[App_rpt] app_rpt on EVB v FreePBX 2.5 update
Hi All,
Just a note that may be useful to others....
And no, please don't write me back to say "why would you do that". This is only meant as helpful information for those who decide they DO want to do it.
I upgraded my EVB-based system to FreePBX 2.5rc1.
My USB Fob would no longer function, and in fact generated a lot of log entries as rpt kept respawning itself, unable to detach the USB HID device.
It seems that the /usr/local/bin/app_rpt_helper routine...
grep "permiblast" /var/lib/asterisk/bin/freepbx_engine > /dev/null 2>&1
res=$?
if [ $res = 1 ]; then
     sed -i 's/\[ -e \/dev\/dsp ] && chown -R asterisk:asterisk \/dev\/dsp/\/usr\/local\/bin\/permiblast/' /var/lib/asterisk/bin/freepbx_engine
fi
...is no longer sufficient.
Now the lines in /var/lib/asterisk/bin/freepbx_engine look like this:
         [ -e /dev/dsp ] && chown -R $AMPDEVUSER:$AMPDEVGROUP /dev/dsp
So the match fails. Rather than muck up freepbx_engine too much, I just added a line right below that line in freepbx_engine:
           /usr/local/bin/permiblast
All is well now. :slight_smile: I suppose I should fix the app_rpt_helper script to look for the new format, because future updates in the FreePBX series are likely to keep this pattern and my next upgrade may well break things again.
Again, just FYI for those who may care.
Steve - N9YTY
Hi Steve,
I guess I should be more explicit in warning people to only use the
upgrade script that comes with the package!
This is a new version that uses FreePBX 2.4.1 in the works. For now
there are reasons not to try 2.5.
Take a look at http://www.xelatec.com/xipar/ for the new version later
this week.
73,
Steve Henke, W9SH
On Mon, Sep 15, 2008 at 2:32 PM, Steven Palm <n9yty@n9yty.com> wrote:
Hi All,
want to do it.
HID device.
res=$?
fi
break things again.
Steve - N9YTY
App_rpt mailing list
App_rpt@lists.illiana.net
...and that's why I said in my original email NOT to write back saying don't do it.
  I KNOW it's not approved, I was passing on info to others, not looking to be scolded, but I guess the temptation is too hard to resist. LoL.
  Steve
Hey consider it a mild chiding! Seriously I was just kidding. This
stuff is made to be broken. It's the only way we make any progress. So
have fun. Push it to the max. - 73, Steve
saying don't do it.
resist. LoL.
Steve
The “betas” of the Echolink and IRLP channel drivers and associated stuff is now available.
please download:
http://stats.allstarlink.org/ast-irlp-echolink.tar.gz
Jim,
I finally got my own dsl at KN6VR qth. Install date is 10/3. I’ll initially set up as a reflector and add radios as I can. IRLP and Echolink will be an intigral part. I’ll get you the ip address(es) as soon as they arrive so node numbers can be issued.
Eric
AF6EP
please download:
knowing IP addresses is no longer necessary for issuance of node numbers. That went away about 1 year ago.
Date: Thu, 18 Sep 2008 15:36:26 -0700
To: app_rpt@lists.illiana.net
Subject: Re: [App_rpt] New software available
Jim,
Eric
AF6EP
please download:
What do you need to issue node numbers?
Eric
Jim,
Eric
AF6EP
please download:
just fill out the form
Date: Thu, 18 Sep 2008 16:18:15 -0700
Eric
Jim,
Eric
AF6EP
please download:
