app_rpt logging
Afternoon all,
  Is there a way to enable broad logging of connect, disconnect, keying, that's seen by app_rpt? Even cranked up to debug, the information about who's connected, say via echolink, is not available. I'd have to dump console output to a file, and I'm hoping I'm just missing some setting to get by this. Thoughts?
Adam, KC2YQF
Allmon is a realtime monitor and control of app_rpt nodes via a web interface. See http://wd6awp.net/allmon/about.php
Tim
:wq
On Feb 17, 2015, at 12:15 PM, Pawlowski, Adam ajp26@buffalo.edu wrote:
Afternoon all,
Is there a way to enable broad logging of connect, disconnect, keying, that’s seen by app_rpt? Even cranked up to debug, the information about who’s connected, say via echolink, is not available. I’d have to dump console output to a file, and I’m hoping I’m just missing some setting to get by this. Thoughts?
Adam, KC2YQF
Adam,
All the other ideas have merit but there is a built-in way to do this using the archivedir command. The command is inserted in the node definition part of the node you want to log in rpt.conf.
archivedir=/var/log/asterisk/audio
archiveaudio=0 ; Disable saving .wav files
The second command is one we added to the BBB distribution because archivedir will save all status information including wav audio files of all transactions on the node stanza where you define it. Setting archiveaudio to 0 diables the saving of the audio files. Something you would definitely want to do if you are running the BBB. On a Pc you could just just have a cron job that deletes the wav files each day if you don’t want them.
It creates daily text files named like this -
/var/log/asterisk/audio/xxxxx/20150217.txt
xxxxx is the node number, so you can have logs for each node in separate directories. The file contents typically looks like this -
20150217000020,TXUNKEY,40879
20150217000020,TXUNKEY,41244
20150217000020,TXUNKEY,40561
20150217000022,RXKEY,28544
20150217000022,TXKEY,41167
20150217000022,TXKEY,28796
20150217000022,TXKEY,28366
There is a lot of data on a busy node! It is the complete date and time to the second, the action taken, and the node number that action was taken on.
I have created a perl program that sorts this all out and uses the Asterisk database to create real names. It also follows the date change and selects the new days file.
02/17/2015 20:24:29 RXKEY 40961 WA3DSP 146.565 Simplex 88.5 Cape May, NJ
02/17/2015 20:24:52 RXKEY 29971 WA3EZT 446.2 simplex Jenkintown, PA 19046
02/17/2015 20:26:37 RXKEY 28796 KC4RPP 443.100 Naples, FL
02/17/2015 20:27:11 RXKEY 40961 WA3DSP 146.565 Simplex 88.5 Cape May, NJ
02/17/2015 20:28:17 RXKEY 29971 WA3EZT 446.2 simplex Jenkintown, PA 19046
02/17/2015 20:29:19 RXKEY 28796 KC4RPP 443.100 Naples, FL
In this case I only look at rxkey’s but you could look at any status command you desire. This is a great way to see exactly who is keyed up on a node.
So the information is there you just have to process it. The archivedir command gives you a very complete log of everything your node did including audio recordings if you want them.
73 Doug
WA3DSP
To: app_rpt-users@ohnosec.org
Date: Tue, 17 Feb 2015 20:15:06 +0000
Subject: [App_rpt-users] app_rpt logging
Afternoon all,
Adam, KC2YQF
Doug…
I haven’t tried that archiveaudio=0 thing.
Is that just on the bb code? I see no mention if such a thing elsewhere.
On Feb 17, 2015 9:04 PM, “Doug Crompton” doug@crompton.com wrote:
Adam,
73 Doug
WA3DSP
Afternoon all,
Adam, KC2YQF
Sam,
I don’t know if it was picked up in the Acid release. But on a PC it is not a big deal to save the wave files when you have a hard drive. Before I added the code to not save the wav files on my PC Acid install it saved a lot of data (every transmission is a separate wav file) but it hardly made a dent on a large hard drive even after several months and as I said you can just delete all wav files in the directory daily or at whatever interval you want with a cron job.
73 Doug
WA3DSP
Date: Tue, 17 Feb 2015 22:25:00 -0500
Subject: Re: [App_rpt-users] app_rpt logging
To: doug@crompton.com
CC: ajp26@buffalo.edu; app_rpt-users@ohnosec.org
Doug…
Adam,
73 Doug
WA3DSP
Afternoon all,
Adam, KC2YQF
