Hi Eric,
The correct command is now 'sip reload', same as 'iax2 reload', 'rpt reload', etc. The only odd man out is 'dialplan reload', you'd expect 'extensions reload' if you're like me.
The best way to remember is just to type 'help sip' or 'help rpt' to get the correct command list.
If the commands are missing then it means that either the relevant '.conf' files don't exist (maybe empty) OR the modules.conf file is wrong. Try 'module show' there should be at least 43 modules shown and for a normal ACID install I think it is well over a hundred. If you look at the modules.conf file it should have as a minimum:
[global]
[modules]
autoload=yes
noload= chan_alsa.so
If you have that and there are still missing modules after a 'module reload' then there are a bunch of things missing from /usr/lib/asterisk/modules and something has gone terribly wrong. Try a restart now from the CLI.
Regards, John ZL4JY
________________________________
From: app_rpt-bounces@lists.illiana.net on behalf of Eric Fort
Sent: Sun 12/10/2008 2:24 PM
To: Don Russell; Asterisk Repeater Controler
Subject: Re: [App_rpt] asterisk console commands missing?
is this specific to app_rpt? all the sip, extensions, iax, and a few other commands are missing. I can see commands being depreciated but suddenly removed...what happened, when and where did the change come to be?
Eric
On Sat, Oct 11, 2008 at 6:07 PM, Don Russell <w9drr@live.com> wrote:
a lot of the command lines have changed a little bit
try
reload chan_sip.so
Don
Date: Sat, 11 Oct 2008 16:24:54 -0700
To: app_rpt@lists.illiana.net
actually looking a bit more it seems that many of the cli commands have been gutted from the acid installed version.
-e
On Sat, Oct 11, 2008 at 4:21 PM, Eric Fort <eric.fort@gmail.com> wrote:
I'm working on configuring my app_rpt node for autopatch and such. what happened to "sip reload" in the asterisk CLI? How does one reload sip.conf?
Eric
AF6EP
See how Windows Mobile brings your life together-at home, work, or on the go. See Now <http://clk.atdmt.com/MRT/go/msnnkwxp1020093182mrt/direct/01/>
