Good day all
Here in the Indian Ocean. the Reunion Island Amateur radio repeaters use SVXLink Reflector to connect among themselves. We have setup a link using raspberry PI and SVXLink to connect our repeater network to them.
I have setup an AllStarLink node here in Mauritius and would like to bridge/link both network.
I have tried to use the AllStar Echolink to achieve same but it does not work through TCP Port 5300.
Echolink uses UDP Port 5198, 5199 for out and inbound and TCP 5200.
SVXLINK Reflector uses TCP Port 5300 to allow SVXLINK nodes to connect.
In SVXLink I use a Reflector logic with the following:
[ReflectorLogic]
TYPE=Reflector
CALLSIGN= XXXXXX <---- your callsign, no need to use assigned Echolink Callsign.
JITTER_BUFFER_DELAY=0
HOST= [tcp-ip of the svxlink reflector]
AUTH_KEY=[Password to connect]
PORT=5301 <---- Can be either 5300, or 5301, or 5302
Is
it possible to change the Echolink Port value 5200 to 5300 thus may be allow connection to SVX reflector using the Echolink module AllStarLink ?
Or is there an alternative way to do it?
Thanks for any advice
73’s
Rachid
3B8FP.
Hi Adi
I would like to connect my allstar node to a Svxreflector network.
At my station, I have a PI connected to a Svxreflector network and a second PI running allstar node.
I want to interconnect them or at least provide DTMF for Svxreflector to connect to allstar.
vy 73’s
Rachid
3B8FP
On Mon, May 13, 2019 at 12:26 AM Adi Bier dl1hrc@gmx.de wrote:
Hi Rachid,
Am 12.05.19 um 19:59 schrieb Rachid Karroo:
Is it possible to change the Echolink Port value 5200 to 5300 thus may
AllStarLink ?
No, since the protocol of tcp-port 5200 (classic EchoLink) is different
from the Svxreflector’s protocol. Please could you figure out your
intention. SvxLink supports EchoLink and app_rpt as far as I know too,
you want to connect an allstar node to a SvxReflector network?
vy 73s de Adi / DL1HRC
