[App_rpt] URI configuration help
Hi Steve and Roger,
Thanks so much for the assistance. I'll give it a try today and report
back. I think most of my questions are now answered.
One thing I've noticed--it's not a big deal, and easily enough to overcome
by just using a sampled sound file--is that the CW ID timing generation
seems a little random. Has anyone else noticed this? I suspect this may be
an artifact of my Linux kernel and/or hardware config...I'm using the
easyvoxbox distro base, with hand compiled new versions of asterisk,
app_rpt and supporting tools. BTW, I'm using an Dual-core AMD64 4400+ CPU
and 3ware Raid 1....I'll investigate this more later-
Thanks again!
David KB4FXC
On Sun, 20 Jul 2008, Roger F. Jordan Sr. wrote:
Below are examples of MY SETUP as assisted by W9SH
I removed the Functions but notice the phone functions use two different
function lists for Phonepatch... They are not included for security
reasons...
<snip>
We are painfully aware of this problem. The ID will suddenly shift speed
right in the middle of identifying. It is on the list to be
investigated. We think it is either a change to something in the kernel,
or core asterisk, but we don't know for sure which yet.
Steve
WA6ZFT
David McGough wrote:
Hi Steve and Roger,
Thanks again!
David KB4FXC
reasons...
<snip>
App_rpt mailing list
App_rpt@lists.illiana.net
Hi Roger & Steve,
Well, I'm making progress. I've noticed a couple more things I thought I'd
mention. First, I've got a strange situation where I can only properly
access 2 of the 3 URI's I have attached to the PC....Initially, I only
plugged 1 URI in and couldn't get it to work at all (though the green LED
was blinking)....Then, when I plugged in a 2nd URI, the first started
working (with my TKR-850)....Today, I found that the second wasn't
functional....So, tonight, experimentally, I plugged in a 3rd URI and
both of the original 2 are now working. Strange.....Perhaps this has
something to do with udev? Anyway, this isn't holding me up at the moment.
The second issue is more troublesome. I can't get the repeater to link to
the remote base....When I issue the connect command: *2(node number), the
controller says it's linking both on the console and verbally. But, then
it seems to hang totally with the TX enabled from the end that received
the commands. I've tried this both ways--repeater to remote base (commands
from the repeater) and vice versa. I end up having to kill -9 the asterisk
process to regain control--"stop now" from the asterisk console
hangs...This should work, right?
Thanks in advance!
David KB4FXC
On Sun, 20 Jul 2008, David McGough wrote:
Hi Steve and Roger,
<snip>
Oops....In my previous message I meant to say I'm using the command:
*3(node number) to connect....See the functions table I'm using, below.
73, David KB4FXC
; function table
[functions]
1=ilink,1 ; Specific link disconnect
2=ilink,2 ; Specific Link connect - monitor only
3=ilink,3 ; Specific Link connect - transceive
4=ilink,4 ; Enter command mode on a specific link
7=ilink,5 ; Link status
80=status,1 ; System info
81=status,2 ; Time
82=status,3 ; app_rpt.c Version
87=ilink,15 ; long range sensors
;6=autopatchup,noct=1,farenddisconnect=1,dialtime=20000 ; Autopatch up
;0=autopatchdn ; Autopatch down
99=cop,4 ; Test tone
98=cop,6 ; Phone TX key
David,
First off, I just learned something myself about adding extra radio
ports using USB fobs: They must be added one at a time.
Second, there should be no USB hubs between the FOB's and the PC's USB
ports.
Finally, what type if linux install is this? ACID, EVB, custom?
I'd suggest restoring the configuration back to one radio port get that
working, then add and tune the ports one at a time.
Steve,
WA6ZFT
Hi Roger & Steve,
Thanks in advance!
David KB4FXC
Hi Steve and Roger,
<snip>
Hi Steve,
I am running a EVB base system--centos 5 and 2.6.18-53.1.21.el5 kernel. I
updated asterisk to a hand-compiled version (1.4.21) using the latest
app_rpt and chan_usb code from Xelatek's SVN....Maybe I'll back down to
the ACID release.
The URI's are plugged directly into the PC, and 2 of the 3 seem to be
working fine--other than I can't connect the extensions together. The
TKR-850 (set internally in duplex mode and is asterisk extension 111)
works as a repeater, and accepts DTMF commands, etc....And, the remote
base (currently a IC-706mk2g, extension 222) also accepts DTMF commands,
etc....But, when I try to connect these units (using *3<node>), I get a
lock up....
I reduced my extensions.conf file to the below for testing:
---------------extensions.conf---------------------------------------
[general]
static=yes ; These two lines prevent the command-line interface
writeprotect=yes ; from overwriting the config file. Leave them here.
[radio-secure]
exten => 111,1,rpt,111
exten => 222,1,rpt,222
[autopatch]
And, here is my rpt.conf:
---------------rpt.conf---------------------------------------------
; Radio Repeater configuration file (for use with app_rpt)
[111] ; Change this to your assigned node number
rxchannel = Radio/usb ; Rx audio/signalling channel
controlstates=controlstates ; system control state list
scheduler=schedule; ; scheduler entries
functions=functions ; Repeater Function Table
phone_functions=functions ; Repeater Function Table
link_functions=link-functions ; Link Function Table
telemetry=telemetry ; Telemetry descriptions
wait_times=wait-times ; Wait times
context = autopatch ; dialing context for phone
callerid = "Repeater" <0000000000> ; callerid for phone calls
;idrecording = |iid ; id recording or morse string
idrecording=|ikb4fxc/r ; id recording or morse string
accountcode=RADIO ; account code (optional)
hangtime=1000 ; squelch tail hang time (in ms)
(optional)
althangtime=4000 ; longer squelch tail
totime=170000 ; transmit time-out time (in ms)
(optional)
totime=10000
idtime=540000 ; id interval time (in ms)
(optional)
; The default values for hangtime, time-out time, and id interval time are
; 5 seconds (5000 ms), 3 minutes (180000 ms), and 5 minutes (300000 ms)
; respectively
politeid=30000 ; time in milliseconds before ID
timer
                                        ; expires to try and ID in the
tail.
                                        ; (optional, default is 30000).
idtalkover=|iid ; Talkover ID (optional) default
is none
unlinkedct=ct2 ; unlinked courtesy tone
(optional) default is none
remotect=ct3
duplex=2
[222] ; Change this to your assigned node number
rxchannel = Radio/usb1 ; Rx audio/signalling channel
;idrecording=|ikb4fxc ; id recording or morse string
(optional)
(optional)
totime=10000
(optional)
; respectively
politeid=30000 ; time in milliseconds before ID timer
                                        ; expires to try and ID in the tail.
idtalkover=|iid ; Talkover ID (optional) default is none
unlinkedct=ct2 ; unlinked courtesy tone (optional) default is none
remotect=ct3
duplex=0
; function table
[functions]
only
81=status,2 ; Time
; Link function table
; If this section is defined, then the remote user accessing our machine
in command mode
; will only be able to do the functions defined in this section. If this
section is
; omitted, then the link functions will be the same as the repeater
functions.
[link-functions]
only
transceive
4=ilink,4 ; Command mode
81=status,2 ; Time
;6=autopatchup,farenddisconnect=1,noct=1,dialtime=20000 ; Autopatch up
[telemetry]
; Telemetry entries can be shared across all repeaters, or defined for
each repeater.
; Can be a tone sequence, morse string, or a file
; |t - Tone escape sequence
; Tone sequences consist of 1 or more 4-tuple entries (freq1, freq2,
duration, amplitude)
; Single frequencies are created by setting freq1 or freq2 to zero.
; |m - Morse escape sequence
; Sends Morse code at the telemetry amplitude and telemetry frequency as
defined in the
; [morse] section.
; Follow with an alphanumeric string
; |i - Morse ID escape sequence
; Sends Morse code at the ID amplitude and ID frequency as defined in the
; [morse] section.
ct1=|t(350,0,100,2048)(500,0,100,2048)(660,0,100,2048)
ct2=|t(660,880,150,2048)
ct3=|t(440,0,150,4096)
ct4=|t(550,0,150,2048)
ct5=|t(660,0,150,2048)
ct6=|t(880,0,150,2048)
ct7=|t(660,440,150,2048)
ct8=|t(700,1100,150,2048)
remotetx=|t(1633,0,50,3000)(0,0,80,0)(1209,0,50,3000);
remotemon=|t(1209,0,50,2048)
cmdmode=|t(900,903,200,2048)
functcomplete=|t(1000,0,100,2048)(0,0,100,0)(1000,0,100,2048)
patchup=rpt/callproceeding
patchdown=rpt/callterminated
;idstr=|m('K','B','4','F','X','C')
; Morse code parameters, these are common to all repeaters.
[morse]
speed=13 ; Approximate speed in WPM
frequency=800 ; Morse Telemetry Frequency
amplitude=4096 ; Morse Telemetry Amplitude
idfrequency=1065 ; Morse ID Frequency
idamplitude=1024 ; Morse ID Amplitude
; A section for wait times can be defined for every repeater
[wait-times]
telemwait=2000 ; Time to wait before sending most telemetry
idwait=500 ; Time to wait before starting ID
unkeywait=2000 ; Time to wait after unkey before sending CT's and link telemetry
calltermwait=2000 ; Time to wait before announcing "call terminated"
; This is where you define your nodes which can be connected to.
[nodes]
111 = radio@127.0.0.1/111,NONE ; Change this to your assigned node number
222 = radio@127.0.0.1/222,NONE ; Change this to your assigned node number
Finally, here is the usbradio.conf:
; Open Sound System Console Driver Configuration File
[general]
rxcpusaver=0
txcpusaver=0
debug=0x7
[usb]
; TKR-850
devicenum=0
hdwtype=0 ; Leave this set to 0 for USB sound fobs modified
using
                        ; the instructions from usbfob.pdf. Use a setting
of
rxboost=0 ; 0 = 20db attenuator inserted, 1= 20db attenuator
removed
                        ; Set to 1 for additonal gain if using a low-level
receiver output
rxctcssrelax=1 ; reduce talkoff from radios w/o CTCSS Tx HPF
txctcssdefault=0.0 ; default tx ctcss freq, any frequency permitted
rxctcssfreqs=0.0 ; rx ctcss freqs in floating point. must be in
table
txctcssfreqs=0.0 ; tx ctcss freqs, any frequency permitted
carrierfrom=usbinvert ; no,usb,usbinvert,dsp,vox
                        ; usb - from the COR line on the modified USB
sound fob
                        ; usbinvert - from the inverted COR line on the
modified USB sound fob
                        ; dsp - from RX noise using dsp techniques
                        ; vox - voice activated from RX audio
ctcssfrom=no ; no,usb,dsp
                        ; no - CTCSS decoding, system will be carrier
squelch
                        ; usb - CTCSS decoding using input from USB FOB
                        ; (currently not supported)
                        ; dsp - CTCSS decoding using RX audio in DSP.
                        ; rxdemod option must be set to flat for this to
work.
rxdemod=speaker ; input type from radio: no,speaker,flat
                        ; flat - Use RX audio from discriminator
txprelim=no ; Audio processing on left output channel: no,yes
                        ; no - Audio is not pre-emphasized and limited.
                        ; Suitable for use on a microphone input
                        ; yes - Audio is pre-emphasized and limited.
                        ; Suitable for direct connection to an FM
modulator
txtoctype=notone ; Transmit tone control type: no,phase,notone
                        ; phase - encode CTCSS and reverse phase
                        ; AKA ("reverse burst") before unkeying TX
                        ; notone - encode CTCSS and stop sending tone
before unkeying TX
                        ; AKA ("chicken burst")
txmixa=voice ; Left channel output:
no,voice,tone,composite,auxvoice
                        ; no - Do not output anything
                        ; voice - output voice only
                        ; tone - CTCSS tone only
                        ; composite - voice and tone
                        ; auxvoice - auxiliary voice output at headphone
level for monitoring
txmixb=no ; Right channel output: no,voice,tone,composite,
auxvoice
                        ; See txmixa above.
invertptt=0 ; Invert PTT 0 = ground to transmit, 1 = open to
transmit
                        ; This is the collector lead of the 2n4401 on the
modified
                        ; usb sound fob.
                        ; please refer to the howto for the procedure to
do this.
duplex=1 ; Full Duplex
[usb1]
; IC-706mk2g
devicenum=1
hdwtype=0
rxboost=0
rxctcssrelax=1
txctcssdefault=0.0
rxctcssfreqs=0.0
txctcssfreqs=0.0
auxvoice
transmit
duplex=0 ; Simplex
On Mon, 21 Jul 2008, Stephen Rodgers wrote:
David,
ports.
Steve,
WA6ZFT
> Hi Roger & Steve,
> Thanks in advance!
> David KB4FXC
>> Hi Steve and Roger,
>> <snip>
David,
Using the latest version of Asterisk may be the cause of your problems.
Why did you feel the need to upgrade it from what comes with EVB?
Troubleshooting the lockup on an unproven system configuration will be a
complete waste of your time if you aren't a developer and able to fix
things yourself in the code and are willing to spend hours and hours
tracking down the root cause of the problem. If you want to get
something running quickly, you have to resist the urge to update code to
the latest and greatest and stick to that which has a track record of
working.
There are several people running plain vanilla multi-node EVB systems
(Roger W4RFJ and Will W4WWM). I'm running a two node ACID system on the
bench but it doesn't have all that much test time on it. (It doesn't
lock up when the two nodes are connected together though.) There is one
other person running ACID on a two node system (Randy KC6HUR) he might
be able to give some insight as to how well it works.
This is one of the few problems with open source, you just don't know in
advance which combinations of programs will play nice together without
doing extensive testing yourself and troubleshooting the problems
yourself. This is why EVB and ACID exist. There are just to many things
which can go terribly wrong when programs are updated to the latest and
greatest versions.
Steve
Hi Steve,
the ACID release.
lock up....
[general]
[radio-secure]
[autopatch]
(optional)
(optional)
totime=10000
(optional)
; respectively
timer
tail.
is none
remotect=ct3
duplex=2
(optional)
(optional)
totime=10000
(optional)
; respectively
remotect=ct3
duplex=0
; function table
[functions]
only
81=status,2 ; Time
in command mode
section is
functions.
[link-functions]
only
transceive
81=status,2 ; Time
[telemetry]
each repeater.
defined in the
; [morse] section.
; [morse] section.
[morse]
[wait-times]
[nodes]
[general]
rxcpusaver=0
txcpusaver=0
debug=0x7
[usb]
; TKR-850
devicenum=0
using
of
removed
receiver output
table
sound fob
squelch
work.
modulator
before unkeying TX
auxvoice
                        ; See txmixa above.
transmit
modified
                        ; usb sound fob.
do this.
[usb1]
; IC-706mk2g
devicenum=1
hdwtype=0
rxboost=0
rxctcssrelax=1
txctcssdefault=0.0
rxctcssfreqs=0.0
txctcssfreqs=0.0
auxvoice
transmit
duplex=0 ; Simplex
David,
ports.
Steve,
WA6ZFT
Hi Roger & Steve,
Thanks in advance!
David KB4FXC
Hi Steve and Roger,
<snip>
Hi Steve,
I guess I'm a glutton for punishment! I'm a systems programmer/developer
and in the past haven't had much trouble with hand-compiling versions of
asterisk....But, I know exactly what you're talking about!
The main reason I compiled it was to include the iLBC CODEC, etc.,--which
I have previously used exclusively for Internet-based links on our office
asterisk PBXs....I figured this would give me my best connectivity option
from the road with the laptop.
But, for the moment, I'll back down to the ACID release and give it a try.
Thanks so much for all your help!
73, David KB4FXC
David,
working.
greatest versions.
Steve
> Hi Steve,
> the ACID release.
> lock up....
> [general]
> [radio-secure]
> [autopatch]
> (optional)
> (optional)
> totime=10000
> (optional)
> ; respectively
> timer
> tail.
> is none
> remotect=ct3
> duplex=2
> (optional)
> (optional)
> totime=10000
> (optional)
> ; respectively
> remotect=ct3
> duplex=0
> ; function table
> [functions]
> only
> 81=status,2 ; Time
> in command mode
> section is
> functions.
> [link-functions]
> only
> transceive
> 81=status,2 ; Time
> [telemetry]
> each repeater.
> defined in the
> ; [morse] section.
> ; [morse] section.
> [morse]
> [wait-times]
> [nodes]
> [general]
> rxcpusaver=0
> txcpusaver=0
> debug=0x7
> [usb]
> ; TKR-850
> devicenum=0
> using
> of
> removed
> receiver output
> table
> sound fob
> squelch
> work.
> modulator
> before unkeying TX
> auxvoice
> ; See txmixa above.
> transmit
> modified
> ; usb sound fob.
> do this.
> [usb1]
> ; IC-706mk2g
> devicenum=1
> hdwtype=0
> rxboost=0
> rxctcssrelax=1
> txctcssdefault=0.0
> rxctcssfreqs=0.0
> txctcssfreqs=0.0
> auxvoice
> transmit
> duplex=0 ; Simplex
>> David,
>> ports.
>> Steve,
>> WA6ZFT
>>> Hi Roger & Steve,
>>> Thanks in advance!
>>> David KB4FXC
>>>> Hi Steve and Roger,
>>>> <snip>
David,
One thing I forgot to mention after I looked over your configs.
1. You mentioned the second radio was a remote base. You should have a
,y on the end of a remote base node like this:
222 = radio@127.0.0.1/222,NONE,y ; Change this to your assigned node number
2. As a starting point, a remote base node should have a node stanza
which looks like this:
[222]
;devicenum=1 ; Not necessary, remove. Device
          ; automatically assigned.
rxchannel = radio/usb1 ; Rx audio/signalling channel
remote = ic706
functions = remote-functions
phone_functions = remote-functions
ioport = /dev/ttyS0 ; Specify port for serial port
civaddr = 88 ; Specify CIV address for IC706
And a function list like this:
[remote-functions]
0=remote,1 ; Retrieve Memory
1=remote,2 ; Set freq.
2=remote,3 ; Set tx PL tone
3=remote,4 ; Set rx PL tone
40=remote,100 ; Rx PL off
41=remote,101 ; Rx PL on
42=remote,102 ; Tx PL off
43=remote,103 ; Tx PL on
44=remote,104 ; Low Power
45=remote,105 ; Medium Power
46=remote,106 ; High Power
711=remote,107 ; Bump -20
714=remote,108 ; Bump -100
717=remote,109 ; Bump -500
713=remote,110 ; Bump +20
716=remote,111 ; Bump +100
719=remote,112 ; Bump +500
721=remote,113 ; Scan - slow
724=remote,114 ; Scan - quick
727=remote,115 ; Scan - fast
723=remote,116 ; Scan + slow
726=remote,117 ; Scan + quick
729=remote,118 ; Scan + fast
79=remote,119 ; Tune
51=remote,5 ; Long status query
52=remote,140 ; Short status query
6=remote,6 ; Set mode
98=cop,6
Steve
WA6ZFT
Hi Steve,
73, David KB4FXC
David,
working.
greatest versions.
Steve
Hi Steve,
the ACID release.
lock up....
[general]
[radio-secure]
[autopatch]
(optional)
(optional)
totime=10000
(optional)
; respectively
timer
tail.
is none
remotect=ct3
duplex=2
(optional)
(optional)
totime=10000
(optional)
; respectively
remotect=ct3
duplex=0
; function table
[functions]
only
81=status,2 ; Time
in command mode
section is
functions.
[link-functions]
only
transceive
81=status,2 ; Time
[telemetry]
each repeater.
defined in the
; [morse] section.
; [morse] section.
[morse]
[wait-times]
[nodes]
[general]
rxcpusaver=0
txcpusaver=0
debug=0x7
[usb]
; TKR-850
devicenum=0
using
of
removed
receiver output
table
sound fob
squelch
work.
modulator
before unkeying TX
auxvoice
                        ; See txmixa above.
transmit
modified
                        ; usb sound fob.
do this.
[usb1]
; IC-706mk2g
devicenum=1
hdwtype=0
rxboost=0
rxctcssrelax=1
txctcssdefault=0.0
rxctcssfreqs=0.0
txctcssfreqs=0.0
auxvoice
transmit
duplex=0 ; Simplex
David,
ports.
Steve,
WA6ZFT
Hi Roger & Steve,
Thanks in advance!
David KB4FXC
Hi Steve and Roger,
<snip>
Why can there be no USB Hubs?
I have two systems in development right now that will both require hubs to gain enough ports.
The adding one at a time and keeping them in the same location is the reason to use the URI's and add eeproms. Has anybody actually utilized the eprom functions using a URI and Asterisk?
Mark,
KC5EVE
At 08:50 PM 7/21/2008, you wrote:
David,
ports.
Steve,
WA6ZFT
> Hi Roger & Steve,
> Thanks in advance!
> David KB4FXC
>> Hi Steve and Roger,
>> <snip>
I totally disagree.
The new app-rpt should be merged with trunk and also be compatible
with new kernels and updated software. That is a basic fact of almost
EVERY piece of software. Sometimes you have to read the README to get
it working but that's it.
Do you know what most of those updates are? Mostly security fixes and
bug fixes.
To suggest leaving a system without updating it is just terrible
advice and begging to be hacked.
Steve Totaro
KB3OPB
On Mon, Jul 21, 2008 at 11:07 PM, Stephen Rodgers <hwstar@rodgers.sdcoxmail.com> wrote:
David,
working.
greatest versions.
Steve
Mark,
I can help you with the hubs.
Contact me at sph@xelatec.com.
73,
Steve Henke
reason to use the URI’s and add eeproms. Has anybody actually
Mark,
KC5EVE
David,
Second, there should be no USB hubs between the FOB’s and the PC’s USB
ports.
I’d suggest restoring the configuration back to one radio port get that
Steve,
WA6ZFT
Hi Roger & Steve,
Well, I’m making progress. I’ve noticed a couple more things I thought I’d
mention. First, I’ve got a strange situation where I can only properly
access 2 of the 3 URI’s I have attached to the PC…Initially, I only
plugged 1 URI in and couldn’t get it to work at all (though the green LED
was blinking)…Then, when I plugged in a 2nd URI, the first started
working (with my TKR-850)…Today, I found that the second wasn’t
functional…So, tonight, experimentally, I plugged in a 3rd URI and
both of the original 2 are now working. Strange…Perhaps this has
something to do with udev? Anyway, this isn’t holding me up at the moment.
The second issue is more troublesome. I can’t get the repeater to link to
the remote base…When I issue the connect command: *2(node number), the
controller says it’s linking both on the console and verbally. But, then
the commands. I’ve tried this both ways–repeater to remote base (commands
process to regain control–“stop now” from the asterisk console
hangs…This should work, right?
Thanks in advance!
David KB4FXC
Hi Steve and Roger,
Thanks so much for the assistance. I’ll give it a try today and report
Hi Steve,
I'll probably eventually want to use USB hubs, too! I'll give this a try
once I get the base install straightened out.
Tnx en 73
David KB4FXC
On Tue, 22 Jul 2008, Steven Henke wrote:
Mark,
73,
Steve Henke
> Mark,
> KC5EVE
> >David,
> >ports.
> >Steve,
> >WA6ZFT
> > > Hi Roger & Steve,
> I'd
> LED
> moment.
> to
> the
> then
> (commands
> asterisk
> > > Thanks in advance!
> > > David KB4FXC
> > >> Hi Steve and Roger,
> > >> <snip>
Hi Everyone,
Well, I got the ACID release installed easily and it's working GREAT!
--All the strangeness is gone! WONDERFUL!
Thanks to everyone for all the help.
73, David KB4FXC
PS: I'll try out a multi-tt USB hub soon now.
On Mon, 21 Jul 2008, David McGough wrote:
Hi Steve,
73, David KB4FXC
> David,
> working.
> greatest versions.
> Steve
> > Hi Steve,
> > the ACID release.
> > lock up....
> > [general]
> > [radio-secure]
> > [autopatch]
> > (optional)
> > (optional)
> > totime=10000
> > (optional)
> > ; respectively
> > timer
> > tail.
> > is none
> > remotect=ct3
> > duplex=2
> > (optional)
> > (optional)
> > totime=10000
> > (optional)
> > ; respectively
> > remotect=ct3
> > duplex=0
> > ; function table
> > [functions]
> > only
> > 81=status,2 ; Time
> > in command mode
> > section is
> > functions.
> > [link-functions]
> > only
> > transceive
> > 81=status,2 ; Time
> > [telemetry]
> > each repeater.
> > defined in the
> > ; [morse] section.
> > ; [morse] section.
> > [morse]
> > [wait-times]
> > [nodes]
> > [general]
> > rxcpusaver=0
> > txcpusaver=0
> > debug=0x7
> > [usb]
> > ; TKR-850
> > devicenum=0
> > using
> > of
> > removed
> > receiver output
> > table
> > sound fob
> > squelch
> > work.
> > modulator
> > before unkeying TX
> > auxvoice
> > ; See txmixa above.
> > transmit
> > modified
> > ; usb sound fob.
> > do this.
> > [usb1]
> > ; IC-706mk2g
> > devicenum=1
> > hdwtype=0
> > rxboost=0
> > rxctcssrelax=1
> > txctcssdefault=0.0
> > rxctcssfreqs=0.0
> > txctcssfreqs=0.0
> > auxvoice
> > transmit
> > duplex=0 ; Simplex
> >> David,
> >> ports.
> >> Steve,
> >> WA6ZFT
> >>> Hi Roger & Steve,
> >>> Thanks in advance!
> >>> David KB4FXC
> >>>> Hi Steve and Roger,
> >>>> <snip>
Hi Everyone,
Now that I'm to the "beta" test phase, I've got some more questions that I
don't see answers to on the list--or have overlooked (if so, oops!).
First, is there an easy way to disable DTMF decoding entirely for a
channel? My HF node (on very staticy 75M) generates a fair number of
spurious DTMF decodes. And, each time it thinks it hears a code, there is,
as expected, a very short dropout of HF RX audio being passed to the UHF
repeater side. I don't need DTMF decode at all for this node and would
like to turn it off.
Second, does anyone have (or know of) a simple utility to generate sound
files for the CD ID, etc.
Thanks!
David KB4FXC
