[App_rpt] [Fwd: RE: audio setup issues with USB FOBs]
"wa4zlw@arrl.net" <wa4zlw@arrl.net>
-------- Original Message --------
Subject: RE: [App_rpt] audio setup issues with USB FOBs
Date: Sun, 27 Apr 2008 16:44:41 -0400
To: Asterisk Repeater Controler <app_rpt@lists.illiana.net>, References: <47FE5157.9090105@backwoodswireless.net> <e2ed85230804101825v52873c77ta4f5c74f37708383@mail.gmail.com>
Steve�I�m headed down to VA tomorrow morning and will return home Friday. What�s a good time during this week for you? Please post directly to leonz@mybluemont.com <mailto:leonz@mybluemont.com> so we can take it off list.
Thanks leon
*From:* app_rpt-bounces@lists.illiana.net [mailto:app_rpt-bounces@lists.illiana.net] *On Behalf Of *Steven Henke
*Sent:* Thursday, April 10, 2008 9:26 PM
*To:* wa4zlw@arrl.net; Asterisk Repeater Controler
*Subject:* Re: [App_rpt] audio setup issues with USB FOBs
Leon,
Sounds like the flat output may be flat but only through 3 KHz and not up to 10 KHz where the noise is for carrier squelch.
The way to figure this out is to sample the audio through the USB adapter into a utility like Audacity and use its FFT to see what the noise spectrum looks like.
I'd be glad to help you do this by logging in, capturing the signal and transfering to my lab for analysis. I can take the results and come up with a configuration setting that will work for you.
Just let me know what you want to do.
73,
Steve Henke, W9SH
On Thu, Apr 10, 2008 at 1:41 PM, Leon D. Zetekoff, NCE <wa4zlw@backwoodswireless.net <mailto:wa4zlw@backwoodswireless.net>> wrote:
Hi there�
We purchased a few of the DMK USB FOBs awhile back after homebrewing a few.
When I was down in Virginia at company HQ last month, I spent a few
nights trying to make this work to no avail. We have an old IFR service
monitor which I was using to generate tones and such. We're using an
Icom commercial repeater IC-FR3000/4000. The Icom has no internal
controls for rx or txaudio that I can find (documentation is very slim).
Basically, rxtune doesn't want to work with the audio coming off the
Icom repeater discriminator. I did not try deemphasized audio as I want
to keep everything flat. In looking through some of the old posts we are
seeing similar results whereby rxtune doesn't see anything.
But oddly enough, if I used the HT to generate DTMF tones, the * box
would detect them. The transmitted audio I could not get more than 2 or
2.5 kHz deviation with the audio coming out of the * box.
As a side note, when we were using the homebrew USB FOBs we had louder
digitally generated audio (didn't have the service monitor then) than
repeated audio.
Got any ideas to try?
Thanks leon wa4zlw
App_rpt mailing list
App_rpt@lists.illiana.net <mailto:App_rpt@lists.illiana.net>
