[App_rpt] Simplex node with just RXAud/TXAud/PTT ?
I believe I am looking for a configuration similar to what you’ve got going on, simplex base control: one asterisk box at location A, with a motorola GM300 through USB soundcard FOB and another identical setup at location B. When a portable at A transmits on the channel the GM300 is on, I want the audio to cross over IAX2/GSM and open up the radio at site B, transmitting to portables at that site… the same process should happen in reverse for traffic from B. I’ve read it’s dangerous to use mobile radios above a 10% transmission duty cycle due to heat, so I think CTCSS/DCS between the portables and their (local) base is the best way to prevent that… meaning I want VOX control between the asterisk boxes right? Any comments or suggestions you may have would definitely be appreciated!
ChadP
no!!! why in the world would you want VOX operation when you have GM300’s which all have a BEAUTIFUL 16 pin connector on the rear
that gives you direct access to flat-audio (from discriminator, to modulator). If you take 4 wires, Ground, PTT, discriminator (flat) audio out,
and flat audio in, and connect them to the USB FOB and let the computer do the rest, you will have an absolutely optimum setup (at least for
simplex operation). You can even buy cables that have the 16 pin connector on 1 end and wires on the other on E-bay.
Date: Tue, 12 Aug 2008 18:51:57 -0500
To: app_rpt@lists.illiana.net
Subject: [App_rpt] Simplex node with just RXAud/TXAud/PTT ?
ChadP
It depends on the radio you use. I have 2 GM300s setup as a repeater, my transmit side only runs 8 watts and will run forever (i have dual fan cooling on it). One thing that you must have is fans blowing across the heatsink. My repeater is fairly active (i use it for voip linking) and i have had no issues. It's been on the air for a few years now.
Jim / K6JWN
On Aug 12, 2008, at 4:51 PM, Chad Palm wrote:
I believe I am looking for a configuration similar to what you've got going on, simplex base control: one asterisk box at location A, with a motorola GM300 through USB soundcard FOB and another identical setup at location B. When a portable at A transmits on the channel the GM300 is on, I want the audio to cross over IAX2/GSM and open up the radio at site B, transmitting to portables at that site.. the same process should happen in reverse for traffic from B. I've read it's dangerous to use mobile radios above a 10% transmission duty cycle due to heat, so I think CTCSS/DCS between the portables and their (local) base is the best way to prevent that.. meaning I want VOX control between the asterisk boxes right? Any comments or suggestions you may have would definitely be appreciated!
ChadP
App_rpt mailing list
App_rpt@lists.illiana.net
