Been digging around and haven’t found anything about
Orangepi 3 on Allstar.
Anyone get lucky.
Bruce
Ve3bv
53554
I would say your bet bet is installing a compatible rasbian os and then follow this
Did you ever have any luck with this? been fighting a 3B for a bit now. I’m able to install their debian server package and install asl3 afterwards but getting lots of errors and simple usb is not communicating. any info if you made progress would be appreciated as i would really like to use the emmc board instead of the sd card method. System i’m trying to use:
Operating System: Debian GNU/Linux 12 (bookworm)
Kernel: Linux 5.10.160-rockchip-rk356x
Architecture: arm64
As long as you can install normal Debian 12 bookworm and whatever provides that kernel has a corresponding headers package that’ll work properly with DKMS, it should in general just work. I’m using ASL3 on a generic arm64 platform and it works fine.
Now, if that kernel has problems with things like snd_pcm_oss or items needed to build any of the DAHDI modules, then you’re not going to have success.
so far, the orangepi is winning but I won’t be defeated! ![]()
