[App_rpt] EVB 0.011
Steve:
First, thank you for your quick reply.
I did another install from scratch using your link to get the bash script
evbphase2. I believe this was the same version that I had used initially.
However, I received many more Errors, Warnings and Notices than before,
including all the ones from my first attempt.
I have tried this installation on two computers but with exactly the same
results: Everything is fine and Asterisk runs until I execute evbphase2.
After it finishes, Asterisk starts but immediately exits with error return
1.
A number of the Warnings are really puzzling, such as looking for the sound
module 'format_au.so' which clearly does not exist on disk. Is it possible
that you had some residual files on your system when you tested evbphase2?
I can send you the final lines from /var/log/asterisk/full or the death
messages from Asterisk if you would like to see them.
Do you see any advantage in trying EVB 010?
Looks like I may have to return to compiling everything from source onto
Debian :slight_smile:
I would certainly appreciate any further thoughts.
73,
David
VE7MQ.
