AllStarLink News
Replies to this topic show up on the portal in the ASL News Box.
Site news as of November 25, 2018
This is a complete redesigned (a refactoring) of the allstarlink.org site from the bottom up. The old site could no longer be supported because the operating system, applications and tools are way out of date.
The flash menu is gone. Adobe Flash is no longer required. A browser with HTML 5 and JavaScript is required.
Much of the help text disappeared when logging into the old site. That’s been fixed.
Much, much better mobile device support.
New nodes list complete with search, sort and pagination.
Sysop setting has been removed as this extra step is not needed. Server setup has a dialog explaining that you do not need a server or a node if you’re a portal only user.
Push configs to your node has been removed. There are better methods for this now days.
Improved Map in server settings. Marker is properly located on map when editing.
Callsign change request form is easier to request a callsign change.
Better visibility into the status of your node request.
Integration with forum site.
This is a test reply.
Lorem ipsum dolor sit amet, an convenire comprehensam pro, cibo ponderum urbanitas te eos, tota doming prompta eam eu. Eu brute tollit cum, odio tation aliquip eos in. Cu eius verear nostrum nam, nec wisi erant ei, ei est luptatum suavitate intellegebat. Deleniti temporibus quo no, veniam dolorem dissentiet id qui. Ne erant latine bonorum has, quidam forensibus philosophia quo cu.
Duo ad ignota fabulas fuisset, ex rebum dicat mazim nec, ad omittam facilisi ullamcorper eam. Ex vero mutat oblique usu, ad omnium iuvaret signiferumque eum, cu ius choro perfecto convenire. Eos ex choro feugiat. Denique pertinax dignissim ne his, sit veri euismod fastidii cu. Vis ne nulla doctus similique, ad vim labores epicurei, eum eu tota alterum.
Unum assum sea ut. Nullam soluta cotidieque et has. Mel ei nonumy conceptam. Nonumes adipisci pro ne, in cum singulis salutatus ullamcorper.
Pro te zril clita necessitatibus, dicit audire legendos et est. Mei an justo assentior, nam facer reprehendunt at. Est te mutat percipit patrioque, ex suas solet noster pro, no eam virtute meliore. Ex integre periculis eam. Cum numquam vituperata instructior id, blandit maluisset disputando te nam.
Possim adipisci ne vis. Est purto paulo rationibus id. In phaedrum concludaturque sed, illum utinam pertinax et vis. Sea fierent fastidii accumsan ut, apeirian expetendis assueverit in eum.
