Below are examples of MY SETUP as assisted by W9SH
I removed the Functions but notice the phone functions use two different
function lists for Phonepatch... They are not included for security
reasons...
I hope this helps!!!
Also Steve, Did you get my apps for The GMRS, FRS and MURS and All the
registrations for the different systems I applied for (or is that not you)
I would also like to talk to You guys about Phone patch control...
Best Regards to ALL
Roger W4RFJ
; rpt.conf
; 20071103 0900 sphenke@xelatec.com
; Radio Repeater / Remote Base config for use with app_rpt
; manipulated by the app_rpt installation script
; text strings that begin with xxx_ should be manually edited
; if the install script does not replace them.
[101]
rxchannel = radio/usb
duplex = 2
functions = functions ; DTMF function list
link_functions = functions-linked ; DTMF function list for link
phone_functions = functions-phone-1 ; (optional) different functions for
'P' mode
tonezone = us ; use US tones (default)
context = from-internal ; dialing context for phone
callerid = "de w4rfj/r"<445.95 pl100> ; Callerid for phone calls
idrecording=|ide w4rfj/r
accountcode=RADIO ; account code (optional)
funcchar = * ; function lead-in character
(defaults to '*')
endchar = # ; command mode end character
(defaults to '#')
hangtime=10 ; squelch tail hang time (in ms)
(optional)
totime=180000 ; transmit time-out time (in ms)
(optional)
idtime=600000 ; id interval time (in ms)
(optional)
politeid=30000 ; time in milliseconds before ID
timer
propagate_phonedtmf=yes ;propagate_phonedtmf = yes
unlinkedct=ct1 ; DTMF sent to system from phone
gets
; repeated into main system output
and
[102]
rxchannel = radio/usb1
duplex = 0
phone_functions = functions-phone-1 ; different functions
callerid = "wqex329"<FRS Channel 1> ; Callerid for phone calls
idrecording=|iK
(defaults to '*')
(defaults to '#')
hangtime=3 ; squelch tail hang time (in ms)
(optional)
(optional)
(optional)
timer
propagate_phonedtmf=no
*************everything in between deals with DTMF Commands Etc...
101 = radio@192.168.14.149:4569/101,NONE
102 = radio@192.168.14.149:4569/102,NONE
; end of file - rpt.conf
; usbradio.conf
; Configuration for chan_usbradio
; 20071205 0845 sphenke@xelatec.com
; refer to globals_rpt_custom.conf for variable definitions
[general]
rxcpusaver=0
txcpusaver=0
[usb]
hwtype=0
rxboost=1
rxctcssrelax=0
txctcssdefault=100.0
rxctcssfreqs=100.0
txctcssfreqs=100.0
carrierfrom=dsp
ctcssfrom=dsp
rxdemod=flat
txprelim=yes
txtoctype=notone
txmixa=composite
txmixb=no
invertptt=0
;rxfreq=445.950000
;txfreq=147.490000
duplex=1
eeprom=0
[usb1]
hwtype=0
rxboost=1
rxctcssrelax=1
;txctcssdefault=0
;rxctcssfreq=0
;txctcssfreq=0
carrierfrom=vox
ctcssfrom=no
rxdemod=speaker
txprelim=no
txtoctype=no; notone
txmixa=voice
txmixb=no
invertptt=0
;rxfreq=462.562500
;txfreq=462.562500
duplex=0
eeprom=0
-----Original Message-----
[mailto:app_rpt-bounces@lists.illiana.net] On Behalf Of Stephen Rodgers
Sent: Saturday, July 19, 2008 6:56 PM
To: Asterisk Repeater Controler
Subject: Re: [App_rpt] URI configuration help
David,
This is one area where our documentation falls short. We have got
automated installs and config examples for single-node systems, but
no examples for multi-node systems. Basically for each usb mode
entries will need to be made in usbradio.conf, rpt.conf, and
extensions.conf.
*** usbradio.conf ***
[general]
; Nothing in the general section for multiple devices.
[usb] ; first node
; Insert all USB config options from usbradio.conf.sample here except
; for devicenum setting. Modify settings to suit configuration.
devicenum=0 ; unique for each device defined
[usb1] ; second node
devicenum=1
[usb2] ; third node
devicenum=2
*** extensions.conf ****
exten => 1234,1,rpt,1234 # first node
exten => 5678,1,rpt,5678 # second node
exten => 9012,1,rpt,9012 # third node
**** rpt.conf ****
rpt.conf
[1234] ; first node
rxchannel = Radio/usb
; Configuration settings from rpt.conf.sample tailored to your
application follow the channel definition above.
[5678] ; second node
rxchannel = Radio/usb1
[9012] ; third node
rxchannel = Radio/usb2
Standard disclaimer boilerplate: I tried to answer your question. I
haven't tested what is documented above. I just did some quick research
to come up with this answer, and the research was not in-depth, There
may very well be something I left out, so your mileage may vary. There
are no guarantees. If you find something and fix it, please post it back
to the list so everyone will benefit from it.
Steve
WA6ZFT
David McGough wrote:
Hi Everyone,
I'm finally getting to "finish up" my URI based project and wondered if
someone could help point me to some advanced sample asterisk/app_rpt
config files (usbradio.conf, rpt.conf, primarily) for using the URI
adapters.
I've currently got 1 URI working properly with my TKR-850 repeater. Now, I
want to add 2 remote base radios for VHF and HF, do some linking, etc. I,
mainly need more info about the syntax to use with multiple URI's,
usbradio.conf options, etc.
Thanks in advance!
David KB4FXC
App_rpt mailing list
App_rpt@lists.illiana.net
