Matt,
If you followed the instructions is the ACID sysadmin manual, everything should be fine. Since database show
is working, most of it is up and running. You might want to post your echolink.conf file with rhe password obiliterated
to the list so that we can see if it is ok.
If you try to connect before everyone gets an updated list
the connection will fail. Please try after about an hour
so that everyone gets a list with your node in it.
Something else to check: Is your node showing up on echolink.org?
Finally, don't worry about this message:
WARNING[5786] file.c:1198 waitstream_core: Unexpected control subclass '13'
Steve
WA6ZFT
reply (146 Bytes)
Date: 2008/10/11 Sat AM 01:55:47 PDT
To: "Asterisk Repeater Controler" <app_rpt@lists.illiana.net>
Subject: [App_rpt] Problems with Echolink on app_rptDear all,
I've upgraded my node to the latest release and have attempted to get
Echolink working on my node.However, I'm having problems and wondered if anyone could point me in the
right direction for a fix?When I try to make an outgoing call from my node to an echolink node, I
instantly get the "node connection failed" message.On the CLI, the announcement text is immediately preceeded by:
When I try to make a call IN to my node form an Echolink node, I see:
ERROR[2508]: chan_echolink.c:2165 do_new_call: Cannot find DB entry for
a/ipaddr/81.156.xxx.xxxHowever, I do frequently see messages such as:
NOTICE[2507]: chan_echolink.c:1758 sendcmd: Received OK from Echolink server
europe.echolink.organd the database show command works fine also.
Do I need to follow these instructions here :
http://app-rpt.qrvc.com/echolink.html or is my node already up to date
enough to not have to do this?I also noted the existence of an IRLP config file in the config examples - I
need IRLP functionality on my node and so is this something I can use too?Thanks in advance for any and all help received!
Kind regards,
Matt
G4RKY
node 2250 & 2237
