Does anyone know a way of recording the traffic (audio) in / out of the node and saving it as a file ( MP3 or whatever ) on the node hard drive?
Something along the lines of Scanrec, which is a windows application with built in Vox and timestamps, would be ideal but I wanted to avoid having another machine involved.
Anyone any ideas or thoughts on how this could be done - I should add that I’m a complete newbie!
If there's a soundcard built into the system, you could use that to record the audio from the node, Connect the audio from the Asterisk system to a Y splitter, so you can pick the audio off and feed it to the Line In on the soundcard. Then there's a bunch of commandline programs that could be used to record, or alternatively, setup a streaming audio feed.
Anyone any ideas or thoughts on how this could be done - I should add that I'm a complete newbie!
It's already in there. Check out the rpt.conf sample file...
73, Steve W9SH
On Thu, Oct 2, 2008 at 3:57 PM, Matt Beasant <g4rky@yahoo.co.uk> wrote:
Hi everyone,
I did not find rpt.conf.sample in the /etc/asterisk directory of the
network install... We could make it available in the XIPAR downloads...
VR
Roger W4RFJ
Xipar Application Engineer Extraordinaire
-----Original Message-----
[mailto:app_rpt-bounces@lists.illiana.net] On Behalf Of Steven Henke
Sent: Thursday, October 02, 2008 5:52 PM
To: Asterisk Repeater Controler
Subject: Re: [App_rpt] Recording repeater audio
73, Steve W9SH
Hi everyone,
The 'locate' command can be used to find it.
It's in /usr/src/EVB/ast_base/asterisk-1.4.21.2/configs/rpt.conf.sample
You're right that we should make an obvious link to it in the web
based documentation
73,
Steve
On Sat, Oct 4, 2008 at 8:46 AM, Roger F. Jordan Sr. <w4rfj@comcast.net> wrote:
Hey Steve,
VR
Roger W4RFJ
73, Steve W9SH
Hi everyone,
convert to MP3 in real time on a telecom system? Surely you jest :-). The cpu time required for that (especially on smaller systems) would be MOST prohibitive.
Therefore, its really designed to have a queue of native format messages (and log files, also) get copied to a larger server on a periodic basis and let the
large server with big CPU’s handle the MP3 crunching.
Ah, yeah, you’re right Jim. Didnt think of that one!
My excuse, its getting late here in England
As it is, I’m just happy its there for me and working great. Its a steep learning curve for me but the more I learn about Allstar / appRpt the more I like it.
Ever the voice of controversy - I disagree with you. LAME encodes at
faster than real-time on reasonable spec hardware (P3 2.4Ghz for
example will do 2x 48Khz streams). For example, to capture directly
from a sound device and write to MP3 natively you can use sox to do the
I/O and pipe it to lame, as below.
I agree. In my experience, most any recent CPU has enough horsepower to
easily keep up with real-time mp3 encoding.....Particularly if you aren't
trying to encode "audiophile" quality mp3's! ....I haven't tried to get
asterisk to do this, though.
73, David KB4FXC
On Sun, 5 Oct 2008, Jon Richardson wrote:
Hey Jim,
faster than real-time on reasonable spec hardware (P3 2.4Ghz for example
will do 2x 48Khz streams). For example, to capture directly from a sound
device and write to MP3 natively you can use sox to do the I/O and pipe
I don't know how "accessible" the raw commands are to app_rpt but it
shouldn't be too tricky to do...
73 Jon G7PFT
> Therefore, its *really* designed to have a queue of native format
> large server with big CPU's handle the MP3 crunching.
> Date: Sat, 4 Oct 2008 22:10:11 +0100
> From: g4rky@yahoo.co.uk
> To: app_rpt@lists.illiana.net
> Thanks to everyone who replied.
> I've found it now and it works a treat!
> Are there any other options I can use with that command, for example,
> to change to MP3 format or something?
> If not, no problem - its working well and seems to require about 8Kb /
> sec of disc space, which equates to almost 700 hours for a 20Gb
> partition..
> Cool! Thanks,
> Matt
> G4RKY
> 2008/10/4 Steven Henke <steve.w9sh@gmail.com
> <mailto:steve.w9sh@gmail.com>>
> Rodger,
> It's in
> based documentation
> 73,
> Steve
> On Sat, Oct 4, 2008 at 8:46 AM, Roger F. Jordan Sr. > > <w4rfj@comcast.net <mailto:w4rfj@comcast.net>> wrote:
> > Hey Steve,
> directory of the
> downloads...
> > VR
> > Roger W4RFJ
> > From: app_rpt-bounces@lists.illiana.net
> <mailto:app_rpt-bounces@lists.illiana.net>
> <mailto:app_rpt-bounces@lists.illiana.net>] On Behalf Of Steven Henke
> > 73, Steve W9SH
> > On Thu, Oct 2, 2008 at 3:57 PM, Matt Beasant <g4rky@yahoo.co.uk > > <mailto:g4rky@yahoo.co.uk>> wrote:
> >> Hi everyone,
> out of the
> hard drive?
> application with
> avoid having
> should add that
> >> Thanks in advance for any replies.
> >> 73,
> >> Matt
> >> G4RKY
> >> _______________________________________________
> >> App_rpt mailing list
> >> App_rpt@lists.illiana.net <mailto:App_rpt@lists.illiana.net>
> >> http://lists.illiana.net/mailman/listinfo/app_rpt
