AllStarLink v3 Software Updates Release - 2026-01-29
As AllStarLink v3 continues to grow and improve, we are pleased to announce updates and new software packages. The following updated packages are now available :
asl3-asterisk 22.7.0+asl3-3.7.1
  • asterisk
    • Update from Asterisk 22.5.2 to Asterisk 22.7.0
  • asl3-asterisk
    • Add support for asterisk 23.1 PR #70
  • app_rpt
    • app_rpt: Use ao2 container for link management PR #810
    • app_rpt: Remove unused numoflinks from FindBestRssi() PR #817
    • chan_echolink: only init frame if it is going to be used PR #823
    • app_rpt: Move common code into rpt_request_pseudo_chan() PR #826
    • rpt.conf: Default lookup method change to dns from both PR #829
    • app_rpt: No ducking on timeout message PR #833
    • chan_voter: Refactor if() statements to follow asterisk guidelines PR #834
    • chan_voter: Ignore clients when no asterisk channel is setup PR #835
    • chan_voter: Add command line completion PR #836
    • CodeRabbit: first pass at configuration file PR #837
    • Add docstrings to voter-loop-part2 PR #838
    • app_rpt: prevent html in logfile, add "words" to http codes PR #840
    • app_rpt: Correct inxlat and outxlat loading PR #841
    • chan_usbradio: remove unnecessary code PR #842
    • CodeRabbit: Add docstring configuration PR #843
    • chan_voter: Additional debug message changes for easier troubleshooting PR #844
    • Update Linter to 19 and fix style path PR #848
    • chan_voter: Remove dynamic mode PR #849
    • Add docstrings to remove-dynamic-mode PR #850
    • app_rpt: Enumerate phone_mode PR #851
    • app_rpt.c: Clear active_telem when flushing telemetry PR #852
    • rpt_link.c: remove check_link_list() PR #855
    • chan_voter: Reorganize functions by functional use and fix comments PR #859
    • CodeRabbit: Disable poem in code rabbit PR #860
    • chan_voter: Fix module reload chan_voter not detecting client type change PR #861
    • app_rpt.c: Fix "spewing" tot overide debug message PR #862
    • app_rpt: Enumerate parrot states PR #863
    • app_rpt: address race setting myrpt->calldigittimer PR #864
    • chan_voter: Detect and handle buflen too small with mix mode clients PR #867
    • app_rpt: Refactor telem_done PR #868
    • chan_voter: Add comments to code, add/revise logging PR #869
    • app_rpt: cancel_pfxtone() should not try to hangup on a null channel PR #870
    • rpt_link.c: disable check_tlink_list() preparatory to removal PR #871
    • chan_voter: Update payload types to defined labels PR #873
    • app_rpt: Use rpt_tele_mode enum for rpt_telemtry() PR #874
    • app_rpt: Add mutex around cancel_pfxtone list traversal PR #876
    • app_rpt: Refactor rpt_manager using ast_str PR #877
    • app_rpt: Refactor connect_link() and attempt_reconnect() as a thread PR #879
    • chan_voter: Remove nulaw audio processing not implemented in clients PR #880
    • app_rpt: update/validate struct rpt, remove unused variables, refactor char x; and unsigned int x:1; -> rpt_bool x; PR #881
    • app_rpt: optimized cancel_pfxtone() PR #883
    • chan_voter: Remove un-documented duplex option, add "voter tune" CLI PR #884
    • chan_voter: Use ast_null_frame PR #885
    • app_rpt: Add references to l when unlinking to allow finishing up, then free PR #887
    • app_rpt: Fix retry mechanism - prevent multiple connection threads PR #888
    • chan_usbradio.c: Remove unused configuration variable rxctcssadj PR #890
    • app_rpt: restore voxtimeout configuration removed in PR#770 PR #893
    • chan_simpleusb.c: Fix variable declaration in switch case statement PR #894
    • rpt_install.sh: fix the broken link for sound file PR #895
    • app_rpt: Address memory leak missing pthread_join() PR #896
    • app_rpt: Fix missed callmode enum PR #897
    • app_rpt: Address initialization of calldigittimer missed in PR #864 PR #898
    • chan_usbradio.c: fix backward comptibility for EEPROM r/w PR #899
    • app_rpt: Remove incorrect warning message from telemetry thread PR #901
    • app_rpt: Address reference leak when calling rpt_link_add() PR #906
Please update your systems using the Cockpit web console or command line at your convenience.
Sincerely,
AllStarLink
This topic was automatically closed after 2 hours. New replies are no longer allowed.
