As AllStarLink v3 continues to grow and improve we are pleased to announce updates and new software packages.
ASL3 v3.6.0
sa818changes- Sync with the latest updates from 0x9900/SA818
- Add improved port selection from PR #25
asl3-asterisk 20.10.0+asl3-3.1.0-1
app_rpt
Tune menus should allow specifying “node” to update PR #409
Tune menus will not always save settings PR #410
SimpleUSB: show RX level PR #411
chan_usrp: Add TX/RX debug messages PR #413
chan_simpleusb, chan_usbradio: Add parameter to make scaling/clipping optional PR #418
Note: This change is important. The SimpleUSB and USBRadio channel drivers included code that could have resulted in audio scaling / clipping / distortion. We all want good quality audio so we have started an effort to disable the scaling / clipping code. With this change you are advised to check your audio levels and make any needed adjustments.
To minimize the impact on existing configurations we have introduced a new “legacyaudioscaling” parameter to the
simpleusb.confandusbradio.conffiles. The default value for this parameter is “yes” (to keep the scaling / clipping code in place). This means that existing .conf files (without the variable specified) will have the same behavior. At the same time, fresh installs will include “legacyaudioscaling = no” in the .conf files and will not use the old scaling/clipping code.Additional information on the scaling / clipping can be found in app_rpt #399.
Additional information on setting audio levels can be found in USB Audio Interfaces and Calibrating Audio Levels.
Fix crash if
rpt.confcannot be loaded PR #423
asl3-asterisk
asl3-menu v1.10
- node-setup : specify “node” when exec’ing “tune” menus PR #62
- node-setup: add suggestion to review interface settings PR #63
Please update your systems using the Cockpit web console or command line at your convenience.
Sincerely,
AllStarLink
