See below
Steve
WA6ZFT
Date: 2008/10/09 Thu AM 10:56:12 PDT
To: Asterisk Repeater Controler <app_rpt@lists.illiana.net>
Subject: Re: [App_rpt] Dial-in access to remote baseHi Steve,
Thanks for the help! I'm just about there now, I think! I added the config
statements you suggested and now I can key the remote base via '*9' and
unkey via '#'.....But this seems a bit flakey--I can get the remote base
keyed, but, it doesn't always unkey..Also, VOX mode still doesn't want to
work.Some other observations are: I noticed that if I use simple mode, once the
remote base is keyed it won't unkey....Not really an issue to me, but, an
observation. And, function *7 (link status) causes a seg fault--should
that happen?
First off: Link status doesn't make sense on a remote base!
Remote bases are for exclusive use by one user at a time!
Key-unkey flakiness. Two things to check:
1. What happens when you configure the HF and VHF radios as a standard node (with duplex=0)? The remote base code is separate from the standard node code, and there could be a keying bug could be in the remote base code.
2. Please confirm the phone key/unkey is not flakey on your standard node.This key/unkey issue could be a SIP configuration issue.
Please note as I mentioned earlier that VOX, etc., works fine on the
repeater node (#21), interestingly....Here are my current configs:
rpt.conf
--------[22] ; Change this to your assigned node number
rxchannel = Radio/usb1 ; Rx audio/signalling channel
duplex=0
remote=y
functions = functions_remote
phone_functions = functions_remote
authlevel = 0 ; should be set to 0 or left undefined.
remote_inact_timeout = 0
remote_timeout = 0
remote_timeout_warning = 0
remote_timeout_warning_freq = 0
voxtimeout=5000 ; time to let vox talk in ms
voxrecover=500 ; time to take from vox one timed out in ms
simplexpatchdelay=10 ; # of 20 ms frames to delay audio
simplexphonedelay=10 ; # of 20 ms frames to delay audio[functions_remote]
7=ilink,5 ; Link status
8=status,2 ; Time
9=cop,6 ; Phone TX keyextensions.conf
----------------[radio-control]
exten=22,1,Answer
exten=22,n,Playback,rpt/node
exten=22,n,Playback,digits/2
exten=22,n,Rpt,22|PvOn Thu, 9 Oct 2008 hwstar@rodgers.sdcoxmail.com wrote:
> Do you have a functions_remote stanza and is phone_functions pointing
to a remote_functions function table? Do you have a 98=cop,6 statement in
the remote_functions stanza?
> [functions_remote]
> 98=cop,6
> Finally, is authlevel set to 0 or undefined in the node stanza? If
authlevel is >0, you won't be able to key anything and 20 seconds later,
you'll be disconnected!
> [XXXX]
> rxchannel = Zap/2
> remote = ft897
> functions = remote-functions
> phone_functions = remote-functions ; important!
> authlevel = 0; should be set to 0 or left undefined.
> Steve
> WA6ZFT
> > From: David McGough <kb4fxc@inttek.net>
> > Date: 2008/10/09 Thu AM 07:53:24 PDT
> > To: app_rpt@lists.illiana.net
> > Subject: [App_rpt] Dial-in access to remote base
> > Hi Everyone,
> > I'm having a problem using my remote base via dial-in access to asterisk
> > and I'm trying to figure out how to fix it....
> > On my asterisk box, I'm controlling 3 nodes currently. The first (node
> > #21) is a UHF repeater, and the second (node #22) and third (node #23)
> > nodes are simplex VHF and HF remote base radios....All these nodes are
> > working fine, etc.
> > The dial-in and autopatch functions work great with my repeater node
> > (#21) ....But, for the remote base nodes, I can't key the rig from the SIP
> > phone no matter what I try! I've tried all the phone modes: dumb,
> > normal, simple and VOX mode from the extensions.conf. Nothing works.
> > Here is a snippet of my extensions.conf:
> > [radio-control]
> > exten=21,1,Answer ; Works great!
> > exten=21,n,Playback,rpt/node
> > exten=21,n,Playback,digits/2
> > exten=21,n,Playback,digits/1
> > exten=21,n,Rpt,21|Pv
> > exten=22,1,Answer ; Can't key the remote base
> > snippet of rpt.conf:
> > [22]
> > duplex=0
> > remote=y
> > remote_timeout = 0
> > simplexpatchdelay=5 ; # of 20 ms frames to delay audio
> > simplexphonedelay=5 ; # of 20 ms frames to delay audio
> > [nodes]
> > 21 = radio@127.0.0.1/21,NONE
> > 22 = radio@127.0.0.1/22,NONE,y
> > 23 = radio@127.0.0.1/23,NONE,y
> > Thanks in advance!
> > 73, David KB4FXC
> > _______________________________________________
> > App_rpt mailing list
> > App_rpt@lists.illiana.net
> > http://lists.illiana.net/mailman/listinfo/app_rpt
