Allstar Stats Server
Am I missing something or is the Allstar Stats server been offline lately. Cannot reach it to obtain node statuses and bubble maps.
73s
Chuck
KM4NRJ
On Apr 26, 2016 12:00 PM, app_rpt-users-request@ohnosec.org wrote:
Send App_rpt-users mailing list submissions to
    app_rpt-users@ohnosec.org
To subscribe or unsubscribe via the World Wide Web, visit
or, via email, send a message with subject or body ‘help’ to
You can reach the person managing the list at
    app_rpt-users-owner@ohnosec.org
When replying, please edit your Subject line so it is more specific
than “Re: Contents of App_rpt-users digest…”
Today’s Topics:
  1. Re: Play two audio files back to back (David McGough)
  2. Re: Play two audio files back to back (Steve Mahler)
Message: 1
Date: Tue, 26 Apr 2016 07:51:32 -0400 (EDT)
To: “app_rpt-users@ohnosec.orgapp_rpt-users@ohnosec.org
Subject: Re: [App_rpt-users] Play two audio files back to back
Message-ID:
    <Pine.LNX.4.44.1604260747210.7079-100000@goliath.inttek.net>
Content-Type: TEXT/PLAIN; charset=ISO-8859-1
I think the playback command only takes a single audio filename.
Try this approach:
cat /var/lib/asterisk/sounds/tide.gsm > /tmp/temp.gsm
cat /var/lib/asterisk/sounds/times.gsm >> /tmp/temp.gsm
cat /var/lib/asterisk/sounds/will-expire.gsm >> /tmp/temp.gsm
cat /var/lib/asterisk/sounds/at-any-time.gsm >> /tmp/temp.gsm
asterisk -rx “rpt playback $node /tmp/temp”
rm -f /tmp/temp.gsm
Note that once these audio segments are cat’ed together, a final call to
sox can be used to change levels, formats, etc., if needed.
73, David KB4FXC
On Tue, 26 Apr 2016, kk6ecm wrote:
Hmmm … appears to be a mix of two syntaxes, and you may not achieve your goal…
Xxxxxxx*CLI> help rpt playback
Usage: rpt playback <sound_file_base_name>
   Send an Audio File to a node, send to all other connected nodes (global)
        (seems there used to be a <delay> as a third variable)
and
playback, file&file1 on the current node, where the concatenated files are joined with the &, no spaces.
I’m wondering… set delay to 0… not sure if there is a default, or even if it is still a feature.
e.g.
asterisk -rx “rpt playback $node channel 0”
asterisk -rx “rpt playback $node digits/$chan 0”
Bob
kk6ecm
Sent from iPad
On Apr 25, 2016, at 9:26 PM, Skyler F electricity440@gmail.com wrote:
Small Problem:
rpt playback 42622 channel&channel
ast_streamfile: Unable to open channel&channel
Skyler
On Mon, Apr 25, 2016 at 10:23 PM, kk6ecm kk6ecm@gmail.com wrote:
Leading and trailing spaces with the & are not tolerated.
e.g filename&filename2 OK
filename & filename2 Not OK
Bob
kk6ecm
Sent from iPad
On Apr 25, 2016, at 8:13 PM, Skyler F electricity440@gmail.com wrote:
I am currently writing scripts for my remote base, and am working on the channel switch acknowledgment.
Here is what I am currently doing:
asterisk -rx “rpt playback $node channel”
asterisk -rx “rpt playback $node digits/$chan”
This works well for my 16 channel radio, but I am annoyed by the amount of space between the audio files.
I tried stuff like
asterisk -rx “rpt playback $node channel & digits/$chan”
but I just get a syntax error.
Does anybody know the solution to get the audio files to play back to back like they do when AllStar announces node connections etc?
Skyler KD??WHB\
Skyler Fennell
amsatnet.info
KD??WHB
Message: 2
Date: Tue, 26 Apr 2016 07:08:11 -0500
To: app_rpt-users@ohnosec.org
Message-ID: 571F5A2B.4050307@lusfiber.net
Content-Type: text/plain; charset=windows-1252; format=flowed
Or, if you are using WAV files … catwav them (which uses sox) and play
the result …
/bin/rm -f $WXT/$TEMPMSG #Make filename available for output
/usr/local/bin/catwav $WXT/$TAILMSG $WXA/${P1}${P2}${P3} $WXT/$TEMPMSG
/bin/rm -f $WXT/$TAILMSG #Make filename available for output
/usr/local/bin/catwav $WXT/$TEMPMSG $WXA/spc.wav $WXT/$TAILMSG
You would do the asterisk -rx " rpt localplay NODE cattedfile" here (I
use it to build tailmessages with multiple announcements).
…STeve - KF5VH
Try this approach:
rm -f /tmp/temp.gsm
73, David KB4FXC
and
e.g.
Bob
kk6ecm
Sent from iPad
Small Problem:
Skyler
Bob
kk6ecm
Sent from iPad
I tried stuff like
Skyler KD??WHB\
Skyler Fennell
amsatnet.info
KD??WHB
End of App_rpt-users Digest, Vol 86, Issue 62
` I believe if you will check back through your previous
messages from earlier today or last night that it has been well
documented on this list that the server will be up and down.
    N5ZUA
On 4/26/2016 11:17 PM, KM4NRJ FLORIDA
bubble maps.
73s
Chuck
    KM4NRJ
On Apr 26, 2016 12:00 PM, < >
wrote:
      Send
      � � � � app_rpt-users@ohnosec.org
      � � � � [http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users](http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users)
      or, via email, send a message with subject or body 'help' to
      � � � � app_rpt-users-request@ohnosec.org
      � � � � app_rpt-users-owner@ohnosec.org
specific
      than "Re: Contents of App_rpt-users digest..."
      Today's Topics:
      � �1. Re: Play two audio files back to back (David McGough)
      � �2. Re: Play two audio files back to back (Steve Mahler)
      Message: 1
      To: "app_rpt-users@ohnosec.org          "
      Message-ID:
      � � � � <Pine.LNX.4.44.1604260747210.7079-100000@goliath.inttek.net>
filename.
      Try this approach:
/tmp/temp.gsm
/tmp/temp.gsm
      asterisk -rx "rpt playback $node /tmp/temp"
      rm -f /tmp/temp.gsm
      Note that once these audio segments are cat'ed together, a
final call to
      73, David KB4FXC
      > Hmmm ...� appears to be a mix of two syntaxes, and you
      > Usage: rpt playback <nodename>
      >� � � � Send an Audio File to a node, send to all other
      >� � � � � � �(seems there used to be a <delay> as a
third variable)
      > and
      > I'm wondering... set delay to 0... not sure if there is a
      > e.g.
      > >> asterisk -rx "rpt playback $node channel 0"
digits/$chan 0"
      > Thanks,
      > Bob
      > kk6ecm
      > 73
      > Sent from iPad
      > > On Apr 25, 2016, at 9:26 PM, Skyler F <          >
wrote:
Small Problem:
Skyler
On Mon, Apr 25, 2016 at 10:23 PM, kk6ecm <>
wrote:
� Leading and trailing spaces with the & are
not tolerated.
Bob
kk6ecm
Sent from iPad
On Apr 25, 2016, at 8:13 PM, Skyler F <>
acknowledgment.
digits/$chan”
files.
I tried stuff like
& digits/$chan”
Skyler KD??WHB\
You do not need a password to unsubscribe,
you can do it via email confirmation. If you have trouble
unsubscribing, please send a message to the list detailing the
problem.
Skyler Fennell
KD??WHB
Message: 2
To: Subject: Re: [App_rpt-users] Play two audio files back to back
Message-ID: <>
sox) and play
the result …
/bin/rm -f� $WXT/$TEMPMSG� � � �#Make filename available for
output
/usr/local/bin/catwav $WXT/$TAILMSG� $WXA/${P1}${P2}${P3}
$WXT/$TEMPMSG
/bin/rm -f� $WXT/$TAILMSG� � � �#Make filename available for
output
/usr/local/bin/catwav $WXT/$TEMPMSG� $WXA/spc.wav
$WXT/$TAILMSG
here (I
…STeve - KF5VH
filename.
Try this approach:
/tmp/temp.gsm
/tmp/temp.gsm
/tmp/temp.gsm
rm -f /tmp/temp.gsm
a final call to
needed.
73, David KB4FXC
Hmmm …� appears to be a mix of two syntaxes, and
Usage: rpt playback
� � � � �Send an Audio File to a node, send to all
� � � � � � � (seems there used to be a
and
e.g.
digits/$chan 0”
Bob
kk6ecm
Sent from iPad
On Apr 25, 2016, at 9:26 PM, Skyler F <>
wrote:
Small Problem:
channel&channel
Skyler
wrote:
� �Leading and trailing spaces with the &
are not tolerated.
Bob
kk6ecm
Sent from iPad
acknowledgment.
digits/$chan”
files.
I tried stuff like
& digits/$chan”
Skyler KD??WHB\
unsubscribe, you can do it via email confirmation. If you have
trouble unsubscribing, please send a message to the list
detailing the problem.
Skyler Fennell
KD??WHB
You do not need a password to unsubscribe, you can do it
via email confirmation. If you have trouble unsubscribing,
kk6ecm@gmail.com
amsatnet.info
kizzy@lusfiber.net
kk6ecm@gmail.com
amsatnet.info
yea… the Stats server has been down now for a couple of days at least…
    N5ZUA
bubble maps.
73s
Chuck
    KM4NRJ
On Apr 26, 2016 12:00 PM, <app_rpt-users-request@ohnosec.org >
wrote:
      Send
specific
      Today's Topics:
      Message: 1
      Message-ID:
filename.
      Try this approach:
/tmp/temp.gsm
/tmp/temp.gsm
      rm -f /tmp/temp.gsm
final call to
      73, David KB4FXC
      > Hmmm ...  appears to be a mix of two syntaxes, and you
third variable)
      > and
      > e.g.
digits/$chan 0"
      > Thanks,
      > Bob
      > kk6ecm
      > 73
      > Sent from iPad
      > > On Apr 25, 2016, at 9:26 PM, Skyler F <electricity440@gmail.com          >
wrote:
      > > Small Problem:
      > > 73
      > > Skyler
      > >> On Mon, Apr 25, 2016 at 10:23 PM, kk6ecm <kk6ecm@gmail.com          >
not tolerated.
      > >> Thanks,
      > >> Bob
      > >> kk6ecm
      > >> 73
      > >> Sent from iPad
      > >> > On Apr 25, 2016, at 8:13 PM, Skyler F <electricity440@gmail.com          >
acknowledgment.
      > >> > asterisk -rx "rpt playback $node channel"
digits/$chan"
files.
      > >> > I tried stuff like
& digits/$chan"
      > >> > 73
      > >> > Skyler KD??WHB\
problem.
      > > Skyler Fennell
      > > [amsatnet.info](http://amsatnet.info)
      > > KD??WHB
      Message: 2
      Message-ID: <571F5A2B.4050307@lusfiber.net>
      Or, if you are using WAV files ... catwav them (which uses
sox) and play
      the result ...
output
$WXT/$TEMPMSG
output
$WXT/$TAILMSG
here (I
      ...STeve - KF5VH
filename.
      > Try this approach:
/tmp/temp.gsm
/tmp/temp.gsm
/tmp/temp.gsm
      > rm -f /tmp/temp.gsm
a final call to
needed.
      > 73, David KB4FXC
      >> and
      >> e.g.
digits/$chan 0"
      >> Thanks,
      >> Bob
      >> kk6ecm
      >> 73
      >> Sent from iPad
wrote:
      >>> Small Problem:
channel&channel
      >>> 73
      >>> Skyler
are not tolerated.
      >>>> Thanks,
      >>>> Bob
      >>>> kk6ecm
      >>>> 73
      >>>> Sent from iPad
acknowledgment.
digits/$chan"
files.
      >>>>> I tried stuff like
& digits/$chan"
      >>>>> 73
      >>>>> Skyler KD??WHB\
      >>> Skyler Fennell
      >>> KD??WHB
      > To unsubscribe from this list please visit [](http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users)[http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users](http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users)
Loren Tedford (KC9ZHV)
Email: lorentedford@gmail.com
http://www.lorentedford.com
http://www.kc9zhv.com
http://forum.kc9zhv.com
http://hub.kc9zhv.com
http://www.newwavesucks.com
http://forum.newwavesucks.com
