Allstar
Hello Again. I failed to mention The Allstar server is running ACID. After boot up It repeats the following ,
(asterisk) did not claim interface 3 before use. Forgot where to fix this. Thanks again.
Chris
Allstar node 42264
You may have a USB pointing problem between asterisk and Linux.
On boot up type "service asterisk stop" at the command prompt
Type lsusb at the command prompt.
[root@Xxxxxx~]# lsusb
Bus 004 Device 004: ID 0d8c:013c C-Media Electronics, Inc. CM108 Audio Controller
Bus 004 Device 001: ID 0000:0000
Bus 004 Device 002: ID 0d8c:013c C-Media Electronics, Inc. CM108 Audio Controller
Bus 001 Device 001: ID 0000:0000
Bus 003 Device 001: ID 0000:0000
Bus 002 Device 001: ID 0000:0000
Bus 005 Device 001: ID 0000:0000
Then make sure your tune files ( in /etc/asterisk) properly point to your USB device such as a URI in devstr= (see below example)
[root@xxxxx asterisk]# cat usbradio_tune_usb<node#>.conf
[usb27178]
; name=usb<node#>
; devicenum=1
devstr=4-2 ; Bus 004 Device 002: ID 0d8c:013c C-Media Electronics, Inc. CM108 Audio Controller
rxmixerset=125
txmixaset=500
txmixbset=500
rxvoiceadj=1.820479
rxctcssadj=0.500000
txctcssadj=0
rxsquelchadj=825
Correct the tune file then
At the command prompt type: service asterisk start
Bob
kk6ecm
Sent from iPad
Chris
Allstar node 42264
That brings up some questions I have about this- I have 2 interfaces on the Pi2 running Dougs image, sometimes when I reboot it, the two nodes both try to use the same interface even though they are configured in the tune files. Throws up errors in a continuous loop. When I restart asterisks from the command line it then works as it should and the two nodes are using their assigned interfaces. It’s almost like the two interfaces are not fully initialized before asterisk starts on bootup. Now this is what lsusb shows:
Bus 001 Device 005: ID 0d8c:000c C-Media Electronics, Inc. Audio Adapter
Bus 001 Device 004: ID 0d8c:000c C-Media Electronics, Inc. Audio Adapter
When I used the tune menu to set the levels it wrote in the devices as follows:
For node 42051: devstr=1-1.4:1.0
For node 42078: devstr=1-1.5:1.0
Should I change that to 1-4 for node 42051, and 1-5 for node 42078?
Andrew.
To: chris ckw@gci.net
Cc:App_rpt-users@ohnosec.orgApp_rpt-users@ohnosec.org
Sent: Wednesday, August 26, 2015 10:23 PM
Subject: Re: [App_rpt-users] Allstar
On boot up type “service asterisk stop” at the command prompt
[usb27178]
; name=usb<node#>
; devicenum=1
rxmixerset=125
txmixaset=500
txmixbset=500
rxvoiceadj=1.820479
rxctcssadj=0.500000
txctcssadj=0
rxsquelchadj=825
Bob
kk6ecm
Sent from iPad
Chris
Allstar node 42264
I am not sure if you are listening on the arm-allstar list. If not questions on the BBB/RPi2 should be asked there.
Did you follow the instructions on installing two nodes on the RPi2 in the setup how-to on hamvoip.org? You need to follow the instructions in the initial setup and then NOT move the physical USB connections.
73 Doug
WA3DSP
Date: Fri, 28 Aug 2015 20:27:03 +0000
To: kk6ecm@gmail.com; App_rpt-users@ohnosec.org
Subject: Re: [App_rpt-users] USB Pointing problem- More info?
Andrew.
[usb27178]
; name=usb<node#>
; devicenum=1
rxmixerset=125
txmixaset=500
txmixbset=500
rxvoiceadj=1.820479
rxctcssadj=0.500000
txctcssadj=0
rxsquelchadj=825
Bob
kk6ecm
Sent from iPad
Chris
Allstar node 42264
Thanks Doug,
I’ll take a look at it. I added the second node number and interface later on after the initial setup. I was not on the arm-allstar mail list, I just signed up with it.
Thanks.
Andrew.
To: KD8USF kd8usf@yahoo.com
Cc:app_rpt-users@ohnosec.orgapp_rpt-users@ohnosec.org
Sent: Friday, August 28, 2015 8:37 PM
Subject: RE: [App_rpt-users] USB Pointing problem- More info?
73 Doug
WA3DSP
Andrew.
[usb27178]
; name=usb<node#>
; devicenum=1
rxmixerset=125
txmixaset=500
txmixbset=500
rxvoiceadj=1.820479
rxctcssadj=0.500000
txctcssadj=0
rxsquelchadj=825
Bob
kk6ecm
Sent from iPad
Chris
Allstar node 42264
