Allstar node
Those mods are about the same as lots of them on the net.
They still do not expose the discriminator or modulator.
73, Steve N4IRS
Maybe this link to Doug's slick modification might be helpful
> information with regard to the abilities of the BF888s
> Warren, KD4Z
Steve,
That’s because the BF-888 and similar models do not have those exact connection points; most uses of those radios don’t require the ability to disable the built in bandpass filters and preemphasis or deemphasis, which is actually handled entirely inside the radio firmware. I’m not certain exactly what the OP is wanting to do beyond setting up the two different modes on the same hardware, but if there is a desire to bridge between them, I do know how to accomplish that part.
Matthew Pitts
N8OHU
To:app_rpt-users@ohnosec.orgapp_rpt-users@ohnosec.org
Sent: Tuesday, September 22, 2015 1:59 PM
Subject: [App_rpt-users] Allstar node
73, Steve N4IRS
Maybe this link to Doug’s slick modification might be helpful
Warren, KD4Z
Your best bet is some old motorola surplus. The GM300, Maxtrac, SM50, CDM750’s are great for link nodes or repeaters. You can find them on ebay cheap. I’m sure they’ll have a much better duty cycle than the 888 also. All the pins you need to interface to your node are on the 16 pin accessory connector on the back. The best bang for your buck might be an SM50 or GM300
On Wed, Sep 23, 2015 at 5:18 PM, n8ohu@yahoo.com wrote:
Steve,
Matthew Pitts
N8OHU
73, Steve N4IRS
Warren, KD4Z
Hi,
I agree that surplus Motorola hardware is an excellent way to go, except
from a TX duty cycle standpoint. I've built a couple portable repeaters
using a pair of 888 radios now and they run very high duty cycle with no
issues at all--not even needing any forced air cooling. The chief downside
to the 888 radios is synthesizer noise, and they are NOISY! So, that is
one major limitation is building a high-performance repeater. But, for a
local coverage or experimental unit, they're great!!
73, David KB4FXC
CDM750's are great for link nodes or repeaters. You can find them on ebay
cheap. I'm sure they'll have a much better duty cycle than the 888 also.
GM300
On Wed, Sep 23, 2015 at 5:18 PM, <n8ohu@yahoo.com> wrote:
> Steve,
> That's because the BF-888 and similar models do not have those exact
> connection points; most uses of those radios don't require the ability to
> is actually handled entirely inside the radio firmware. I'm not certain
> Matthew Pitts
> N8OHU
> *From:* Steve Zingman <szingman@msgstor.com>
> *To:* "app_rpt-users@ohnosec.org" <app_rpt-users@ohnosec.org>
> *Sent:* Tuesday, September 22, 2015 1:59 PM
> *Subject:* [App_rpt-users] Allstar node
> 73, Steve N4IRS
> > Warren, KD4Z
> App_rpt-users mailing list
> press the "Unsubscribe or edit options button"
> You do not need a password to unsubscribe, you can do it via email
> confirmation. If you have trouble unsubscribing, please send a message to
> the list detailing the problem.
