Android IAXRPT stuck PTT
All this talk of Android IAXRPT got me interested. I installed it
(v1.13). Sometimes when I connect to my node, the PTT on the node will
stick on. There is no indication of this in the app and no audio going
through, just dead air. (Luckily I had a radio monitoring and
discovered this issue quickly.) Other times I connect and it works
just fine--PTT follows the PTT button. What's going on here? Why does
it transmit without PTT pressed?
On IAXRPT for Windows (running in Wine on OS X), PTT behaves correctly.
I also have Zopier set up, but I configured this for VOX. I hit the
mute button when I don't want to transmit. It works just fine.
Relevant configuration stanzas below. (Let me know if you need more.)
Tom KD7LXL
iax.conf:
[iaxrpt]
username=iaxrpt
type=friend
context=radio-gui
auth=md5
secret=xxx
host=dynamic
disallow=all
allow=gsm
allow=ulaw
allow=g726aal2
notransfer=yes
[tomsphone] ; Zoiper Setup
username=tomsphone
type=friend
context=tomsphone
host=dynamic
auth=md5
secret=xxx
disallow=all
allow=ulaw
allow=g726aal2
allow=gsm
codecpriority=host
transfer=no
callerid="KD7LXL"
extensions.conf:
[radio-gui]
exten => 41702,1,rpt(41702|X)
exten => 1001,1,rpt(1001|X)
[tomsphone]
exten => 41702,1,answer()
exten => 41702,n,Playback(rpt/connected)
exten => 41702,n,rpt(41702|Pv)
exten => 1001,1,answer()
exten => 1001,n,Playback(rpt/connected)
exten => 1001,n,rpt(1001|Pv)
I’ve personally found, I had an old samsung galaxy phone, that leaving the app going all of the time in the background would cause things like that to happen. I would normally fire the app up to use it and then shut it down when down.
However I just got a new phone yesterday so I will have to reevaluate how it behaves on my new phone.
N1XBM
Apparare Scientor
Paratus Communicare
Allstar Node # 27086, 41540, 41812, 42086, 42658, 42657
www.radioguysrepeaternetwork.com
For some reason I did not get Tom’s message from the list.
Tom,
Which context are you connecting to?
On 07/21/2016 07:41 PM, Robert Newberry
wrote:
    I've personally found, I had an old samsung galaxy
down.
N1XBM
    Apparare Scientor
    Paratus Communicare
    [www.radioguysrepeaternetwork.com](http://www.radioguysrepeaternetwork.com)
1st Law of Logic
[email protected]http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-usershttp://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users
In trying to confirm this, I exited (via the menu, not just returning
to home screen), reopened the app, and connected a couple times in a
row and experienced the behavior every time.
However, my goal is to leave this connected and monitoring the
repeater all day instead of carrying an HT, so I'd love if it were
stable enough for that. Auto-reconnect would be nice too.
Tom KD7LXL
On Thu, Jul 21, 2016 at 4:41 PM, Robert Newberry <[email protected]> wrote:
I've personally found, I had an old samsung galaxy phone, that leaving the
when down.
This is the context I use for AndroidIAX
[iax-client]��� ��� ��� ��� ; for IAX VIOP clients.��� ��� ��� ���
exten => ${NODE},1,Ringing
exten => ${NODE},n,Wait(3)
exten => ${NODE},n,Answer
exten => ${NODE},n,Set(NODENUM=${CALLERID(number)})
exten => ${NODE},n,Playback(rpt/node|noanswer)
exten => ${NODE},n,SayDigits(${EXTEN})
exten => ${NODE},n,Set(CALLERID(num)=0)
exten => ${NODE},n,Rpt,${NODE}|P|${CALLERID(name)}
exten => ${NODE},n,Hangup
exten => ${NODE},n(hangit),Answer
exten => ${NODE},n(hangit),Wait(1)
exten => ${NODE},n(hangit),Hangup
down.
N1XBM
    Apparare Scientor
    Paratus Communicare
1st Law of Logic
Steve,
Good question. Sorry I wasn't clear on that. Android IAX and Windows
IAXRPT both connect to iaxrpt context. I only have the PTT issues with
Android IAX.
Reading the context you just posted, I'm trying to understand which
parts of it are critical. The telemetry drives me crazy so I cut that
out. Do I need to maybe add the Ringing, Wait, and Answer commands? (I
did try adding Answer at one point with no difference in behavior.)
Tom KD7LXL
On Thu, Jul 21, 2016 at 4:53 PM, Steve Zingman <[email protected]> wrote:
For some reason I did not get Tom's message from the list.
Tom,
Tom,
the relevant line is
If you could try the complete context we can then prune it if it fixes the issue.
Steve
Tom,
Steve,
Android IAX.
Tom KD7LXL
1st Law of Logic
I pasted this in verbatim and now connections fail:
[Jul 22 08:33:01] NOTICE[13402] chan_iax2.c: Rejected connect attempt
from 71.231.22.13, request '41702@iax-client' does not exist
Apparently the ${NODE} variable is never populated.
The big difference I notice is this one has P and my earlier config had an X:
What does that mean? I know Pv sets VOX mode and I understood X to
mean DTMF to enable/disable PTT. How does Android IAX signal PTT?
Tom
[iax-client] ; for IAX VIOP clients.
Opps, Sorry.
Add NODE = 41702 above it.
Tom
1st Law of Logic
As you can tell, I'm very new to this and unfamiliar with the standard
variables, etc. Okay, added NODE = 41702 to the [globals] stanza and
now it works! I tried a few connects/disconnects and had no odd PTT
behavior.
Then I went back and removed the Playback commands as I prefer. It still works.
What is the difference between the P and X option in the Rpt command?
That seems to be the major difference here. All of the tutorials I found use X.
I have a hard time finding canon documentation for this stuff.
By the way, I was able to break (node graph was missing)
http://stats.allstarlink.org/getstatus.cgi?41702 by putting a space in
the CallerID. I guess that's not allowed.
Thanks for your help. The quick replies made for easy troubleshooting.
Tom KD7LXL
On Fri, Jul 22, 2016 at 8:44 AM, Steve Zingman <[email protected]> wrote:
Opps, Sorry.
Tom,
Thanks for the feedback. Glad to know things are working. I have a pretty well commented set of config files atn <https://github.com/N4IRS/AllStar&gt;
We will also look into the CallerID issue. We are preparing to put AndroidIAX up on the Google PlayStore.
Steve
Opps, Sorry.
behavior.
Tom KD7LXL
1st Law of Logic
As we all (obviously) know, VOIP protocols, such as IAX2, may be used for
transport of audio/signalling for uses other then phone calls, such as radio, in this case.
Therefore, an endpoint that accepts a VOIP connection processes/utilizes different
methodologies for a radio connection and a “traditional telephony” (like a phone call)
type of connection.
The “X” is used for a radio-style connection, and indicates to app_rpt that it is not to authenticate
the call (that is, authentication was done in the dialplan previous to “sending” it to app_rpt). This is
necessary for scenarios such as use with IAXRPT, where user authentication is done via means external
to app_rpt.
The “P” is used to make app_rpt accept a “traditional” telephony-style (VOIP SIP, IAX2, etc, or other telephony
interface, such as DAHDI) connection, and allow access to a node via a “telephone” call.
These are 2 very different operating environments.
Jim
From: [email protected] [email protected] on behalf of Tom Hayward [email protected]
Sent: Friday, July 22, 2016 9:10 AM
To: Steve Zingman
Cc: [email protected]
Subject: Re: [App_rpt-users] Android IAXRPT stuck PTT
On Fri, Jul 22, 2016 at 8:44 AM, Steve Zingman [email protected] wrote:
Opps, Sorry.
As you can tell, I’m very new to this and unfamiliar with the standard
behavior.
the CallerID. I guess that’s not allowed.
Tom KD7LXL
[email protected]
and scroll down to the bottom of the page. Enter your email address and press the “Unsubscribe or edit options button”
Does this mean I need to be using two different contexts for IAXRPT
and Android IAX? As I said, I previously had "X" and now have "P" and
am using the same context for both Windows and Android app. From the
GUI, they appear to be very similar apps so I assumed they behaved the
same in terms of connection style. But as I reported, the X mode was
sometimes locking PTT on my node when connecting from Android. I never
experienced this from Windows IAXRPT.
Tom KD7LXL
On Fri, Jul 22, 2016 at 9:29 AM, Jim Duuuude <[email protected]> wrote:
The "X" is used for a radio-style connection, and indicates to app_rpt that
it is not to authenticate the call (that is, authentication was done in the dialplan previous to
"sending" it to app_rpt). This is necessary for scenarios such as use with
IAXRPT, where user authentication is done via means external to app_rpt.
The "P" is used to make app_rpt accept a "traditional" telephony-style (VOIP
SIP, IAX2, etc, or other telephony interface, such as DAHDI) connection, and
allow access to a node via a "telephone" call.
Personally, I dont know anything about the Android version. I dont
even have a device that runs Android (or IOS either!!).
I think this definitely a question for someone that knows the Android stuff.
Jim
Sent: Friday, July 22, 2016 9:40 AM
To: Jim Duuuude
Cc: Steve Zingman; [email protected]
“sending” it to app_rpt). This is necessary for scenarios such as use with
and Android IAX? As I said, I previously had “X” and now have “P” and
Tom KD7LXL
