Greetings,
A little background, ive installed ASL on intel Atom with the modified usb FOB cm108 and an HT for RF on 144MHz, have echolink enabled and all connections from echolink and allstar in and out establish perfectly, configured the port forwarding on the router and all worked well. The bigger plan is to putup at least 3 nodes in Pakistan linking 3 city coverage repeaters together in future while having the facility of world being connected to us or vise versa :D.
The issue in subject line has been posted many times before and I have gone through almost all of them for the past 3+ days now but to no avail. The node does not show up in the online nodes list nor on http://status.allstarlink.org/nodeinfo.cgi?node=48092 where as it does showup green in system-wide node list, the iax2 show registry shows
allstarlink1*CLI> iax2 show registry
67.215.233.178:4569 Y 48092 39.50.88.107:10880 60 Registered
have checked all possible network settings and no change from the first day it went online.
repeater@allstarlink1:~$ sudo cat /tmp/rpt_extnodes-temp | grep 48092
48092=[email protected]:4569/48092,39.50.88.107
repeater@allstarlink1:~$ sudo grep 48092 /var/lib/asterisk/rpt_extnodes
ran tcpdump on the allstarnode and I can see the packets being sent and acknowledged (below).
14:22:47.299321 IP 192.168.1.5.35422 > stats.allstarlink.org.http: Flags [S], seq 1388935083, win 29200, options [mss 1460,sackOK,TS val 1223790 ecr 0,nop,wscale 7], length 0
14:22:47.303605 IP 192.168.1.5.35424 > stats.allstarlink.org.http: Flags [S], seq 2416777296, win 29200, options [mss 1460,sackOK,TS val 1223791 ecr 0,nop,wscale 7], length 0
14:22:47.625331 IP stats.allstarlink.org.http > 192.168.1.5.35422: Flags [S.], seq 953265040, ack 1388935084, win 28960, options [mss 1452,sackOK,TS val 914084267 ecr 1223790,nop,wscale 7], length 0
14:22:47.625451 IP 192.168.1.5.35422 > stats.allstarlink.org.http: Flags [.], ack 1, win 229, options [nop,nop,TS val 1223872 ecr 914084267], length 0
14:22:47.625642 IP 192.168.1.5.35422 > stats.allstarlink.org.http: Flags [P.], seq 1:316, ack 1, win 229, options [nop,nop,TS val 1223872 ecr 914084267], length 315: HTTP: GET /uhandler.php?node=48092&time=1529313767&seqno=107&nodes=&apprptvers=0.327&apprptuptime=1875&totalkerchunks=0&totalkeyups=5&totaltxtime=33&timeouts=0&totalexecdcommands=1 HTTP/1.1
14:22:47.632208 IP stats.allstarlink.org.http > 192.168.1.5.35424: Flags [S.], seq 1293069211, ack 2416777297, win 28960, options [mss 1452,sackOK,TS val 914084267 ecr 1223791,nop,wscale 7], length 0
14:22:47.632359 IP 192.168.1.5.35424 > stats.allstarlink.org.http: Flags [.], ack 1, win 229, options [nop,nop,TS val 1223873 ecr 914084267], length 0
14:22:47.632735 IP 192.168.1.5.35424 > stats.allstarlink.org.http: Flags [P.], seq 1:217, ack 1, win 229, options [nop,nop,TS val 1223873 ecr 914084267], length 216: HTTP: GET /uhandler.php?node=48092&time=1529313767&seqno=108&keyed=0&keytime=1885 HTTP/1.1
14:22:47.953808 IP stats.allstarlink.org.http > 192.168.1.5.35422: Flags [.], ack 316, win 235, options [nop,nop,TS val 914084349 ecr 1223872], length 0
14:22:47.958200 IP stats.allstarlink.org.http > 192.168.1.5.35422: Flags [P.], seq 1:208, ack 316, win 235, options [nop,nop,TS val 914084350 ecr 1223872], length 207: HTTP: HTTP/1.1 200 OK
14:22:47.958288 IP 192.168.1.5.35422 > stats.allstarlink.org.http: Flags [.], ack 208, win 237, options [nop,nop,TS val 1223955 ecr 914084350], length 0
14:22:47.960295 IP 192.168.1.5.35422 > stats.allstarlink.org.http: Flags [F.], seq 316, ack 208, win 237, options [nop,nop,TS val 1223955 ecr 914084350], length 0
14:22:47.962823 IP stats.allstarlink.org.http > 192.168.1.5.35424: Flags [.], ack 217, win 235, options [nop,nop,TS val 914084350 ecr 1223873], length 0
14:22:47.966204 IP stats.allstarlink.org.http > 192.168.1.5.35424: Flags [P.], seq 1:208, ack 217, win 235, options [nop,nop,TS val 914084351 ecr 1223873], length 207: HTTP: HTTP/1.1 200 OK
14:22:47.966263 IP 192.168.1.5.35424 > stats.allstarlink.org.http: Flags [.], ack 208, win 237, options [nop,nop,TS val 1223957 ecr 914084351], length 0
14:22:47.968871 IP 192.168.1.5.35424 > stats.allstarlink.org.http: Flags [F.], seq 217, ack 208, win 237, options [nop,nop,TS val 1223957 ecr 914084351], length 0
14:22:48.284755 IP stats.allstarlink.org.http > 192.168.1.5.35422: Flags [F.], seq 208, ack 317, win 235, options [nop,nop,TS val 914084432 ecr 1223955], length 0
14:22:48.284887 IP 192.168.1.5.35422 > stats.allstarlink.org.http: Flags [.], ack 209, win 237, options [nop,nop,TS val 1224037 ecr 914084432], length 0
14:22:48.296156 IP stats.allstarlink.org.http > 192.168.1.5.35424: Flags [F.], seq 208, ack 218, win 235, options [nop,nop,TS val 914084433 ecr 1223957], length 0
14:22:48.296248 IP 192.168.1.5.35424 > stats.allstarlink.org.http: Flags [.], ack 209, win 237, options [nop,nop,TS val 1224039 ecr 914084433], length 0
Please advise
73’s
Shehzad AP2CJ
