[App_rpt] ACID update procedure to install latest version ofAsterisk
I don't know if I asked.this or.not, but what will this upgrade procedures do to us that are also running chan_irlp?
Jim / K6JWN
------Original Message------
Sender: app_rpt-bounces@lists.illiana.net
To: Asterisk Repeater Controler
ReplyTo: Asterisk Repeater Controler
Subject: [App_rpt] ACID update procedure to install latest version ofAsterisk
Sent: Oct 11, 2008 8:56 PM
A later version of asterisk is available for ACID installs.
These upgrade instructions must be followed to the letter.
1. Change directories to /root
2. If you don't have an astupd.sh file STOP. Your ACID install is too
old and you will need to do a fresh install which will install the
latest version automatically. If you have to re-install, make a backup
of your config files in /etc/asterisk so that you can restore them to
the new install.
3. If you have an astupd.sh file, you will need to update it by
downloading a new version. Use the following wget command from the /root
directory to do this:
wget http://dl.allstarlink.org/installcd/astupd.sh
4. Once the new script is downloaded, type:
../astupd.sh
5. Your system will now be updated. Wait for the download and compile to
complete.
6. Reboot your system and check to see that your node is functioning
properly.
Steve
WA6ZFT
App_rpt mailing list
App_rpt@lists.illiana.net
Sent from my Verizon Wireless BlackBerry
Jim,
Unknown. This is uncharted territory. It may or may not work. I have no
way to test chan_irlp as I do not have an IRLP node and chan_irlp is not
technically supported by ACID yet. Besides not having an IRLP node to
test, all chan_irlp installs are somewhat cumbersome to do at this
point, so I have not devoted much attention to it.
Steve
WA6ZFT
Jim / K6JWN
the new install.
../astupd.sh
complete.
properly.
Steve
WA6ZFT
