I am sorry for my previous incorrect apparent incorrect statement about the nodesetup script… Apparently for some reason yesterday after working with both systems I was unable to get the nodesetup script to work…
Today the scripts worked… Not sure if it was network related or not… However I can tell you from two seperate Internet Service providers I ran this script with failure along with a fresh install in a VM which later this afternoon was able to pull my config files…
Officially here is what works… with the nodesetup script…
If your on a pure Dial installation this script should work if it doesn’t make sure you check resolv.conf and /etc/network/intefaces to ensure that the settings appear to be correct…
I am not sure as to what caused my 12 hr frustration with downloading the proper config files yesterday while using Dial…
however today the script for some reason worked…
Ubuntu 14.04LTS nodesetup now no longer works no matter what…
What you have to do is download the scripts in dial then copy the /etc/asterisk/ folder into the Ubuntu machine in the same location… Really easy plug and play…
I know I have hurt some feelings out their so I am sorry please forgive my earlier post… About when will the script be working again…
thanks so much 73’s
