Roger,
Glad to see you are on the way to getting it working.
Thanks for the update on radio tune. I was unaware this returned any
information at all.
Steve.
Roger F. Jordan Sr. wrote:
Hi Steve,
Thanks for the quick reply! Steve W9SH has been on the phone with me and
has pretty much put me on the right track! We (actually He) has determined
that One of my radios is not configured correctly (I am in the process of
fixing! And also we have pretty much gone thru all the files to ensure that
I did not mess anything else up!The "radio tune" command does give you information... according to the
docs... it will tell you what usb device is active and info about that
device!I appreciate the reply!
Roger W4RFJ
-----Original Message-----
[mailto:app_rpt-bounces@lists.illiana.net] On Behalf Of Stephen Rodgers
Sent: Friday, February 15, 2008 9:08 PM
To: Asterisk Repeater Controler
Subject: Re: [App_rpt] This might help you help me figure out what is goin'
on...First off, The EEPROM notices can be safely ignored. With a modified USB
fob, there is no EEPROM facility. All level settings are stored in a file.The correct command is "radio tune rxnoise". There is no "radio tune"
command.You should have an AC noise waveform at the tap on the voltage divider
during the "radio tune rxnoise" test Preferably, you should check it
with a scope and see what the level is. Levels less than 50 millivolts
peak to peak at the tap could be your problem.Roger F. Jordan Sr. wrote:
Hi everyone.
I am getting an error in the cli as follows.
[Feb 15 16:41:36] NOTICE [10592]: chan_usbradio.c:1079 hidthread
UNSUCCESSFUL: EEPROM checksum BAD OR No EEPROM installed on channel usb[Feb 15 16:41:36] NOTICE [10593]: chan_usbradio.c:1079 hidthread
UNSUCCESSFUL: EEPROM checksum BAD OR No EEPROM installed on channel usb1Still unable to get anything to adjust with the radio tune command.
Does the above line look familiar to anyone
Best Regards,
Roger W4RFJ
App_rpt mailing list
App_rpt@lists.illiana.net
http://lists.illiana.net/mailman/listinfo/app_rpt_______________________________________________
