App_rpt-users Digest, Vol 88, Issue 19
You are correct Joe. The RTCM is a contender though it wouldn’t exist or would be useless without Jim’s software.
As Robert mentioned, and his friend is right. I was warned by a local and very knowledgeable elmer also. Personally I’m simulcasting but fortunately there is a node smack dab in the middle that “most” users will switch to so they don’t hear the issues in the overlap zones.
I haven’t yet cracked the RTCM’s open to modify them and I may not ever do it just cause i’m lazy. It depends on how picky your users are. That’s sort of a loaded question though. When folks get used to allstar (especially if you’re running a high quality codec) and they travel into one of these overlap zones they’ll probably complain because they’re used to so much more fidelity!
Does it work without jumping through all the hoops…? Yes, it’s just way more ugly in the areas that have overlapping coverage.
blah blah…i’m delirious and I still have two more night shifts to go!
73 de K0JSC
On Mon, Jun 6, 2016 at 10:59 AM, app_rpt-users-request@ohnosec.org wrote:
Send App_rpt-users mailing list submissions to
    app_rpt-users@ohnosec.org
To subscribe or unsubscribe via the World Wide Web, visit
or, via email, send a message with subject or body ‘help’ to
You can reach the person managing the list at
    app_rpt-users-owner@ohnosec.org
When replying, please edit your Subject line so it is more specific
than “Re: Contents of App_rpt-users digest…”
Today’s Topics:
  1. Re: RTCM Simulcast question (Robert Newberry)
  2. Re: App_rpt-users Digest, Vol 88, Issue 16 (Joe Leikhim)
Message: 1
Date: Mon, 6 Jun 2016 12:56:57 -0400
To: app_rpt-users@ohnosec.org
Subject: Re: [App_rpt-users] RTCM Simulcast question
Message-ID:
    <CAM09xEagKzHhFhw94cqe7oDKWkhr51fdTKt0CuQB2DMz7OH4Gg@mail.gmail.com>
Content-Type: text/plain; charset=“utf-8”
Please don’t flame me.
I have a friend who used to work in the paging industry. When I talked to
him about simulcast he was telling me about the paging industry the pains
they went thru. He was saying that they used all of the same transmitters
made around the same time. A signal can go from point A to B in transmitter
a different lengths of time.
He basically told me the same thing, that go do it and enjoy. He just
warned me about PL sync and all of the details to getting it right. He just
said at the end of the day that he was confident I could get it to work,
but probably will not be satisfied with the results.
N1XBM
Apparare Scientor
Paratus Communicare
Allstar Node # 27086, 41540, 41812, 42086, 42658, 42657
www.radioguysrepeaternetwork.com
-------------- next part --------------
An HTML attachment was scrubbed…
URL: <http://ohnosec.org/pipermail/app_rpt-users/attachments/20160606/87496c0d/attachment-0001.html>
Message: 2
Date: Mon, 6 Jun 2016 12:59:27 -0400
Subject: Re: [App_rpt-users] App_rpt-users Digest, Vol 88, Issue 16
Message-ID: afeb133c-87cc-0c50-9e8d-5ee854a7fc24@leikhim.com
Content-Type: text/plain; charset=“windows-1252”; Format=“flowed”
There was mention on this board that drift of the 9.6 MHz clock causes
the CTCSS phase to shift. If this is the case, you will have audible
noise and possibly receiver CTCSS drop outs in overlap areas. You will
have distortion of audio frequencies as well.
Whatever solution to the 9.6 MHz clock must be phase coherent between
RTCM nodes .
I have no experience with RTCM, but am quite familiar with commercial
simulcast in the LMR world. I am lurking here because I see the RTCM as
a very affordable contender to the commercial products that exist today.
Joe K4SAT
On 6/6/2016 12:23 PM, Jeff Carrier wrote:
The RTCM and simulcast DOES work. As mentioned before, you have to be
using a transmitter that can accept a 10 mHz (or whatever) reference
signal. You also need 1 PPS for your receivers and transmitter. You
also need to sync the RTCM to your GPSDO (which I have not done). If
you have not done all this you WILL hear some “funk” in the overlap
areas.
That “funk” can go from usable to un-usable depending on how strong
the transmitters are in the overlap region.
Pardon the “non-technical” terms. It does work but the law of physics
do apply here.
de K0JSC
On Mon, Jun 6, 2016 at 9:54 AM, <app_rpt-users-request@ohnosec.org
app_rpt-users@ohnosec.org <mailto:app_rpt-users@ohnosec.org>
or, via email, send a message with subject or body 'help' to
<mailto:app_rpt-users-request@ohnosec.org>
<mailto:app_rpt-users-owner@ohnosec.org>
than "Re: Contents of App_rpt-users digest..."
Today's Topics:
   1. Re: audio for direct VCO FM (Joe Leikhim) (Steve Wright)
   2. Re: RTCM Simulcast question (Steve Wright)
   3. Re: audio for direct VCO FM: Si5351B (David McGough)
   4. Re: RTCM Simulcast question (Joe Moskalski)
   5. Re: RTCM Simulcast question (David McGough)
   6. Re: RTCM Simulcast question (Joe Moskalski)
Message: 1
Date: Mon, 6 Jun 2016 19:40:50 +1200
<mailto:info@meshnetworks.co.nz>>
To: app_rpt-users@ohnosec.org <mailto:app_rpt-users@ohnosec.org>
Subject: Re: [App_rpt-users] audio for direct VCO FM (Joe Leikhim)
Message-ID: <57552902.9070008@meshnetworks.co.nz
<mailto:57552902.9070008@meshnetworks.co.nz>>
Content-Type: text/plain; charset=windows-1252; format=flowed
On 04/06/16 04:00, Joe Leikhim <rhyolite@leikhim.com
<mailto:rhyolite@leikhim.com>> wrote:
> Assuming the VCO is part of a PLL, the PLL will tend to
"correct" the
> modulation, [....]
Was planning to use the Si5351B - has VCO input.
S
Message: 2
Date: Mon, 6 Jun 2016 20:22:36 +1200
Message-ID: <575532CC.2020304@meshnetworks.co.nz
<mailto:575532CC.2020304@meshnetworks.co.nz>>
On Sat, Jun 4, 2016 at 6:03 PM, Joe Moskalski <kc2irv@gmail.com
<mailto:kc2irv@gmail.com>> wrote:
> I will be setting up a 2 site UHF simulcast system in the coming
months
Huh?  I was told (on this list) that simulcast TX "doesn't work".
S
Message: 3
Date: Mon, 6 Jun 2016 10:46:38 -0400 (EDT)
From: David McGough <kb4fxc@inttek.net <mailto:kb4fxc@inttek.net>>
Subject: Re: [App_rpt-users] audio for direct VCO FM: Si5351B
Message-ID:
<Pine.LNX.4.44.1606060946450.4196-100000@goliath.inttek.net
<mailto:Pine.LNX.4.44.1606060946450.4196-100000@goliath.inttek.net>>
Content-Type: TEXT/PLAIN; charset=US-ASCII
Hi Steve,
We're getting way off topic for the mailing list, but, I thought
I'd post
this reply here if there are any other interested hams out there,
perhaps
who are also experimenting in this area.
I haven't played with the Si5351B version of this interesting
chip, yet. I
wonder whether the voltage control input of this chip would be
suitable
for AF FM modulation? Assuming that you could modulate the VCXO at
audio
frequencies (the datasheet isn't completely clear to me about
that), an
immediate issue would be that everytime you change the fractional-N
division ratio, you'll change the modulation index. This will have
to be
compensated for, one way or another.
I've been playing with several boards with Si5351 chips. They're
pretty
neat. They're also pretty noisy! ...With both spurious and phase
noise.
The phase noise can be improved somewhat with a better external
crystal
oscillator, the spurs seem more challenging.  Using the on-board
VCXO with
the 5351B, you can't use a high quality external oscillator, so phase
noise and overall frequency stability could be an issue, too.
Anyhow, for my applications, I'm following the Si5351 with a secondary
clean-up VCO/PLL, which was already in the radios. I just needed a
frequency-agile reference oscillator, so to speak. I think the
Si5351 will
work well for this, based on my preliminary tests! (I'd certainly
like to
hear the experiences from anyone who has already been down this road!)
I guess you're not finding any local sources of surplus radios?
Do you
have any 6m power amps available?
73, David KB4FXC
"correct" the
> > modulation, [....]
> S
Message: 4
Date: Mon, 6 Jun 2016 11:03:11 -0400
From: Joe Moskalski <kc2irv@gmail.com <mailto:kc2irv@gmail.com>>
To: App_rpt-users@ohnosec.org <mailto:App_rpt-users@ohnosec.org>
Message-ID:
<CAES28qxB06niu+nL4Y5QfUvgZFf-y8s=uZdH2afzxKnwr0HV+w@mail.gmail.com
<mailto:uZdH2afzxKnwr0HV%2Bw@mail.gmail.com>>
Content-Type: text/plain; charset="utf-8"
> It seems clear that in order for simulcast to work properly with
the RTCM
> I will need to clock the CPU to the GPSDO. Is there a device
available to
> give you the 9.6 mhz reference from the 10 mhz out from the
GPSDO or does
> anyone have a schematic available so that I can build them myself?
<[https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail&utm_term=icon](https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail&utm_term=icon)>
Virus-free.
[www.avast.com](http://www.avast.com) <[http://www.avast.com](http://www.avast.com)>
<[https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail&utm_term=link](https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail&utm_term=link)>
<#DDB4FAA8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
An HTML attachment was scrubbed...
URL:
<[http://ohnosec.org/pipermail/app_rpt-users/attachments/20160606/a36d4626/attachment-0001.html](http://ohnosec.org/pipermail/app_rpt-users/attachments/20160606/a36d4626/attachment-0001.html)>
Message: 5
Date: Mon, 6 Jun 2016 11:36:01 -0400 (EDT)
Message-ID:
<Pine.LNX.4.44.1606061122550.4196-100000@goliath.inttek.net
<mailto:Pine.LNX.4.44.1606061122550.4196-100000@goliath.inttek.net>>
Hi Joe,
While on the subject of the Si5351 chips, the application of
converting
one reference clock to a secondary frequency is what they were
designed
for. So, since you've already got a GPS reference, this -might- be an
inexpensive starting point...For this application, you obviously won't
need all the bells and whistles presented in this article! See:
[http://www.knology.net/~gmarcus/Si5351/Si5351_VFO_QEX.pdf](http://www.knology.net/~gmarcus/Si5351/Si5351_VFO_QEX.pdf)
<[http://www.knology.net/%7Egmarcus/Si5351/Si5351_VFO_QEX.pdf](http://www.knology.net/%7Egmarcus/Si5351/Si5351_VFO_QEX.pdf)>
[http://www.knology.net/~gmarcus](http://www.knology.net/~gmarcus) <[http://www.knology.net/%7Egmarcus](http://www.knology.net/%7Egmarcus)>
Note that I would replace the Si5351 25MHz reference with a decent
TCXO
(available on ebay, etc.)....Note that I haven't used the Si5351
with an
RTCM, there may be simpler/better ways???
73, David KB4FXC
with the RTCM
available to
GPSDO or does
> Virus-free.
Message: 6
Date: Mon, 6 Jun 2016 11:54:11 -0400
To: David McGough <kb4fxc@inttek.net <mailto:kb4fxc@inttek.net>>
Cc: App_rpt-users@ohnosec.org <mailto:App_rpt-users@ohnosec.org>
Message-ID:
<CAES28qx-G3wytTXKMRVvzMNm+498_c-aeNB6JrTWmZOR7A7ZcA@mail.gmail.com
<mailto:CAES28qx-G3wytTXKMRVvzMNm%2B498_c-aeNB6JrTWmZOR7A7ZcA@mail.gmail.com>>
I mentioned this to someone else, QRP Labs has a kit that creates
a OCXO
around the Si5351 chip. here is the link:
[http://www.qrp-labs.com/ocxokit.html](http://www.qrp-labs.com/ocxokit.html)
If you couple this with another kit of theirs you can program it
it any
frequency you want. My only thought is would it be accurate/stable
enough.
[http://www.qrp-labs.com/progrock.html](http://www.qrp-labs.com/progrock.html)
Virus-free.
On Mon, Jun 6, 2016 at 11:36 AM, David McGough <kb4fxc@inttek.net
<mailto:kb4fxc@inttek.net>> wrote:
> Hi Joe,
converting
designed
be an
won't
decent TCXO
with an
> 73, David KB4FXC
with the
> RTCM
available
> to
GPSDO or
> does
myself?
> > Virus-free.
> To unsubscribe from this list please visit
> [http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users](http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users) and
scroll down
> to the bottom of the page. Enter your email address and press the
> "Unsubscribe or edit options button"
> You do not need a password to unsubscribe, you can do it via email
> confirmation. If you have trouble unsubscribing, please send a
message to
> the list detailing the problem.
URL:
<[http://ohnosec.org/pipermail/app_rpt-users/attachments/20160606/a06570ac/attachment.html](http://ohnosec.org/pipermail/app_rpt-users/attachments/20160606/a06570ac/attachment.html)>
End of App_rpt-users Digest, Vol 88, Issue 16
Joe Leikhim
Leikhim and Associates
Communications Consultants
Oviedo, Florida
JLeikhim@Leikhim.com
407-982-0446
WWW.LEIKHIM.COM
URL: <http://ohnosec.org/pipermail/app_rpt-users/attachments/20160606/00c882a2/attachment.html>
End of App_rpt-users Digest, Vol 88, Issue 19
One method that would improve the simulcast performance without going nuts designing, troubleshooting and building a completely separate device to clock the RTCM to the GPSDO would be to replace the the 9.6 Mhz crystal with a TCXO. There are several available with a square wave 9.6 Mhz output with an accuracy of .3 ppm. Of course this won’t make it perfect but its minimally invasive, cheap, easy and most importantly… readily available.
Another question I have is would an external oscillator with a sine wave output work? If so then there are 9.6 Mhz OCXO’s (I found some on ebay) that would be an even further improvement.
73 de K0JSC
Today’s Topics:
Message: 1
Message-ID:
N1XBM
Apparare Scientor
Paratus Communicare
Message: 2
RTCM nodes .
Joe K4SAT
areas.
do apply here.
de K0JSC
Today's Topics:
Message: 1
"correct" the
> modulation, [....]
S
Message: 2
months
S
Message: 3
Message-ID:
Hi Steve,
I'd post
perhaps
chip, yet. I
suitable
audio
that), an
to be
pretty
noise.
crystal
VCXO with
Si5351 will
like to
Do you
73, David KB4FXC
"correct" the
> > modulation, [....]
> S
Message: 4
Message-ID:
the RTCM
available to
GPSDO or does
Virus-free.
URL:
Message: 5
Message-ID:
Hi Joe,
converting
designed
TCXO
with an
73, David KB4FXC
with the RTCM
available to
GPSDO or does
> Virus-free.
Message: 6
Message-ID:
a OCXO
it any
enough.
Virus-free.
> Hi Joe,
converting
designed
be an
won't
decent TCXO
with an
> 73, David KB4FXC
with the
> RTCM
available
> to
GPSDO or
> does
myself?
> > Virus-free.
scroll down
message to
URL:
Joe Leikhim
Oviedo, Florida
407-982-0446
WWW.LEIKHIM.COM
