Alternate IAX port >> Registered ok but not listed?
I am unable to connect to my node from the webtransceiver and don’t see it listed on the active nodes page. I use an alternate iax port because i have to.
From reading other posts… it seems I
may need an admin to change my iax port from 4569 to what I now want to use
which is 4570? thoughts?
My registration is still showing
4569 and am forwarding 4570 on my router to my ACID box.
cruiser*CLI> iax2 show registry
Host
dnsmgr Username
Perceived
Refresh State
:4569
N 28970 :4569
60 Registered
I’m not seeing my node show up and
believe this is the cause. In my iax.conf I have bindport set 4570 and also in
server config under network I set port 4570 on the portal.
looking at rpt_extnodes i see my node listed with the correct port…
28970=radio@:4570/28970,
[general]
bindaddr=0.0.0.0
bindport=4570
register=28970:@register.allstarlink.org
I had already done that in the portal but it still wasn’t working. As an experiment, i changed everything back to the original 4569 port and forwarded that on my router. I could then connect with the webtransceiver. However i can’t leave it there and need to get it to work on an alternate port. It seems from my testing that something is hard set to port 4569 on the allstar end of things?
ideas?
thank you
On Tue, Oct 9, 2012 at 3:47 AM, Ken ke2n@cs.com wrote:
Yes – you need to log onto the portal and get to the server configuration tab – there is a place there to change to port number that the registration server is talking to.
Ken
From: app_rpt-users-bounces@ohnosec.org [mailto:app_rpt-users-bounces@ohnosec.org] On Behalf Of Kevin Oleniczak
Sent: Tuesday, October 09, 2012 12:09 AM
To: app_rpt-users@ohnosec.org
Subject: [App_rpt-users] Alternate IAX port >> Registered ok but not listed?
From reading other posts… it seems I may need an admin to change my iax port from 4569 to what I now want to use which is 4570? thoughts?
My registration is still showing 4569 and am forwarding 4570 on my router to my ACID box.
:4569 N 28970 :4569 60 Registered
I’m not seeing my node show up and believe this is the cause. In my iax.conf I have bindport set 4570 and also in server config under network I set port 4570 on the portal.
[general]
bindaddr=0.0.0.0
bindport=4570
You need to change the bindport=4570 in the IAX.conf file if you
want to use something other than 4569. Then forward the ports in the
router.
You may need to reboot your server for it to take affect.
Jon VA3RQ
On 10/9/2012 8:29 PM, Kevin Oleniczak
of things?
  ideas?
  thank you
wrote:
              Yes
talking to.
Ken
[mailto:app_rpt-users-bounces@ohnosec.org ]
                  I
because i have to.
                    From
                    My
                    cruiser*CLI>
iax2 show registry
                    Host
Refresh State
                    <myip>:4569
N 28970 :4569
60 Registered
                    I’m
                    looking
correct port…
[general]
bindaddr=0.0.0.0
bindport=4570
App_rpt-users@ohnosec.orghttp://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users
OK I tried changing the bind port in IAX.conf to 4570 but the node
I’m working on also doesnt seem to take. It still reports port 4569
to the other nodes.
Somewhere along the line this used to work, now it is broken.
I am using the latest svn 0.306.
Is there another place that this needs to be changed?
Jon
<-- Hi Jon! - may be that explains why node 2424 (220 repeater) no longer accepts incoming calls! - it's supposed to be listening on 4568.
R.
On 11/10/2012 11:22 PM, REDBUTTON_CTRL wrote:
OK I tried changing the bind port in IAX.conf to 4570 but the node I'm
working on also doesnt seem to take. It still reports port 4569 to the
other nodes.
I finally got this working. To close this out, here’s what i found.
It turns out the issue was that i had binaddr listed above bindport in iax.conf. In order for bindport to get used, it has to appear in the file before bindaddr.
thanks to all who helped with this.
On Tue, Oct 9, 2012 at 8:40 PM, Tim Sawyer tim.sawyer@mac.com wrote:
Try changing your IP address setting on the Portal to either DHCP or Fixed. I don’t know what the VoIP setting you currently have it set for does.
Tim
:wq
ideas?
thank you
Ken
[general]
bindaddr=0.0.0.0
bindport=4570
I check the node I am working on and it has the following:
; Inter-Asterisk eXchange driver definition
  [general]
  bindport=4570
  bindaddr=0.0.0.0
  disallow=all
  allow=gsm
  allow=g726aal2
  allow=ulaw
  jitterbuffer=yes
  forcejitterbuffer=yes
  dropcount=2
  maxjitterbuffer=4000
  maxjitterinterps=10
  resyncthreshold=1000
  maxexcessbuffer=80
  minexcessbuffer=10
  jittershrinkrate=1
  tos=0x1E
  autokill=yes
  delayreject=yes
  ;iaxthreadcount=30
  ;iaxmaxthreadcount=150
So bindport is set correctly but the node is still reporting to all
the others as port 4569. in the RPT_extnodes list.
I have port 4570 open in the router but the node is not reachable
because of this.
28505=radio@66.206.229.10:4569/28505,66.206.229.10
  On 10/12/2012 12:12 AM, Kevin Oleniczak
wrote:
  I finally got this working. To close this out, here's
what i found.
Tim
:wq
On Oct 9, 2012, at 5:29 PM, Kevin Oleniczak <kevinoleniczak@gmail.com >
end of things?
                ideas?
                thank you
AM, Ken ke2n@cs.com
wrote:
                          Yes
to.
Ken
2012 12:09 AM
                              I am
                                From
                                My
to my ACID box.
                                cruiser*CLI>
iax2 show registry
                                Host
dnsmgr Username
                                <myip>:4569
N 28970
:4569 60
Registered
                                I’m
portal.
                                looking
[general]
bindaddr=0.0.0.0
bindport=4570
Just for drill… if you move into /etc/asterisk and do “fgrep 4569 *” and “fgrep 4570 *”.
What do get back?
Here’s what I see with my alternate port 4565 (on XIPAR) :
iax_general_custom.conf:bindport=4565
rpt.conf:28695 = radio@127.0.0.1:4565/28695,NONE ;KVHF 10m Receiver - ME
rpt.conf:12958 = radio@209.213.169.196:4565/12958,NONE ;KVHF 10m Transmitter
Robert A. Poff
Loganville, PA
S/V Loon
1983 Hunter 34
Havre de Grace, MD.
WB3AWJ - Allstar 27784
Powered by Linux
have you changed the port you use AT the portal? ie the server configuration, network configuration tab?
if you have a node that needs to be on a different port, the underlying server needs to be moved both at the end, as well as at the mother ship.
had the same problem until i had everything lined up.
what i found.
Tim
:wq
end of things?
                ideas?
                thank you
AM, Ken ke2n@cs.com
wrote:
                          Yes
to.
Ken
2012 12:09 AM
                              I am
                                From
                                My
to my ACID box.
                                cruiser*CLI>
iax2 show registry
                                Host
dnsmgr Username
                                <myip>:4569
N 28970
:4569 60
Registered
                                I’m
portal.
                                looking
[general]
bindaddr=0.0.0.0
bindport=4570
On my node 28599 here’s where I had to make mods to reflect using port 4570:
root@nat:/etc/asterisk# grep 4570 *
iax.conf:bindport=4570
iax_rpt_custom.conf:bindport=4570
There are no ports indicated in rpt.conf.
It all works fine, others can connect, and webtransceiver works fine.
I also do not use portal configuration as it won’t let me ser CW ID at 30 WPM
GeorgeC
----- Original Message -----
Robert Poff
Sent: Friday, October 12, 2012 8:32 AM
Subject: Re: [App_rpt-users] Alternate IAX port >> bind port not working
What do get back?
rpt.conf:28695 = radio@127.0.0.1 :4565/28695,NONE ;KVHF 10m Receiver - ME
rpt.conf:12958 = radio@209.213.169.196 :4565/12958,NONE ;KVHF 10m Transmitter
Robert A. Poff
  •    Loganville, PA*
S/V Loon
  •    1983 Hunter 34*
  •    Havre de Grace, MD.*
  •    Powered by Linux*
comment out or remove
bindaddr=0.0.0.0
definition
    [general]
    bindport=4570
    bindaddr=0.0.0.0
    disallow=all
    allow=gsm
    allow=g726aal2
    allow=ulaw
    jitterbuffer=yes
    dropcount=2
    maxjitterinterps=10
    maxexcessbuffer=80
    minexcessbuffer=10
    jittershrinkrate=1
    tos=0x1E
    autokill=yes
    delayreject=yes
    ;iaxthreadcount=30
all the others as port 4569. in the RPT_extnodes list.
because of this.
for does.
Tim
:wq
                  ideas?
                  thank you
wrote:
                            Yes
talking to.
Ken
On Behalf Of Kevin
Oleniczak
2012 12:09 AM
                                I am
have to.
                                  From
                                  My
                                  cruiser*CLI>
iax2 show registry
                                  Host
dnsmgr Username
Perceived Refresh
State
                                  <myip>:4569
N 28970
:4569 60
Registered
                                  I’m
portal.
                                  looking
[general]
bindaddr=0.0.0.0
bindport=4570
OK I now have it working for me.
The bindport in IAX.conf needed to be changed to 4570 and then
server info on the Allstar portal also needed to be changed.
Thanks to Brian for the missing piece of info. The last time I had
to do this was when there was no portal config.
Jon VA3RQ
On 10/12/2012 11:31 AM, George Csahanin
wrote:
      On my node 28599 here's where I
root@nat:/etc/asterisk #
grep 4570 *
rpt.conf.
GeorgeC
Poff
2012 8:32 AM
Subject: Re:
working
    Just for drill...  if you move into /etc/asterisk and do "fgrep
4569 *" and “fgrep 4570 *”.
    What do get back?
    Here's what I see with my alternate port 4565 (on XIPAR) :
Robert A. Poff
Loganville, PA
            ***[                      S/V
Loon](http://wb3awj.hobby-site.org/loon.htm)***
1983 Hunter 34
Havre de Grace, MD.
            WB3AWJ *- Allstar 27784*
            *Powered by Linux*
