]: app_gps.c:518 gpsthread: sent packet: user wb9uus-r pass 18598 vers "Asterisk app_gps"
[Jan 24 09:14:52] NOTICE[2658]: app_gps.c:518 gpsthread: sent packet: user wb9uus-r pass 18598 vers "Asterisk app_gps"
How do I configure this so it can work or, if that isn't what it is about, then how do I get rid of the warning?
Regards,
Bogdan - YO3IIU
JIM
comes with xastir.
Bogdan - YO3IIU
information
to the aprs system.
default
information from.
[general]
purposespassword
this
information
APRS
display (see below)
only
using GPS receiver)
On Sat, Jan 22, 2011 at 10:30 PM, Jim Duuuude > > > >> >> [email protected]wrote:
GPS
coordinates
connected.
JIM WB6NIL
[email protected]
[email protected]
[email protected]
