[App_rpt] Possible Bug (Locked to TX several hours).
Hi Guys I thought I should report the following as a possible Bug.
I dialed up the following Echolink node last night to help out with Jota in the area and left it running over night.
*33 138203 (JOTA-E).
When I went to check it again today at about 2PM the Transmitter was locked on solid and there was no Audio.
I checked the asterisk box to see that Asterisk has dropped out with an error and the DMK dongle had left the Transceiver locked on TX. :frowning:
Both the Green and the Red lights of the DMK Dongle were on Solid (Not Flashing)…
Here is what was on the screen
[Oct 18 21:55:51] NOTICE[6389]: chan_echolink.c:2333 el_reader: Name changed from (Conference [9/33]) CONF to (Conference ) CONF
[Oct 18 21:55:52] WARNING[6498]: codec_gsm.c:144 gsmtolin_framein: Invalid GSM data (1)
[Oct 18 21:55:52] WARNING[6498]: translate.c:211 framein: gsmtolin did not update samples 0
shazam*CLI>
Disconnected from Asterisk server
I think this is the only relevent bit. But below is a longer section of the console msg’s just in case.
Hope this is of some help. .
Regards,
Ken - vk4akp
[Oct 18 21:52:34] NOTICE[6389]: chan_echolink.c:2333 el_reader: Name changed from (KB2BAA John) CONF to (Conference [10/33]) CONF
[Oct 18 21:52:37] NOTICE[6389]: chan_echolink.c:2333 el_reader: Name changed from (Conference [10/33]) CONF to (KI4FRI ) CONF
[Oct 18 21:52:41] NOTICE[6389]: chan_echolink.c:2333 el_reader: Name changed from (KI4FRI ) CONF to (KB2BAA John) CONF
[Oct 18 21:52:48] NOTICE[6389]: chan_echolink.c:2333 el_reader: Name changed from (KB2BAA John) CONF to (Conference [9/33]) CONF
[Oct 18 21:52:48] NOTICE[6389]: chan_echolink.c:2333 el_reader: Name changed from (Conference [9/33]) CONF to (KB2BAA John) CONF
[Oct 18 21:52:51] NOTICE[6389]: chan_echolink.c:2333 el_reader: Name changed from (KB2BAA John) CONF to (Conference [9/33]) CONF
[Oct 18 21:52:53] NOTICE[6389]: chan_echolink.c:2333 el_reader: Name changed from (Conference [9/33]) CONF to (KB2BAA John) CONF
[Oct 18 21:53:21] NOTICE[6389]: chan_echolink.c:2333 el_reader: Name changed from (KB2BAA John) CONF to (Conference [9/33]) CONF
[Oct 18 21:53:22] NOTICE[6389]: chan_echolink.c:2333 el_reader: Name changed from (Conference [9/33]) CONF to (Conference ) CONF
[Oct 18 21:53:33] NOTICE[6389]: chan_echolink.c:2333 el_reader: Name changed from (Conference ) CONF to (WB2JSM-R EchoIRLP) CONF
[Oct 18 21:53:58] NOTICE[6389]: chan_echolink.c:2333 el_reader: Name changed from (WB2JSM-R EchoIRLP) CONF to (Conference [10/33]) CONF
[Oct 18 21:54:01] NOTICE[6389]: chan_echolink.c:2333 el_reader: Name changed from (Conference [10/33]) CONF to (KB2BAA John) CONF
[Oct 18 21:54:16] NOTICE[6498]: chan_echolink.c:1422 el_xwrite: Echolink el0-12 Got DTMF char 3 from IP 213.217.112.162
[Oct 18 21:54:19] NOTICE[6391]: chan_echolink.c:1758 sendcmd: Received OK from Echolink server server2.echolink.org
[Oct 18 21:54:20] NOTICE[6391]: chan_echolink.c:2079 do_el_directory: Diretory pgm done downloading(partial,compressed), 153 records
[Oct 18 21:54:34] NOTICE[6389]: chan_echolink.c:2333 el_reader: Name changed from (KB2BAA John) CONF to (Conference [10/33]) CONF
[Oct 18 21:54:34] NOTICE[6389]: chan_echolink.c:2333 el_reader: Name changed from (Conference [10/33]) CONF to (Conference ) CONF
[Oct 18 21:54:44] NOTICE[6389]: chan_echolink.c:2333 el_reader: Name changed from (Conference ) CONF to (WB2JSM-R EchoIRLP) CONF
[Oct 18 21:55:11] NOTICE[6389]: chan_echolink.c:2333 el_reader: Name changed from (WB2JSM-R EchoIRLP) CONF to (Conference [10/33]) CONF
[Oct 18 21:55:13] NOTICE[6389]: chan_echolink.c:2333 el_reader: Name changed from (Conference [10/33]) CONF to (KB2BAA John) CONF
[Oct 18 21:55:49] NOTICE[6389]: chan_echolink.c:2333 el_reader: Name changed from (KB2BAA John) CONF to (Conference [9/33]) CONF
shazam*CLI>
