Jim Dixon and I have had disapointing results with USB hubs during the testing of USB fobs with them. We don't know why they don't work properly and we don't have the time to figure it out right now. There may be hubs which work just fine, but we just don't know as the root cause of the problem has not been uncovered. If Steve Henke W9SH knows something I don't them maybe he should speak up on the list.
Steve
WA6ZFT
Date: 2008/07/22 Tue AM 07:49:30 PDT
To: Asterisk Repeater Controler <app_rpt@lists.illiana.net>
Subject: Re: [App_rpt] URI configuration help
Why can there be no USB Hubs?
I have two systems in development right now that will both require
hubs to gain enough ports.
The adding one at a time and keeping them in the same location is the
reason to use the URI's and add eeproms. Has anybody actually
utilized the eprom functions using a URI and Asterisk?
Mark,
KC5EVE
At 08:50 PM 7/21/2008, you wrote:
>David,
>First off, I just learned something myself about adding extra radio
>ports using USB fobs: They must be added one at a time.
>Second, there should be no USB hubs between the FOB's and the PC's USB
>ports.
>Finally, what type if linux install is this? ACID, EVB, custom?
>I'd suggest restoring the configuration back to one radio port get that
>working, then add and tune the ports one at a time.
>Steve,
>WA6ZFT
>David McGough wrote:
> > Hi Roger & Steve,
> > Well, I'm making progress. I've noticed a couple more things I thought I'd
> > mention. First, I've got a strange situation where I can only properly
> > access 2 of the 3 URI's I have attached to the PC....Initially, I only
> > plugged 1 URI in and couldn't get it to work at all (though the green LED
> > was blinking)....Then, when I plugged in a 2nd URI, the first started
> > working (with my TKR-850)....Today, I found that the second wasn't
> > functional....So, tonight, experimentally, I plugged in a 3rd URI and
> > both of the original 2 are now working. Strange.....Perhaps this has
> > something to do with udev? Anyway, this isn't holding me up at the moment.
> > The second issue is more troublesome. I can't get the repeater to link to
> > the remote base....When I issue the connect command: *2(node number), the
> > controller says it's linking both on the console and verbally. But, then
> > it seems to hang totally with the TX enabled from the end that received
> > the commands. I've tried this both ways--repeater to remote base (commands
> > from the repeater) and vice versa. I end up having to kill -9 the asterisk
> > process to regain control--"stop now" from the asterisk console
> > hangs...This should work, right?
> > Thanks in advance!
> > David KB4FXC
> > On Sun, 20 Jul 2008, David McGough wrote:
> >> Hi Steve and Roger,
> >> Thanks so much for the assistance. I'll give it a try today and report
> >> back. I think most of my questions are now answered.
> >> <snip>
> > _______________________________________________
> > App_rpt mailing list
> > App_rpt@lists.illiana.net
> > http://lists.illiana.net/mailman/listinfo/app_rpt
I remember a few years ago when I bought my first iMic to interface with Apple's iBook that didn't have a microphone... At that time they actually qualified certain USB hubs as audio compliant. I'm not sure if they still do that or not, but there was (and likely still is?) a huge disparity in performance and it seems like audio was more severely affected than less noticeable hiccups in the data transfer rate on a hard drive or something.
Just my $0.02.
Steve - N9YTY
On Jul 22, 2008, at 2:07 PM, <hwstar@rodgers.sdcoxmail.com> <hwstar@rodgers.sdcoxmail.com > wrote:
Steve
WA6ZFT
Mark,
KC5EVE
David,
ports.
Steve,
WA6ZFT
Hi Roger & Steve,
Thanks in advance!
David KB4FXC
Hi Steve and Roger,
