app_rpt as a controller (duplex=2)
Hi Steve and all;
I have setup node 2424 with app_rpt acting as the controller (so direct interface between the fob and the rptr); a couple of observations / questions:
1. I can't seem to change the frequency (pitch) or speed of the CW ident. I have the following in the morse stanza in rpt.conf:
[morse]
speed=30 ; Approximate speed in WPM
frequency=500 ; Morse Telemetry Frequency
amplitude=4096 ; Morse Telemetry Amplitude
; idfrequency=500
idfrequency=500 ; Morse ID Frequency
idamplitude=1024 ; Morse ID Amplitude
Is this a known issue or am I missing something?
2. Courtesy tones:
(a) When a remote link finishes transmitting, there is no courtesy tone. I believe the following line specifies the c'tone for the remote:
remotetx=|t(1633,0,50,3000)(0,0,80,0)(1209,0,50,3000)
Do we need to specify / enable the remotetx somewhere?
(b) Is the time delay between the drop of a carrier and the beginning of the c'tone (when using the repeater in local mode) variable? - the delay seems to be quite long.
3. PL tone:
In usbradio.conf I have the following:
txtoctype=notone ; notone - encode CTCSS and stop sending tone before unkeying TX
Is the time between the end of PL and drop of carrier variable (to avoid squelch crashes on non-commercial aka amateur radios!)
Thanks!
Ramesh.
Hey Ramesh,
Its payback time!
I can now help you with the courtesy tone issue!
You need the following in your rpt.conf
linkunkeyct=ct8 ; telemetry output when a link un-keys
I use this on 2259 and sends a piptone when the remote link unkeys the local Tx.
Next, the delay between the CT and any other telemetry is set in this part of the rpt.conf file, I have included that part of my rpt.conf:
[wait-times]
telemwait=2000 ; Time to wait before sending most telemetry
idwait=500 ; Time to wait before starting ID
unkeywait=2000 ; Time to wait after unkey before sending CT’s and link telemetry
calltermwait=2000 ; Time to wait before announcing “call terminated”
This is located immediately under the morse section you mention.
Hope this helps and I’m happy if it does!
Cheers,
Matt
Currently A71/G4RKY in Qatar
2009/4/11 Ramesh Dhami (VA3UV) Ramesh@va3uv.com
Hi Steve and all;
questions:
  1. I can’t seem to change the frequency (pitch) or speed of the CW
[morse]
; idfrequency=500
  1. Courtesy tones:
the c’tone (when using the repeater in local mode) variable? - the delay
  1. PL tone:
unkeying TX
Thanks!
Ramesh.
App_rpt-users@qrvc.com
Matt Beasant wrote:
Hey Ramesh,
Its payback time!
<-- Excellent Matt! - thanks changes made and working as required :slight_smile:
Cheers!
Ramesh.
