I just opened up a couple USB fobs I got from geeks.com.
They were sold as cm108. Look identical and had the same
part number as before… they are not cm108’s. they show up as
USB HD audio. really generic info. the chip was ground off so
you can’t see the actual numbers.
part number as before.. they are not cm108's. they show up as
you can't see the actual numbers.
Hi Dave, I agree the Startech FOBS are great... they even have pads to
mount the EEPROM that the URI has... the only thing I did not like about
them... (and it is fixable) is... the FOB does not have the LED and Current
limiting resister connected to the line that goes into blinky mode when
asterisk is up and running therefore indicating the fob is operational. I
am modifying a bunch of them to include the LED (there are pads for SMD)
'73,
Roger W4RFJ
-----Original Message-----
[mailto:app_rpt-bounces@lists.illiana.net] On Behalf Of David McGough
Sent: Friday, August 01, 2008 10:57 PM
To: Asterisk Repeater Controler
Subject: Re: [App_rpt] USB fobs
I got several startech usb audio adapters. They are cm108's and work
well--so far! ....But, may be a little more pricey than some alternatives.
just fyi...
Don
W9DRR
_________________________________________________________________
Stay in touch when you're away with Windows Live Messenger.
