Hello
just got my dmr bridge from allstar 42282 to dmr 31655 working
however afterwards when i went to connect in my rf node 42668 I get a constant keyup every 30 seconds or so on the rf side (however long the intervals are)
there is no traffic on the dmr side when this happens
I have yet to disable the echolink to see if its coming from there
has anyone seen this or know a cure
thanks
mike
This might be a good question for the folks over at DVSwitch. Have you tried there yet? However, we do see @N4IRS here from time to time.
NO I thought that was what this forum was also
discovered it was the echolink node dead keying
seem if you run a bridge dont add echolink to it
I did not mean to discourage you from asking questions here. I just thought you’d have better luck over there. Only trying to be helpful. Anyway, glad you found the problem and thanks for letting us know what it was.
thanks for the help as always
