[App_rpt] The wiring of the URI to a FT857D
Hello to the group,
I would like to wire the URI up to my Yaesu FT857D and would like to here any comments concerning the wiring diagram posted on the FT897. Could one use the wiring diagram replacing the PCI radio interface points for the URI points?
Will / W4WWM
Yes and no. For a audio and keying there will probably be no issues. For
control of frequency and mode, you'll need to purchase the Yeasu CT62
RS-232 adapter cable.
Please also note that we have never tested app_rpt with an FT857 so we
can't tell you for certain that app_rpt will work with it or not.
Steve.
Will wrote:
Hello to the group,
Will / W4WWM
App_rpt mailing list
App_rpt@lists.illiana.net
Steve,
What radio is your hf remote??? Thouhght you were running a ft857??
Eric
On Sat, Feb 23, 2008 at 10:46 AM, Stephen Rodgers hwstar@rodgers.sdcoxmail.com wrote:
control of frequency and mode, you’ll need to purchase the Yeasu CT62
can’t tell you for certain that app_rpt will work with it or not.
Steve.
Will wrote:
Hello to the group,
Will / W4WWM
Steve,
I do have the CT62. So all I would need is to make up or match the PTT, COS ,grounds RX Audio and TX Audio cable to the rig from the URI?
Will
Nope. It's an FT-897.
Steve.
Eric Fort wrote:
Steve,
Eric
On Sat, Feb 23, 2008 at 10:46 AM, Stephen Rodgers < > hwstar@rodgers.sdcoxmail.com> wrote:
Steve.
Will wrote:
Hello to the group,
Will / W4WWM
Will,
Yes, that's about it. Make sure you set the usbradio.conf to use an
external COS/COR as it will not be able to use squelch noise. Also
you my have to tweak some of the voltage divider resistors to adjust the
TX audio level.
Steve.
Will wrote:
Steve,
Will
ah, got it. 857 should work though as the radios are supposed to be internally identical. I believe they use the same cat command set.
Eric
On Sat, Feb 23, 2008 at 1:16 PM, Stephen Rodgers hwstar@rodgers.sdcoxmail.com wrote:
Nope. It’s an FT-897.
Steve.
Eric Fort wrote:
Steve,
Eric
On Sat, Feb 23, 2008 at 10:46 AM, Stephen Rodgers < > > > hwstar@rodgers.sdcoxmail.com> wrote:
Steve.
Will wrote:
Hello to the group,
Will / W4WWM
