[App_rpt] ASTERISKNOW, pciradio and apt-rpt
Hello all :wink:
I'm allready starting a appliance with a pciradio and app-rpt.
I've tried ubuntu, fedora 4, debian with allways a problem to compile the
zaptel driver.
I'm not a geek and i think i've some issue to understand how linux work's
But now, as i'm trying asterisknow, i've found something working better.
I've installed it into a dedicated server. I've tried to launch asis the
pciradio card with "modprobe pciradio" and it's working.
But i have'nt seen anything like app-rpt.so module in CLI console.
I've many trouble to launch something working.
Can you explain what is the best procedure to install asterisk with app-rpt
please ?
Or somebody could explain how managing the app-rpt in asterisknow ?
Best regard's
Pierre
Here's the problem: Asterisknow is precompiled without the app_rpt
module being built during the compile process.
The best thing to do is go back to Fedora core 5 or Ubuntu Edgy, install
the appropriate kernel packages, then compile zaptel, libpri, and
asterisk from scratch. When you do a make menuselect on Asterisk to
configure it, select app_rpt and DTMF_RELAX.
For Fedrora core 5, you'll need to install the kernel-devel package
before compling zaptel.
For Ubuntu edgy, the appropriate packages are linux-headers and
build_essential. Ubuntu can be tricky to get it configured properly to
compile zaptel because it uses different linux-headers packages for the
server, desktop, and amd64 versions and it is very easy to install the
wrong one.
Steve.
f1shs wrote:
路路路
Hello all :wink:
zaptel driver.
please ?
Best regard's
Pierre
App_rpt mailing list
App_rpt@lists.illiana.net
Hi men,
I use AsteriskNow from December without any problem, but I have recompiled
all the 1.4 sources to replace the precompiled original files. It works !
And I am fond of rPATH embedded distro :wink:
Pierre, sorry but I was too busy this week to reply ASAP.
I will send you a mail this Weekend, I promise it !
If you do exactly what is writed in my web page, you MUST have an Asterisk
playing app_RPT as I have.
I believe that you have a configuration problem only.
Have you sent me your config files ?
Best 73 to everybody !
F6HQZ,
Francois BERGERET.
-----Message d'origine-----
路路路
De : app_rpt-bounces@lists.illiana.net
[mailto:app_rpt-bounces@lists.illiana.net] De la part de Stephen Rodgers
Envoy茅 : vendredi 16 mars 2007 16:56
脌 : Asterisk Repeater Controler
Objet : Re: [App_rpt] ASTERISKNOW, pciradio and apt-rpt
Here's the problem: Asterisknow is precompiled without the app_rpt module
The best thing to do is go back to Fedora core 5 or Ubuntu Edgy, install the
appropriate kernel packages, then compile zaptel, libpri, and asterisk from
scratch. When you do a make menuselect on Asterisk to configure it, select
For Fedrora core 5, you'll need to install the kernel-devel package before
compling zaptel.
server, desktop, and amd64 versions and it is very easy to install the wrong
one.
Steve.
f1shs wrote:
Hello all :wink:
the zaptel driver.
work's ...
better.
the pciradio card with "modprobe pciradio" and it's working.
app-rpt please ?
Best regard's
Pierre
App_rpt@lists.illiana.net http://lists.illiana.net/mailman/listinfo/app_rpt
