App_rpt-users Digest, Vol 83, Issue 43
Would removing R67 in the RTCM help?
Sent from my dumb-smart DROID…
app_rpt-users-request@ohnosec.org wrote:
Send App_rpt-users mailing list submissions to
app_rpt-users@ohnosec.org
To subscribe or unsubscribe via the World Wide Web, visit
ohnosec.org
or, via email, send a message with subject or body ‘help’ to
You can reach the person managing the list at
app_rpt-users-owner@ohnosec.org
When replying, please edit your Subject line so it is more specific
than “Re: Contents of App_rpt-users digest…”
Today’s Topics:
  1. Re: Garmin GPS18x no longer compatible with RTCM (Joe Bennett)
Message: 1
Date: Thu, 28 Jan 2016 20:01:20 -0600
To: app_rpt-users@ohnosec.org
Subject: Re: [App_rpt-users] Garmin GPS18x no longer compatible with
RTCM
Message-ID:
CAD+1-48xN03rzJQNaedmJ3qZ8u6Jg87Qvq8ot44jPHWRAvVRww@mail.gmail.com
Content-Type: text/plain; charset=UTF-8
I really doubt that a level converter will add enough timing skew to
amount to anything. The jitter you see on the internet will greatly
outweigh the skew of a level converter by orders of magnitude…
-Joe
KA3NAM
On Tue, Jan 26, 2016 at 1:44 PM, James Cizek james.m.cizek@gmail.com wrote:
Hi folks,
Wanted to get this out to you before anyone else bought one thinking they
would work (since this model is specifically called out in the RTCM docs).
When using a GPS with a Micro-node RTCM for voting, you need to find one
that has a 5 volt Pulse-per-second output. The Garmin lines that is
recommended (GPS 18X, 18X lvc, etc…)
NO LONGER do this!
This is what I got back from Garmin:
Mr. Cizek,
I was just told there was a design change with the GPS 18x LVC. The PPS
signal voltage is now 3V. This was something we were not told until today.
We will be making the changes to the online Technical Specifications to
reflect this change.
I do apologize for the inconvenience. This was a change we were not informed
of.
So this line of GPS’s will NOT work with an RTCM any longer. Talking to
Mark at Micro-node, there is a voltage divider in the RTCM dropping the 5
volt to 3.3 volt to be compatible with the CPU. With only 3 volts on the
incoming line, there isn’t enough making it to the CPU to trigger a state
change and you will get “PPS Timeout” errors and be unable to achieve GPS
lock.
I am not sure what kind of timing skew a level converter would introduce, so
it’s probably a better bet to just get a GPS that has a 5 volt line (Trimble
Thunderbolt or the similar).
There may be a possibility of removing or modifying the voltage divider
inside as well, but without schematics, and unless you have SMD capable
gear, it’s unlikely that that is a good solution.
Just wanted to let folks know so they don’t repeat the brain damage I just
went through figuring this out :slight_smile:
James
KI0KN
ohnosec.org
ohnosec.org and scroll down to
the bottom of the page. Enter your email address and press the “Unsubscribe
or edit options button”
End of App_rpt-users Digest, Vol 83, Issue 43
