Apart from the new scripts and the echolink bits is there anything super
important over 119 or should one just wait for the next time?
Cheers, John ZL4JY
-----Original Message-----
[mailto:app_rpt-bounces@lists.illiana.net] On Behalf Of Stephen Rodgers
Sent: Wednesday, 8 October 2008 08:36
To: Asterisk Repeater Controler
Subject: Re: [App_rpt] New ACID version uploaded to dl.allstarlink.org
James,
A new ISO is not necessary, but all the scripts have drastically
changed! astupd.sh depends on astinstall.sh in /etc/rc.d, and phase2.sh
now calls astinstall.sh which is a common asterisk install script. There
is a change to phase1.sh to remember where the download repository is
located (acidrepo file), and everything keys off of this. So unless you
want to figure out all the details of how the scripts work, your better
off doing a fresh install! Just save all your conf files first so that
you can re-install them over the default files after you run setup.sh
and enable ssh access.
Steve.
James Nessen wrote:
So, should we download a new iso, or is there any way current nodes
can get the new astupd.sh script?
Rodgers
Sent: Sunday, October 05, 2008 1:31 PM
Subject: [App_rpt] New ACID version uploaded to dl.allstarlink.org
A new ACID version has been uploaded:
1. App_rpt version 0.151 supports chan_echolink and local messages 2.
Screen program added 3. chan_echolink channel driver 4. Asterisk
update script astupd.sh
The current install iso has not been affected, but if you are in the
middle of an install, it might be a good idea to start over as the
scripts have changed.
The only reason you should install this is to have the ability to update
to newer versions of asterisk in the future. The old version does not
support the update feature.
Steve.
WA6ZFT
John Yaldwyn wrote:
Hi Steve,
Cheers, John ZL4JY
James,
Steve.
Rodgers
