Announcement are global now?
The announcements, like time and connect massages are suddenly transmitter global instead of local. I’am the Shari usb-unit connected to a Pi5. This was never before. I want those things only transmitter global. What has happened? I can not find any settings, or is it just me?
Bump <<<<<<<<<<<<<<<<<<<<<<<<
It looks that my problem is solved: I have set 'echolinkdefault= 3'
It was on '2'
I've heard this randomly from some nodes. Time and weather announcements, morse ID's, etc. for a while now, but nothing consistent.
No suggestions because I've not experienced my nodes doing that, but I have heard this in the wild.
On Oct 26, 2026, at 12:18, William [email protected] wrote:
Someone replied to a topic you are Watching.
| PE1BMM
October 26 |
If you are hearing time and weather chances are the owner has it set that way, system id is normal.
There are two different ways to playback audio - localplay and playback. Using localplay audio only goes out on directly-connected channels. The playback sends that audo out over the IAX links as well. There are some scripts and tools out there that are using playback by default or by choice. Built-in telemetry and announcements are controlled by their respective settings in rpt.conf as the always have. Things that speak time, IP addresses, weather, etc. are not telemetry-driven and promulgate out over network links specifically due to the choice between localplay and playback.
So, why do I sometimes hear telemetry, like node connect and disconnect messages, from remote nodes? I know it isn't coming from my stuff locally, because I hear it on non-Allstarlink clients, and on direct IAX connections to nodes that send no telemetry. AFAIK, there should be no way to make that global, but I have definitely heard that. Just this morning, in fact, so I'm confused about why that would be happening.
It was clearly a direct feed, not a node talking to another node over RF, which I have also heard before.
| N8EI ASL Community Admin
October 26 |
It's not global. It depends on a number of factors including the method of connecting, setting in Rpt.conf for the node, etc. See Telemetry Messages - AllStarLink Manual
You may be hearing telemetry from a connected node who is playing audio globally (playback)
There is no setting to stop that. It is treated as any other audio from the connected node.
I should add that 'playback' audio should be used with careful thoughtfulness but many do not realize some of the implications.
I may be, but why would a node be playing connect/disconnect messages globally?
That shouldn't even be possible.
Yet, I hear it every now and then, and others on nets comment about it, so I know it's not just me.
It's different when you've got a weird RF path between two nodes. I've heard tata, too. But this is clearly direct from someone's node.
I wish I could make it happen on demand on a node I control.
| Mike
November 7 |
N2DYI:
It's entirely possible and, in fact, desired in some cases. Otherwise, the rpt playback command wouldn't exist.
If you don't want to hear normal network telemetry, you have these settings...
cop,37 ; Foreign Link Local Output Path Disable
cop,36 ; Foreign Link Local Output Path Enable
cop,38 ; Foreign Link Local follow local telem
cop,39 ; Foreign Link Local Output Path On-/-Timed
you can assign/execute as dtmf command or command line them.
All telemetry is sent to all connected stations through iax, no matter your settings.
You have the setting if you do/not want to say it on your node. And again, it does not stop someone from doing stupid things without thought about network issues beyond what you can control.
If you want to see what station is the culprit, watch asterisk in the foreground.
I will add, in some cases, where a multi-connection link that passes through a rf only node, it can be unavoidable.
OK, so how do you actually make that happen, then? I understand rpt playback, but how would you force standard node connect/disconnect messages, no external scripts or anything, to play back globally? Because that is what I hear going on occasionally.
November 7 |
N2DYI:
