AllStarLink v3 continues to grow and improve we are pleased to announce updates and new software packages. The following updated packages are now available :
asl3 3.11.0
- asl-play-arn: Fixes permission problem when playing ARRL radio news PR #158
- asl-play-arn: Use full path to overcome PATH indeterminacy PR #160
asl3-asterisk 22.5.2+asl3-3.6.2
asterisk
- Update from Asterisk 22.4.1 to Asterisk 22.5.2
asl3-asterisk
- asl3-asterisk-config.postinst: fix package name PR #59
- Remove Unneeded Dependency PR #60
- Add patch to search "custom" directory PR #61
- Remove the c-client library depdencency PR #62
- Updates for asterisk-22.5.2 PR #63
- Add patch to correct how deep/wide template configurations are saved PR #64
- Check/Install DAHDI Modules at Start PR #65
- Add AmbientCapabilities=CAP_NET_BIND_SERVICE PR #66
- asterisk.service: add TimeoutStartSec PR #68
app_rpt
- chan_beagle: Initial port to compile on current Asterisk PR #319
- Multiple: Remove RPT_TELECONF and Use ast_audiohook_volume* for ducking PR #563
- app_rpt: Allow tailmessage from dialplan PR #688
- chan_echolink: add few missing locks PR #724
- res_usbradio: correctly apply the USB deviceID mask PR #728
- *-tune-menu: (S)wap command should not exit when no alternate devices PR #730
- app_rpt: rpt_call.c address cap memory leak PR #732
- app_rpt: Add TOD to dialplan PR #735
- app_rpt: rpt_play_tone incorrectly handling rpt_stop_tone PR #738
- Add TX soft limiter adjustment to chan_usbradio.c, xpmr.c, and xpmr.h. PR #740
- app_rpt: fix connect time reported by "rpt lstats" command PR #741
- app_rpt: Add timeout reset delay via
toresettimeparameter PR #744 - simpleusb.conf: Remove invalid options txmixa and txmixb. Update definitions PR #747
- chan_usbradio & chan_simpleusb: add limits PR #748
- app_rpt.c: Remove totx pointer PR #749
- Update README to use clang-format for code prettification PR #750
- chan_beagle: Remove beagleboard support PR #752
- chan_simpleusb.c: remove unused code PR #755
- app_rpt: toresettimer default to 0 (off) PR #756
- app_rpt: .clang-format: Remove duplicate BasedOnStyle directive PR #757
- app_rpt: expand usage of CHAN_TECH() macro (for readability) PR #758
- chan_usbradio: Optimize frame init PR #761
- app_rpt: refactor elapsed time handling PR #762
- chan_usbradio: Code quality - match simpleusb PR #764
- beagle.conf: remove the (no longer supported) config file PR #766
- app_rpt.c: Warn when using pipe delimiter in dialplan instead of comma PR #769
- app_rpt: Investigate the time out code and fix issues with the time out reset timer PR #770
- app_rpt: Fix random key ups and telemetry messages being sent after a time out condition PR #772
- iax.conf: Tune jitterbuffer settings PR #775
- app_rpt: Remove "RANGER" Special Handling for Nodes starting with 9 PR #776
- app_rpt: restore noduck functionality PR #777
- voter.c: Revise debug message levels for easier troubleshooting PR #778
- chan_echolink: Handle truncated call and name PR #780
- Add docs for rpt_telem_time PR #781
- app_rpt.c: Add missing CALLMODE_DOWN when autopatch setup fails. PR #783
- app_rpt.c: Handle duplex=0 with linktolink=yes PR #784
- rpt_link.c: Add {} to all if statements PR #785
- app_rpt.c: Allow Tone macro on each keyup by adding "R" to macro string PR #787
- chan_simpleusb, chan_usbradio: write tune settings only to node/interface PR #788
- app_rpt.c: add mutex_lock when setting audiohooks PR #790
- app_rpt.c: Add "alive" timer to rpt thread checking PR #792
- Channel drivers, tune utilities: add Tx Audio Stats, fix issue 791 PR #793
- Adjust Pre-commit workflow permissions PR #795
- app_rpt: clear tv_usec when clearing tv_sec on link connections PR #797
- app_rpt: Use MAXCONNECTTIME and remove unnecessary variable mymaxct PR #798
- app_rpt: address periodic_process_link not processing all links in certain conditions PR #799
- Audiohook FRACK resolution PR #801
- Revert PR#790 PR #802
- app_rpt: prevent null pointer when calling softhangup(), observed in issue #763 PR #803
- app_rpt: on update_parrot() and update_timers() failure, add missing call to rpt_mutex_unlock() PR #804
- app_rpt: Update all mutex calls to myrpt->lock to use rpt_mutex_* PR #805
- app_rpt: add missing unlock "rainy day" path, remove double lock in rpt_manager_do_xstat() PR #806
- app_rpt: log warning when audiohook fails to adjust volume PR #807
- app_rpt: audio ducking not restoring due to incorrect variable init PR #808
- app_rpt: initialize last_thread_time in rpt_master() PR #809
- app_rpt: memory leak in attempt_reconnect() failure paths PR #811
- app_rpt: Use ast_opt macro instead of ast_test_flag for options PR #814
- app_rpt: Correct logging when TELEM_TAIL_FILE_EXTN exists PR #816
- app_rpt: Remove duplicate lock PR #818
- configs: changes needed for the node-setup menu "customizations" PR #819
asl3-menu v1.15
- Add node customization support PR #79
- node-setup: also update node secret in IAX registrations PR #85
- asl-menu: avoid using
who am icommand PR #91 - node-setup: improve node # changes, especially INN <--> NNX PR #92
- asl-backup-menu: report errors such as node+password mismatch PR #93
- asl-backup-menu: add "--post-exec " option PR #94
- node-setup: allow comments on allowed/blocked nodes PR #97
asl3-pi-appliance 1.10.1
- Remove IPQoS in sshd_config PR #23
Please update your systems using the Cockpit web console or command line at your convenience.
Sincerely,
AllStarLink
