[App_rpt] Problem tuning USB Radio Interface
Jeff Lavoie
[wqex694@wqex694.info] Wrote:
I seem to have a problem
tuning the USB radio interface. Here’e what I get in the CLI.
*CLI> radio tune
Active radio interface
is [usb]
Output A is currently
set to composite.
Output B is currently
set to voice.
Tx Voice Level currently
set to 500
Tx Tone Level currently
set to 200
Rx Squelch currently set
to 500
Device String is 3-2
Usage: radio tune
rxnoise
rxvoice
rxtone
rxsquelch [newsetting]
txvoice [newsetting]
txtone [newsetting]
auxvoice [newsetting]
save (settings to tuning file)
load (tuning settings from EEPROM)
All [newsetting]'s are values 0-999
*CLI> radio tune
rxnoise
tune rxnoise maxtries=12,
target=23000, tolerance=2000
tries=0, setting=2,
meas=1
tries=1, setting=16,
meas=1
tries=2, setting=16,
meas=1
tries=3, setting=16,
meas=1
tries=4, setting=16,
meas=1
tries=5, setting=16,
meas=1
tries=6, setting=16,
meas=1
tries=7, setting=16, meas=1
tries=8, setting=16,
meas=1
tries=9, setting=16,
meas=1
tries=10, setting=16,
meas=1
tries=11, setting=16,
meas=1
DONE tries=12,
setting=1000, meas=1
ERROR: RX INPUT ADJUST
FAILED.
*CLI>
I know I have audio
going into the device. When I made the modifications to the usb device, I
decided not to remove the >audio output jack so that I may use it for
testing purposes. So I plugged some speakers in, went into alsamixer, un->muted
the microphone, turned it up a little, and I had sound from the radio without
any problems. So why can’t asterisk >hear the sound when tuning?
Have I forgotten to do something else before trying this?
Jeff
Well I am getting the same thing except the Meas= is around
9-11 and the final Done line reads tries=12 setting=1000 measure=10
And I can’t get the usb fob to repeat!.. however is
does decode DTMF in double… IE push the tone once and it shows up as
being decoded twice on the CLI… I am thinking I need to reinstall
this EVB setup I have been trying to get working!
Anyone have any ideas??
Best Regards,
Roger W4RFJ
