Allstar & Supermon 2 on a Windows 10 Machine
I’ve have Winscp and Putty installed. Having trouble figuring out how to install Supermon2. I have looked at several youtube videos and still having trouble. Really need someone to help me, maybe even log in to my PC and click what needs to be done. I have had Echolink running for several years and even have my Allstar Node number. I’m 75 years old and my mind is not as sharp as it used to be, even though for 18 years I was the IT director at the courhouse here.
Butch Bridges KC5JVT
Ardmore OK
My profile on QRZ is up to date
Hi Butch!
From what I understand, you have a windows 10 machine on which you want to install ASL3/Supermon 2, is that correct?
As far as I know, Allstar works on Linux only (Raspberry Pi or Debian) but you can use virtualization software to emulate a Debian PC on a Windows PC.
I, too, had a Windows PC for one of my nodes and what I did was install VirtualBox and then load a Debian 12 Linux image onto it. I used it as a radio-less node for a while, connecting to it via my phone.
Later, I passed through my modified Baofeng connected via a CM108 USB sound card.
VirtualBox is a software which can be installed on Windows and it allows you to create virtual machines of any operating system such as Linux. It will basically be like a Linux computer running within your main computer. VirtualBox will allow you to share your PC’s resources with the virtual machine.
If this is what you are looking for, i.e. running allstar ASL3 from a windows machine, I can guide you with it.
For this to work, you will need to have virtualization enabled in your BIOS and a version of Windows 10 that supports virtualization. This can be checked in the task manager which you can open by right-clicking on your task bar at the bottom. I have attached a screenshot with highlights.
Supermon is more for raspberry pi I believe, though I could be wrong.
Regards,
Adam
You can run ur node on VirtualBox inside those windows machines you mentioned.
It will be a breeze for you since you have IT experience. I can guide with the VM networking portion so you dont face the same hurdles that I did and get up and running in no time.
Using a GUI-less Debian will reduce resources used as well, in fact my whole image in less than 5GB and takes less than 1GB RAM.
A HAM friend in PA has been trying to help me get allstar up and running. I seem to have my node up and running, 58735. I need more help. Can you help me???
Butch, please state what you need help with to get an answer to that question.
I think my Raspberry Pi-3 is up and running. A friend in PA told me he can connect to it. I noticed when I go to CanYouSeeMe.org it shows my Port 4569 is not OPEN. I know my router and my modem has 4569 OPEN.
587352
Butch, what is it that you need help with or do you work it out already ?
First off, How do I (or someone) check to see if Allstar on my Pi is working correctly?
Pretty broad question.
Can you connect to other nodes ?
Can you have a conversation with someone on connected nodes ?
All I have is a Pi connected to my home network. I can log into it and see the menus. I have no other hardware or software set up. I have a laptop I hoped to set up and use, like maybe using SuperMon 2? Right now it has Win 10. If need be I could make it a Debian machine. So what is my next step?
That depends on what it is you want to do with it.
It’s not a one size fits all.
You configure to your needs/wants in use.
what is your end goal ? You got this far because you want to do what ?
I primarily want to use Allstar to connect to a Net everyday a noon near Tulsa - Allstar node 49562
So, what equipment do you have in place already ?
You have the server and a configured node ?
Do you have a way to work a connection on a node configured on that server ?
(ie usbradio/URI, iaxrpt, sip phone)
Can’t say what you need when we don’t know what you have.
Thanks for trying to help. Because of all the hassels I have decided to go to Plan B and install Supermon2 on a extra Windows 10 laptop I have. I found detailed step by step instructions on youtube. https://www.youtube.com/watch?v=XX8QzzQr-5s
