[App_rpt] ACID update procedure to install latest version of Asterisk
A later version of asterisk is available for ACID installs.
These upgrade instructions must be followed to the letter.
1. Change directories to /root
2. If you don't have an astupd.sh file STOP. Your ACID install is too
old and you will need to do a fresh install which will install the
latest version automatically. If you have to re-install, make a backup
of your config files in /etc/asterisk so that you can restore them to
the new install.
3. If you have an astupd.sh file, you will need to update it by
downloading a new version. Use the following wget command from the /root
directory to do this:
wget http://dl.allstarlink.org/installcd/astupd.sh
4. Once the new script is downloaded, type:
./astupd.sh
5. Your system will now be updated. Wait for the download and compile to
complete.
6. Reboot your system and check to see that your node is functioning
properly.
Steve
WA6ZFT
with the instructions given wget does not overwrite astupd.sh directly. The old file remains. and the new file is saved as astupd.sh.1. It also needs to be made executable with chmod 770 before you can run it.
Eric
On Sat, Oct 11, 2008 at 8:56 PM, Stephen Rodgers hwstar@rodgers.sdcoxmail.com wrote:
  2. If you don’t have an astupd.sh file STOP. Your ACID install is too
the new install.
  1. If you have an astupd.sh file, you will need to update it by
  1. Once the new script is downloaded, type:
./astupd.sh
  1. Your system will now be updated. Wait for the download and compile to
complete.
  1. Reboot your system and check to see that your node is functioning
properly.
Steve
WA6ZFT
App_rpt mailing list
App_rpt@lists.illiana.net
Eric,
Thanks for catching this! I forgot about how cautious wget can be. My
two versions are identical and iI didn't key off of the date.
Steve
WA6ZFT
Eric
On Sat, Oct 11, 2008 at 8:56 PM, Stephen Rodgers < > hwstar@rodgers.sdcoxmail.com> wrote:
the new install.
./astupd.sh
complete.
properly.
Steve
WA6ZFT
As Eric Fort as pointed out (thanks Eric!), these was a problem in the
previous instructions. Here are the revised update instructions:
2. Do an ls to list the files. If you don't have an astupd.sh file STOP.
Your ACID install is too old and you will need to do a fresh install
which will install the latest version automatically. If you have to
re-install, make a backup of your config files in /etc/asterisk so that
you can restore them to the new install.
3. If you have an astupd.sh file delete it by typing:
rm astupd.sh
4. You will need to update it by downloading a new version. Use the
following wget command from the /root directory to do this:
5. Make it executable by typing:
chmod 755 astupd.sh
6. To update Asterisk, type:
./astupd.sh
7. Your system will now be updated if it is not running the latest
Asterisk version. Wait for the download and compile to
complete.
8. Reboot your system and check to see that your node is functioning
properly.
Steve
WA6ZFT
the new install.
./astupd.sh
complete.
properly.
Steve
WA6ZFT
Times they are a changing. Got a box lying around needing something to do. Thought I'd start another Limey Linux install for it. Wouldn't you know, the smallest CF card at Fry's was 4GB. I did find a 1GB CF at Sam's Club ($15 US). Turns out I had a 512MB card stuck in one of my laptops, so I'll swap that with the 1GB card. Still a lot of overkill but what do you do? :wink:
Randy Hammock KC6HUR
http://kc6hur.net/~rhammock/
http://irlp.kc6hur.net/
If there are no horses in heaven, then when I die, I want to go where they went.
Randy,
The big question is can you DD a 128mb image to a 512MB CF device and
still have it work? I've never tried this, but conceivably it should
work. I have initialized 512MB CF devices with make cf and it does work
for the 512MB Sandisk CF device I have.
Steve
WA6ZFT
they went.
I haven't tried this with limey linux, but, I put a fixed-size flash image
on larger CF cards all the time....I currently use 1GB kingston CF cards.
They're about the smallest/cheapest I can get new. The linux image I'm
using is a custom configured OpenWRT image that is roughly 64MB in size.
I primarily use pcengines ALIX boards....I'm just now starting to try them
with app_rpt....So far, so good!
73, David KB4FXC
On Fri, 17 Oct 2008, Stephen Rodgers wrote:
Randy,
Steve
WA6ZFT
> they went.
