[App_rpt] registering with 3 nodes?
The should now. Fixed addressing overrides reqistration. Your two nodes 2142 and 2165 had an FQDN. I removed the FQDN's from the Allstar database and now the registered IP addresses should propagate in the next hour or so.
Steve
WA6ZFT
Date: 2008/08/19 Tue PM 03:04:10 PDT
To: Asterisk Repeater Controler <app_rpt@lists.illiana.net>
Subject: [App_rpt] registering with 3 nodes?
My asterisk installation (ACID) is running with 3 nodes on it, and in
my iax.conf, I have 3 register lines (one for each node), however when
I look at rpt_extnodes on my node and a remote node, it seems like the
last entry is getting updated with the correct IP, and the first 2
don't get updated at all.
iax2 show registry shows that all 3 nodes are registered. Any ideas?
Nodes in question are 2142, 2165 and 2191 - all on a single host.
Jim / K6JWN
App_rpt mailing list
App_rpt@lists.illiana.net
Very good, thanks Steve!
Jim / K6JWN
On Tue, Aug 19, 2008 at 5:05 PM, hwstar@rodgers.sdcoxmail.com wrote:
The should now. Fixed addressing overrides reqistration. Your two nodes 2142 and 2165 had an FQDN. I removed the FQDN’s from the Allstar database and now the registered IP addresses should propagate in the next hour or so.
Steve
WA6ZFT
To: Asterisk Repeater Controler app_rpt@lists.illiana.net
don’t get updated at all.
Jim / K6JWN
