App_rpt-users Digest, Vol 80, Issue 104
Yes please sign me up.
User: wb2ers
Password: wb2ers
I assume I can change the password once I have a login
Mark DuMoulin
WB2ERS
Wb2ers@metcom.com
C 800-410-3130
-----Original Message-----
From: app_rpt-users-bounces@ohnosec.org [mailto:app_rpt-users-bounces@ohnosec.org] On Behalf Of app_rpt-users-request@ohnosec.org
Sent: Thursday, October 29, 2015 8:38 PM
To: app_rpt-users@ohnosec.org
Subject: App_rpt-users Digest, Vol 80, Issue 104
Send App_rpt-users mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
  ohnosec.org
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
  app_rpt-users-owner@ohnosec.org
When replying, please edit your Subject line so it is more specific than "Re: Contents of App_rpt-users digest..."
Today's Topics:
   1. Re: DIAL Question (Corey Dean)
   2. Re: DIAL simpleusb (Tim Sawyer)
   3. Re: UIR Startup (Mark DuMoulin @ WB2ERS)
   4. Re: UIR Startup (Steve N4IRS)
   5. Re: AMBE question (Bryan Fields)
   6. Re: AMBE question (ronald simpson)
Message: 1
Date: Thu, 29 Oct 2015 12:18:58 -0400
To: David McGough <kb4fxc@inttek.net>
Cc: app_rpt-users@ohnosec.org
Subject: Re: [App_rpt-users] DIAL Question
Message-ID: <D3C84F7B-CF9A-4B21-A85C-E92319C8BEB3@repeater.net>
Content-Type: text/plain; charset=us-ascii
Yes! I ran it that way with an r100 for a few weeks before moving it over to the msf5000. I had no issues running simpleusb and usbradio. I don't have any of the cracks or pops anywhere that you are referring to running usbradio. I do know what you are talking about but I have never experienced that on any of my equipment.
Sent from my iPhone
On Oct 29, 2015, at 10:14 AM, David McGough <kb4fxc@inttek.net> wrote:
Has anyone tested the simpleusb driver with the RPi2 version of DIAL?
On Thu, 29 Oct 2015, Corey Dean wrote:
I thought I had replied to everyone and I noticed I only replied to Neil. I have been running the Debian rpi2 image for quite a while. Way back when Steve first created it. I run it in full duplex mode using usbradio on an msf5000 with no issues at all.
I know what you are talking about with the echo issue. That seems to just be a problem on the arch image on the hamvoip site as that is the only place I have heard it. I did try that image long and and having audio delays at almost 10 seconds and time just made it unusable. That was even using simpleusb. No problems running usbradio and dsp on the Debian image.
To make a long story short, the Debian image just works! No have had zero issues with it.
Corey N3FE
Sent from my iPhone
On Oct 29, 2015, at 8:46 AM, Jon Rorke <jrorke@cogeco.ca> wrote:
I have been playing with the full duplex mode using DSP decode (PL, carrier squelch) in and out on the RPI2 with DIAL and so far it seems to be on par with what Acid does on a PC.
There is some latency due to audio processing but its about 200 to 250 ms and seems to be stable. I have never seen an acid box with 0 latency on the full duplex audio.
In may opinion it woks just as well as an ACID set up on a pc for a single full duplex repeater node.
Can;t speak to the other questions though.
Jon VA3RQ
On 10/28/2015 5:48 PM, Neil k8it wrote:
I have been waiting a bit before I start playing with DIAL on a RPI2.
I still have two questions
1. Does the RPI2 DIAL version solve the tx echo buffer issue that the current version of Asterisk RPI2 code has. The fix to this issue seems to be taking a long time.
2. Some users have reorted that a lot of modules have been disabled, such as the Echolink channel driver and others.
3. With the new Mini-DV4 dongle $125 and the amount of
capability, has anybody wrote a channel driver to tie the Yaesu
Fusion Wires-X network into DIAL. It appears that most of the
documentation is out there, we just need someone to write the
channel driver
73 Neil Sablatzky K8IT
Allstar Node 41838 KITLINK
Allstar Node 42087 KITLINK HUB
IRLP Node exp0068
Echolink K8IT-L
WIRES-X K8IT 11479 Room 21479
Sent: Tuesday, October 27, 2015 10:35 AM
To: N7MTC . ; app_rpt-users@ohnosec.org
Subject: Re: [App_rpt-users] Procedure for loading DIAL on a R-Pi2
or a PC
Mac,
The RPi2 install is pretty much download the image, burn it to SD card,.
Once the Pi boots, you can login on the HDMI / USB console, or SSH into the board on port 222.
The board is setup for DHCP so check your DHCP (router) server for address.
If you want, you can login via the built in serial port at 115,200
System will walk you through setup.
FAQ for DIAL is at:
<AllStarLink Wiki;
73, Steve N4IRS
On 10/27/2015 10:20 AM, N7MTC . wrote:
Is there a procedure for loading the "new" DIAL version of asterisk for Raspberry pi2?
I am looking to connect either a Pi2 or an intel NUC to a Yaesu Dr-1x using the Arcom RC-210 and the Arcom ADR. I noticed DIAL has replaced ACID as the latest flavor of asterisk for both PC and PI2. I have not found any install write-ups or YouTubes showing a DIAL install.
Regardless of which platform I will need to use an USB to Serial adapter to connect the ALLSTAR node to the repeater controller. It will be of the FTDI chipset either a trendnet Tu-s9 or a GearMo USB RS-232.
/73
Mac, N7MTC
Benjamin Franklin - "Those who surrender freedom for security will not have, nor do they deserve, either one."
ohnosec.org
To unsubscribe from this list please visit ohnosec.org and scroll down to the bottom of the page. Enter your email address and press the "Unsubscribe or edit options button"
ohnosec.org
No virus found in this message.
Checked by AVG - www.avg.com
Version: 2015.0.6173 / Virus Database: 4455/10900 - Release Date:
10/27/15
ohnosec.org
ohnosec.org
Message: 2
Date: Thu, 29 Oct 2015 10:25:28 -0700
To: Steve N4IRS <szingman@msgstor.com>
Cc: "app_rpt-users@ohnosec.org" <app_rpt-users@ohnosec.org>
Subject: Re: [App_rpt-users] DIAL simpleusb
Message-ID:
  <CAG3ht9uW80TNGu9BGZghqGg3FozagJ_dmrwJFA3Ygo5XjzmhAg@mail.gmail.com>
Content-Type: text/plain; charset="utf-8"
Working fine including GPIO.
On Thursday, October 29, 2015, Steve N4IRS <szingman@msgstor.com> wrote:
Yes,
No errors reported.
        (o o)
-----ooO-(_)-Ooo------
--- N4IRS was Here ---
ohnosec.org
confirmation. If you have trouble unsubscribing, please send a message
to the list detailing the problem.
Tim
-------------- next part --------------
An HTML attachment was scrubbed...
URL: <http://ohnosec.org/pipermail/app_rpt-users/attachments/20151029/50ce6e1d/attachment-0001.html&gt;
Message: 3
Date: Thu, 29 Oct 2015 17:46:39 +0000
To: 'Ken' <ke2n@cs.com>, "app_rpt-users@ohnosec.org"
  <app_rpt-users@ohnosec.org>, "Mark DuMoulin @ WB2ERS"
  <wb2ers@metcom.com>
Subject: Re: [App_rpt-users] UIR Startup
Message-ID: <da574ffa2fe54879aae2b807a84a2545@MAIL2.metcom.com>
Content-Type: text/plain; charset="us-ascii"
Ken,
Sorry, typo on my side about pin 21 and I just rang out the cable anyway.
I have an IAX client connected to Asterisk where I currently have the signaling and audio path IAX - Asterisk - Radio functioning properly.
The opposite path Radio - Asterisk - IAX is not functioning.
CTCSS (URI pin 7) goes from the pulled up 5 volts to 0 when the radio is receiving signal.
I'm assuming that signaling is present through Asterisk as I get a brief upscale indication on the IAX SPK bargraph and I get a caller ID from the URI node when the receiver receives a properly tone coded signal.
There is no audio being routed through to IAX. This is the issue.
Note: IAX works fine with other node types such as radio-gui, radio-gui-cell and radio-phone.
URI DB-25 pin
1. goes to the Radio PTT
7. goes to the CTCSS Detect from the radio and I have a 18k pullup attached to +5 at 14 20. goes to radio Gnd 21. goes to Radio Receive Audio out. This is no greater than 0 dbm.
22. goes to the radio flat Transmit Audio in.
We have flashing green indicating app_rpt application is running.
Any ideas?
Mark DuMoulin
WB2ERS
Wb2ers@metcom.com
C 800-410-3130
Sent: Thursday, October 29, 2015 11:01 AM
To: app_rpt-users@ohnosec.org; Mark DuMoulin @ WB2ERS <wb2ers@metcom.com>
Cc: 'Steve Zingman' <szingman@msgstor.com>
Subject: UIR Startup
Also noticed "I have the receiver audio connected to pin 22 Left_Out."
Receive audio goes to mic in pin 9.
Actually - it should normally go to pin 21 "mic AC".
This has an attenuator in line.
It is possible to burn out the chip if you go direct to pin 9 and overdrive it.
GL
Ken
Message: 4
Date: Thu, 29 Oct 2015 13:47:00 -0400
To: "\"Mark DuMoulin\"@WB2ERS" <wb2ers@metcom.com>, 'Ken'
  <ke2n@cs.com>, "app_rpt-users@ohnosec.org" <app_rpt-users@ohnosec.org>
Message-ID: <56325B94.8070204@msgstor.com>
Content-Type: text/plain; charset=windows-1252; format=flowed
Comment out the rxctcssfreqs line. in usbradio.conf
On 10/29/2015 1:46 PM, Mark DuMoulin @ WB2ERS wrote:
Ken,
URI DB-25 pin
Any ideas?
Mark DuMoulin
WB2ERS
Wb2ers@metcom.com
C 800-410-3130
<wb2ers@metcom.com>
GL
Ken
Message: 5
Date: Thu, 29 Oct 2015 14:41:16 -0400
To: APP RPT <app_rpt-users@ohnosec.org>
Subject: Re: [App_rpt-users] AMBE question
Message-ID: <5632684C.8080706@bryanfields.net>
On 10/29/15 11:25 AM, Robert Newberry wrote:
This topic could be another e-mail list.
Why?
This is where allstar has it nailed
being able to link multiple audio paths. We have someone using dstar
on our system it sounds pretty decent. I'd like to see p25 and DMR
included. I'll stop posting on this as well and keep it last for this list.
I would like to see asterisk being the common platform used for internet linking of any radio systems. It decouples the network from the technology.
Course this does remove the network operators from the god like status they have and the ensuing circle-jerk :slight_smile:
Bryan Fields
727-409-1194 - Voice
727-214-2508 - Fax
http://bryanfields.net
Message: 6
Date: Thu, 29 Oct 2015 17:37:49 -0700
To: Steve Zingman <szingman@msgstor.com>
Cc: App RPT Users <app_rpt-users@ohnosec.org>
Message-ID:
  <CANr-_9rhZ9EXMOFaXZ9XX2Hk8CtmqcRd6=yncKqpdV9Xa4+x+g@mail.gmail.com>
I have a considerable investment into Fusion. I will support this effort in any way I can. I ordered one of the dongles that does Fusion, Dstar and DMR. I saw the YouTube video of the demonstration about this dongle in the Fusion mode.
I see alot of potential here in this group
Ron
N6GKJ
On Oct 29, 2015 6:47 AM, "Steve N4IRS" <szingman@msgstor.com> wrote:
When we did the DMR to AllStar testing, we used the NW Digital Radio
DV3000. It was mounted on a RPi2 running asterisk.
The DV3000 uses AMBE-3000 vocoder chip from DVSI. We tested with
Mototrbo and D-Star. Did not have a Fusion or P25 radios.
73, Steve N4IRS
On 10/29/2015 8:03 AM, David McGough wrote:
Guys,
I haven't looked carefully as to which variants of AMBE are in use by
D-STAR, Fusion, etc...Doesn't the original AMBE patent expire fairly soon?
The reason I'm asking is that I know there are some fledgling
open-source AMBE implementations out there. A couple years ago I
hacked CODEC2 into Asterisk for experimentation, thinking about
directly linking to HF via the FreeDV project--and, not wanting to
transcode from one low-bandwidth CODEC to another, making truly awful audio!
After playing with it a few weeks, I didn't do much more...(I've
still got that code and it still works, if anyone wants to play with
it?)
...Just wondering.
73, David KB4FXC
On Thu, 29 Oct 2015, Matthew Pitts wrote:
Mike,
You are correct in the statement that the DV4mini needs additional
hardware to handle the transcoding from a digital radio. Once I get
my nodes back up on my Raspberry Pi, I will work on an updated
version of the D-STAR channel driver that supports DMR and Fusion
AMBE encoding and decoding as well as radio control functionality for the DV4mini.
Matthew Pitts
N8OHU
On October 28, 2015 6:18:34 PM EDT, Mike Zingman >>> <mike.zingman@gmail.com> >>> wrote:
Actually the DV4Mini alone does not help tie Allstar into Wires-X.
In order to do that one must:
1) Have an interface to the YSF network protocol
2) Decode and extract the AMBE frames from the streamed protocol
3) Transcode the frames to PCM at the proper sample rate using the
DVSI
AMBE3000 chipset
4) Send those frames to something like the already created USRP
channel driver
In reverse, 4, 3, 2, 1 to send data back to the YSF network. In
addition to the simple outline above, you would want to
a) Add audio filtering/shaping to make the AMBE audio more
acceptable to what we are used to on Allstar (one of the single
greatest aspects of Allstar is the audio quality)
b) Transfer of as much metadata between the networks as possible
The DV4Mini is a radio module + digital modulator (DStar/DMR/YSF).
It has no AMBE encode/decode hardware so there is no way to
transcode the audio content. For that a "ThumbDV" or a DV3000
would be the hardware of choice. The DV4Mini could be used as a
user radio on an existing RF network, but one would still need the
AMBE3K to do the transcode.
Mike
the
seems to
disabled,
such
capability,
has
anybody wrote a channel driver to tie the Yaesu Fusion Wires-X
network into
DIAL. It appears that most of the documentation is out there, we
just
need
someone to write the channel driver
IRLP Node exp0068
Echolink K8IT-L
*Sent:* Tuesday, October 27, 2015 10:35 AM
*To:* N7MTC . <n7mtc@outlook.com> ; app_rpt-users@ohnosec.org
*Subject:* Re: [App_rpt-users] Procedure for loading DIAL on a
R-Pi2
or a
PC
Mac,
card,.
into
address.
FAQ for DIAL is at:
<AllStarLink Wiki;
<AllStarLink Wiki;
73, Steve N4IRS
asterisk
for
Raspberry pi2?
has
replaced
not
adapter
be
of
/73
Mac, N7MTC
not
listApp_rpt-users@ohnosec.orghttp://
ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users
ohnosec.org and
message to the list detailing the problem.
ohnosec.org
ohnosec.org and
scroll
down
message to
10/27/15
ohnosec.org
ohnosec.org and
scroll
down
message to
ohnosec.org
ohnosec.org and
ohnosec.org
ohnosec.org
URL: <http://ohnosec.org/pipermail/app_rpt-users/attachments/20151029/1df294a8/attachment.html&gt;
End of App_rpt-users Digest, Vol 80, Issue 104
