Fixed:
1. Mantis bug 0000011 pad test broken
2. Mantis bug 0000004 out-of-band telemetry sent when link in monitor
Added:
Adjustable gains for irlp and echolink in rpt.conf node stanza. Testing
required to see if it resolves Mantis bug 0000001. Key values for
rpt.conf follow (which are also the defaults):
irxgain=-10 ; IRLP receive gain adjustment
; Note: Gain is in db-volts (20logVI/VO)
itxgain=10 ; IRLP transmit gain adjustment
erxgain=-3 ; Echolink receive gain adjustment
etxgain=3 ; Echolink transmit gain adjustment
Unfortunately, the varying audio level problem is still not resolved.
Awesome!! I just installed this update on a node that was known to have hot IRLP audio. Using the new level adjustments I was able to make his IRLP audio sound just as great as his Asterisk->Asterisk audio.
I have the latest version of ACID installed on 6+ nodes. I know that the astupd.sh script will at some time update the app_rpt and irlp/echolink channels, but in a step by step how would one get the latest builds (Bleeding edge) installed and built?
