Just an update. I did a bit of hacking of the ACID install scripts, edited them to take out some of the riskier parts, and then ran them to install Asterisk on the existing CentOS box. Now, Asterisk no longer segfaults. Just have to see about getting the chan_rtpdir link working, after ensuring that the version of chan_rtpdir matches the requirement on the other end.
73 de VK3JED
http://vkradio.com
I hope you have better luck with that than my limited initial testing... It wasn't extensive, so it could be a stupid mistake on my part.
I put in the DTMF commands in the rtpDir config file, updated the channel driver to the latest SVN version (and app_rpt), but I can see no indication that anything ever happens or any data is being passed to rtpDir for the DTMF codes. I can see in the asterisk log that it caught the DTMF characters, just nothing to show that they made it to rtpDir.
Steve
I'm running a different software confiiguration, using thebridge instead. I can see that Asterisk has made the connection (still running a v0.2 link, and it seems to be nailed up, which is exactly what I want for my setup).
As my tbd is a remote system (no RF, it's the hub of a major active network), the DTMF side is less important at this stage. The ideal would be to have my Asterisk box on a co-lo box somewhere so it could be used as a conference hub for a large number of Asterisk nodes to connect to.
73 de VK3JED
http://vkradio.com
rtpDir.
ver. 0.2 has absoulutely no concept of DTMF.
Date: Thu, 31 Jul 2008 06:59:03 +1000
To: app_rpt@lists.illiana.net
Subject: Re: [App_rpt] Some success!
rtpDir.
I’m running a different software confiiguration, using thebridge
As my tbd is a remote system (no RF, it’s the hub of a major active
73 de VK3JED
http://vkradio.com
App_rpt mailing list
App_rpt@lists.illiana.net
I know, I'm using it as a nailed up link.
BTW, has the list configuration changed in the last day or so? I can't tell who's posted what, everything comes from "Asterisk Repeater Controller", which is confusing.
73 de VK3JED
http://vkradio.com
why would it being nailed up or not have anything to do with
passing DTMF data?
Jim WB6NIL
Date: Thu, 31 Jul 2008 11:19:47 +1000
I know, I’m using it as a nailed up link.
can’t tell who’s posted what, everything comes from “Asterisk
Repeater Controller”, which is confusing.
73 de VK3JED
http://vkradio.com
