[App_rpt] asterisk console commands missing?
I’m working on configuring my app_rpt node for autopatch and such. what happened to “sip reload” in the asterisk CLI? How does one reload sip.conf?
Eric
AF6EP
actually looking a bit more it seems that many of the cli commands have been gutted from the acid installed version.
-e
Eric
AF6EP
I am trying out the new iso. getting a constant spew of “usbfs did not claim interface 3 before use”
ring any bells?
Don
Want to do more with Windows Live? Learn “10 hidden secrets” from Jamie. Learn Now
No. Not true.
Here's the output from 'help' sip on my ACID box:
test*CLI> help sip
              sip history Enable SIP history
          sip history off Disable SIP history
               sip notify Send a notify packet to a SIP peer
       sip prune realtime Prune cached Realtime object(s)
  sip prune realtime peer Prune cached Realtime peer(s)
  sip prune realtime user Prune cached Realtime user(s)
               sip reload Reload SIP configuration
            sip set debug Enable SIP debugging
         sip set debug ip Enable SIP debugging on IP
        sip set debug off Disable SIP debugging
       sip set debug peer Enable SIP debugging on Peername
        sip show channels List active SIP channels
         sip show channel Show detailed SIP channel info
         sip show domains List our local SIP domains.
         sip show history Show SIP dialog history
           sip show inuse List all inuse/limits
         sip show objects List all SIP object allocations
           sip show peers List defined SIP peers
            sip show peer Show details on specific SIP peer
        sip show registry List SIP registration status
        sip show settings Show SIP global settings
   sip show subscriptions List active SIP subscriptions
           sip show users List defined SIP users
            sip show user Show details on specific SIP user
And here's what happens when I thpe the command at the CLI prompt.
test*CLI> sip reload
Reloading SIP
  == Parsing '/etc/asterisk/sip.conf': Found
test*CLI>
Something else has to be going on.
Steve
WA6ZFT
-e
On Sat, Oct 11, 2008 at 4:21 PM, Eric Fort <eric.fort@gmail.com> wrote:
I'm working on configuring my app_rpt node for autopatch and such. what
happened to "sip reload" in the asterisk CLI? How does one reload sip.conf?
Eric
AF6EP
App_rpt mailing list
App_rpt@lists.illiana.net
usbfs does not have anything to do with the URI or modified USB fob.
It's a USB file system message. Disconnect all USB devices except the
FOB and see what happens.
Don Russell wrote:
I am trying out the new iso. getting a constant spew of "usbfs did not claim interface 3 before use"
ring any bells?
Don
_________________________________________________________________
http://windowslive.com/connect/post/jamiethomson.spaces.live.com-Blog-cns!550F681DAD532637!5295.entry?ocid=TXT_TAGLM_WL_domore_092008
is this specific to app_rpt? all the sip, extensions, iax, and a few other commands are missing. I can see commands being depreciated but suddenly removed…what happened, when and where did the change come to be?
Eric
On Sat, Oct 11, 2008 at 6:07 PM, Don Russell w9drr@live.com wrote:
a lot of the command lines have changed a little bit
try
reload chan_sip.so
Don
Date: Sat, 11 Oct 2008 16:24:54 -0700
To: app_rpt@lists.illiana.net
Subject: Re: [App_rpt] asterisk console commands missing?
-e
Eric
AF6EP
See how Windows Mobile brings your life together—at home, work, or on the go. See Now
There has to be something different about your install then. The vanilla
install works fine and has all of the commands.
Did you check the logs when starting asterisk manually to see what the
error messages are? Did you do a show modules to see what is and isn't
loaded?
We provide ACID for free and it does not come with commercial level
support. If you do something which is not documented in the ACID
sysadmin manual, then you cross the threshold where we can no longer
support you efficiently and you are on your own.
Steve
WA6ZFT
removed...what happened, when and where did the change come to be?
Eric
try
reload chan_sip.so
Don
-e
Eric
AF6EP
See how Windows Mobile brings your life together�at home, work, or on the
go. See Now <http://clk.atdmt.com/MRT/go/msnnkwxp1020093182mrt/direct/01/&gt;
