Announce: ACID version 0.9 released
ACID 0.9 can be downloaded from dl.allstarlink.org.
This is based on Centos 5.3,
ACID version 0.9 contains:
app_rpt.c version 0.203:
1. Added tone burst detection for our European friends.
2. Fixed W9SH's audio format mismatch on startup bug (very unusual config)
3. Added check for RPT_A version of zaptel.(We need this to fix
autopatch call progress issues)
4. Fixed strange keying problem with new version of IAXRPT.
5. Fixed more hang problems and unreliability with simplex
repeater/remote base nodes
6. Fixed telemetry propagation when downrev (non-newkey1) systems present
7. Fixed irlp/echolink tx audio distortion at high gains
8. Resolve spurious time out message.
9. Fixed problems with simplex autopatch.
10. Fixed serial rx hang problem with Kenwood remotes
11. Fixed problem with serial baud rate being wiped out on Kenwood
TMG-707 radios (using USB device).
12. Added delay statements to FT-897 serial commands on remote base
bacause some FT897 radios do not accept the complete sequence of
commands without some delay between the commands.
13. Fixed Mantis bug 0000032: ID Talkover CW loops causes RX audio to chop
14. Add beaconing node stanza key to allow the repeater ID to be sent
regardless of whether there has vin activity or not.
15. Fix "always enabled" bug with holdofftelem feature.
16. Add nounkeyct and holdofftelem node stanza confiiguration options.
17. Add COP functions 49 (NOICE) and 50 (NOICD) to enable and disable
all Allstar, Echolink and IRLP connections.
18. Fixed telemetry control parameters.
19. Resolve mantis bug 0000016: Quick unkeys and rekeys over the network
queue a link Courtesy Tone
20.Add nolocallinkct key to node stanza so that nodes co-hosted on the
same server can optionally send no link courtesy tone.
21. Added arbitary tone generation as COP function 48.
22.Add link activity timer function to resolve Mantis feature request
0000010.
23. Better control of IRLP connect and disconnect messages through
config file options and DTMF commands, and added irlpplay CLI command to
assist in queuing the messages one at a time.
24. Fixed Mantis bug 0000011 pad test broken
25. Fixed Mantis bug 0000004 out-of-band telemetry sent when link in
monitor
26.Added antenna select for FT-950
27. Cleaned up debug messages for FT-950
28, Added FT-950 support
29. Fix alarm setup with multiple uChameleons
chan_irlp.c version 0.27:
1, Fixed problem with enabling and disabling irlp connect/disconnect
announcement mmessages. Use irlpplay Asterisk cli command.
2, Don't update DB when operating in experimental reflector mode.
3. Resolve Mantis bug 0000001 by disabling Asterisk's DTMF decoder on
IRLP incoming audio.
4. Major changes to add experimental reflector support and ability to
connect to expermental reflectors.
chan_echolink.c version 0.21:
1, Resolved Mantis Bugs 0000026 and 0000038
2, Failure to connect to certain Echolink nodes.
3, Removed multiple initial packets.
chan_usbradio.c/xpmr has been updated:
1, CM108AH (new uri) support
2, Add support for CM119 sound chips
3, Improve carrier squelch operation.
4. Allow for hot plug functionallity of USB devices
5. Add rxontime parameter for simplex nodes. (anti-pingpong)
6. Fix TX hang problem.
7. Resolve Segfault when txmixa=voice and txtone is set to zero.
8. Sync with Xelatec version. Add TX blanking time.
9. Fixed mode steering problem and clipping in xpmr
Final Note: Someone needs to test the astupd feature on older ACID
installs and either say it works or doesn't work. Do not use astupd on
older installs until we have confirmation that it is working, play it
safe and do a complete install from CD unless this is reported to be
working from several sources.
Steve
WA6ZFT
Keith Williamson wrote:
I decided to start from scratch with the new v0.9 CentOS 5.3 iso.
All went fine and my Allstar node (2541) registered fine and my echolink
node registered fine. However, when I attempted a NEW install of irlp, the
irlp-centos-install script bombed out on line 423 when it attempted to run
/home/irlp/bin/pgp. The pgp executable is missing. I checked with a "tar
-tzf irlp-centos-dist.tgz" (in irlp-install-files) and it is indeed
missing.
Should I just do a yum install of pgp and link pgp into /home/irlp/bin or
are there perhaps more files missing from the irlp-centos-dist.tgz?
Keith, KF7DRV
Hi.
Looking at the installcd directory at dl.allstarlink.org, I only see an
iso
for CentOS 5.1 dated March 9.
Also, I have been trying to do the IRLP setup for a NEW IRLP node and the
install script bombs out when it gets to the point of doing the wget of
irlp-centos-dist.tgz. This morning I was able to manually download it
with
wget but then tar complained that it wasn't a valid gzip'd file. Just a
few
minutes ago, it appeared as if the file is not even in the installcd
directory anymore.
Is the installcd folder just in flux for a day or so while the switchover
is
made to 0.9 or am I missing something fundamental here?
Keith, KF7DRV
ACID 0.9 can be downloaded from dl.allstarlink.or<
http://dl.allstarlink.org>
g
config)
present
chop
0000010.
monitor
Steve
WA6ZFT
App_rpt-users@qrvc.com
The ISO usually doesn't change when an upgrade is release, because most
of the code is downloaded over the network using install scripts.
The irlp-centos-dist.tgz tarball got inavertently deleted during the
move over from dltest. It has since been restored.
Steve
WA6ZFT
Good question....
The file on dl.allstarlink.org is missing the mentioned binary. We are
working to regenerate the correct binary with everything necessary
included.
The same faulty file is in our revision control system as well! Grrrr....
Please be patient, we'll announce when the file has been updated....
Steve
WA6ZFT
On Thu, Sep 17, 2009 at 7:07 PM, Stephen Rodgers < > hwstar@rodgers.sdcoxmail.com> wrote:
On Wed, Sep 16, 2009 at 10:00 PM, Stephen Rodgers < >>> hwstar@rodgers.sdcoxmail.com> wrote:
BTW i just updated node 2181 using the update script
i went from 0.174 to 0.203
remotely via ssh, seamed to go fine i guess time will tell.
seems i am always behind. hihi!
the new rebuilt 2180 node was a raw install from the
latest DL iso.
Thanks in Advance
Bob Brown, WØNQX
Kansas City Metro Area
http://sm0kenet.net
http://byrg.net
http://kcdstar.byrg.net
“Surely you can’t be serious?” “Of course I am, and don’t call me Shirley.”
Jonathan Swift - “May you live every day of your life.”
On Thu, Sep 17, 2009 at 00:00, Stephen Rodgers hwstar@rodgers.sdcoxmail.com wrote:
  2. Fixed W9SH’s audio format mismatch on startup bug (very unusual config)
  1. Fixed serial rx hang problem with Kenwood remotes
  2. Fixed problem with serial baud rate being wiped out on Kenwood
  3. Added delay statements to FT-897 serial commands on remote base
15. Fix “always enabled” bug with holdofftelem feature.
0000010.
monitor
2, Don’t update DB when operating in experimental reflector mode.
3. Resolve Mantis bug 0000001 by disabling Asterisk’s DTMF decoder on
  1. Major changes to add experimental reflector support and ability to
  1. Add rxontime parameter for simplex nodes. (anti-pingpong)
  2. Fix TX hang problem.
  3. Resolve Segfault when txmixa=voice and txtone is set to zero.
  4. Sync with Xelatec version. Add TX blanking time.
  5. Fixed mode steering problem and clipping in xpmr
installs and either say it works or doesn’t work. Do not use astupd on
Steve
WA6ZFT
missing.
Keith, KF7DRV
Hi.
iso
with
few
directory anymore.
is
Keith, KF7DRV
g
config)
present
chop
0000010.
monitor
Steve
WA6ZFT
Steve
WA6ZFT
Good question....
included.
Steve
WA6ZFT
The irlp update script has been updated inside the irlp-centos-dist.tgz
tarball to download tyhe pgp binary from IRLP's webserver. A new tarball
was uploaded to dl.allstarlink.org. I've done a dry run and it now
downloads the pgp file correctly and completes the install (without
sending the order into to the IRLP folks).
Someone now needs to step forward and do a live install and report back
on the results of that :wink:
Steve
WA6ZFT
On Thu, Sep 17, 2009 at 7:07 PM, Stephen Rodgers < >> hwstar@rodgers.sdcoxmail.com> wrote:
On Wed, Sep 16, 2009 at 10:00 PM, Stephen Rodgers < >>>> hwstar@rodgers.sdcoxmail.com> wrote:
I just used the astupd.sh script to update my node 2250.
All worked OK but had to reboot the node after the update.
All seems fine now :slight_smile: app_rpt version 0.203
Matt
G4RKY
2009/9/20 Bob Brown - WØNQX bbrown@byrg.net
latest DL iso.
Thanks in Advance
Bob Brown, WØNQX
http://sm0kenet.net
http://byrg.net
0000010.
monitor
Steve
WA6ZFT
Steve
WA6ZFT
Ran irlpsetup.sh (for reinstall of my old EchoIRLP node). Reinstall seemed to go OK, but I am still unable to connect to IRLP nodes (long wait, then 'connection failed' message). Upon reboot, I did see a message about 'no such command irlp db load...' but it disappeared before I got a good look at it.
John / WB5NFC
Steve
WA6ZFT
John / WB5NFC
Hi John,
I tried this on my system of which IRLP was installed in dry-run mode
(without sending install data to the irlp folks), but I didn't see the
db load error message. Can you try the following and post the specific
error message to the list?:
Try commenting out the rc.irlp line in /etc/rc.d/rc.local like this:
#/home/irlp/custom/rc.irlp
Then run the command manually once you are logged in as root:
cd /home/irlp/custom
./rc.irlp
This should print out the error message we are looking for...
Steve
WA6ZFT
Ran irlpsetup.sh a second time and now IRLP seems to be working. Tracking down and commenting out inappropriate EchoIRLP lines from my original install now.
Example:
/home/irlp/custom/environment: line 128:
/home/EchoIRLP/custom/echo_environment: No such file or directory
Starting IRLP services:
irlpd...
done.
Updating IRLP hosts file... (put in background) done!
Updating IRLP dns server... (put in background) done!
Enabling IRLP node... /home/irlp/custom/environment: line
128: /home/EchoIRLP/custom/echo_environment: No such file or directory
done!
[root@wb5nfc ~]# /home/irlp/custom/environment: line 128:
John
